| Mast too Long. Need to Fix. #101992 03/29/07 02:13 PM 03/29/07 02:13 PM |
Posts: 20 Destin FL | I have an 86 H16 with a comp tip mast. Apparently the mast was not cut short enough when they comptip was installed by 4.25 inches. I really dont want to break the mast apart if possible. Is there any problems with cutting the comptip down at the top and then reinstalling the comptip mast head the halyard hook?
Does anyone have any other suggestion for getting the mast to the correct size?
Thanks
86 H16
Its such a fine line between clever and stupid.
| | | Re: Mast too Long. Need to Fix.
[Re: Fender]
#101995 03/29/07 03:58 PM 03/29/07 03:58 PM |
Thanks I have to shorten the distance between the top and where the sail inserts in the mast for the downhaul. I got the measurements from hobie and the metal part is definately long. Im for sure going to triple check this before I do anything to it. I will probably get someone else to confirm this also prior to any alterations to make sure Im not having a brain cramp or something. Ive run 3 sets of mains on this with the exact same issue.
86 H16
[Re: davidtilley]
#101997 03/29/07 04:29 PM 03/29/07 04:29 PM |
Posts: 20 Destin FL | Id like to be able to race if I wanted so I may have to break them apart then.. Arghhhh!!!
86 H16
[Re: srm]
#101999 03/29/07 08:15 PM 03/29/07 08:15 PM |
Posts: 20 Destin FL | The mast has a screw on either side of it so help secure the comp tip. The comp tip is 93 inches long (exluding where the rollers are) and the aluminum mast is 224 inches long (not including the mast base) Does this seem too long? Total on 317 inches.
If its class legal I would prefer just to cut the comptip at the top to get it to spec.
86 H16
[Re: Fender]
#102002 03/30/07 06:42 AM 03/30/07 06:42 AM |
Posts: 29 syracuae | i would take the comptip off the mast and cut the mast where the comptip goes in. this way your next comptip or sail track will fit and you won't have to mess with the tang that holds the main up. just call local metal suppley (bla bla steel supply company) and they will probly cut it for you in two seconds straight and square.
Cheech U-204
[Re: mmiller]
#102005 03/30/07 01:24 PM 03/30/07 01:24 PM |
Posts: 84 ms/fl | why dont you just get another mast----there are lots of used ones....or just tie a 4 inch line between your gooseneck and your sail
A-class #19
[Re: DHO]
#102006 03/30/07 08:24 PM 03/30/07 08:24 PM |
Posts: 5,582 “an island in the Pacifi... | How come Hobie is the only cat manufacturer that the commie lawyers forced into using Comp-tips??? Deeeeeeep pockets. Shysters will always focus on the big money. US Sail Level 2 Instructor US Sail Level 3 Coach | | |
334
guests, and 213
