| Re: Full-batten jib - better?
[Re: Rolf_Nilsen]
#103515 04/12/07 09:37 AM 04/12/07 09:37 AM |
Joined: Jun 2001 Posts: 3,293 Long Beach, California John Williams OP
Posts: 3,293 Long Beach, California | So, Rolf - I think what I have gleaned here is that; - 1. Fully-battened jibs have a finer entry, but as a result, potentially a narrower performance groove.
2. Fully-battened jibs hold shape better in certain conditions, and jib-life is somewhat extended. 3. The lowered tack position (sans furler) can be an advantage if sheeting angle, luff tension and slot are adjusted properly. 4. Battens in the jib are as critical as battens in the main, and adjustment to tension will be as important (no surprise there). 5. Mark Laruffa needs to get more sleep. That sum it up so far?
[Re: John Williams]
#103516 04/12/07 09:51 AM 04/12/07 09:51 AM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | [color:"green"]So, Rolf - I think what I have gleaned here is that; - 1. Fully-battened jibs have a finer entry, but as a result, potentially a narrower performance groove.
2. Fully-battened jibs hold shape better in certain conditions, and jib-life is somewhat extended. 3. The lowered tack position (sans furler) can be an advantage if sheeting angle, luff tension and slot are adjusted properly. 4. Battens in the jib are as critical as battens in the main, and adjustment to tension will be as important (no surprise there). 5. Mark Laruffa needs to get more sleep. That sum it up so far? [/color] Sounds like the sum up that I would have concluded. Dan | | | Re: Full-batten jib - better?
[Re: John Williams]
#103517 04/12/07 11:49 AM 04/12/07 11:49 AM |
Posts: 307 maui | hi guys here is my perhaps unusual take on jibs... lowering the tack has the the same effect as moving the jib leads aft. this lets the head fall to leeward, opening the top of the slot, but possibly causing leech flutter. all common knowlege. i sail in strong winds and came up with a fully battened 110%jib that roller furls. the battens are parallel with the luff. it made us point better and stopped leech flutter w/o moving the leads forward. actually, only the bottom batten is full. the other 2 are just very long. i have done sail making and have an industrial machine. this idea is offered for free. i'm not trying to sell jibs here. for our sailing this has been a huge improvement in both sailing performance and ease of jib furling. there photos if intrest is there. ciao
[Re: TEAMVMG]
#103519 04/12/07 12:14 PM 04/12/07 12:14 PM |
Posts: 1,307 Asuncion, Paraguay | i never get the argument that the battens make a jib last longer - JUST PULL A LINE AND ROLL IT UP! if its flogging on the beach. Good point. For this reason I will try a full battened jib but with battens PARALEL TO THE HEADSTAY. It will be like the old Supercat battens, only extended to the foot. The idea is to gain area and maintain shape while still being able to roll it up. Anyone tried this? Suggestions and comments are welcome.
Luiz
[Re: Laruffa]
#103523 04/12/07 03:51 PM 04/12/07 03:51 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | Lowering the jib 1.5" would be impossible to notice any difference, if there is, even though we all do it at the front end of the fleet?? I would say that Tigermike was having a good day, and when lowering your jib there is more to consider, did you get the some rig tension, a small and I mean small change would alter the performance of the boat in any given condition. Fair comment - To be honest the rig may be some what tighter which I hadn't really considered till now. On the other hand - maybe it was just a good day out. Ask me again tomorrow night <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> >>That was the only thing I changed.<<
Pointing angle may not improve significantly as a result of dropping the jib 1-1/2". However, if the only change was lowering the jib, then the jib lead angle would also have changed as a result of lowering the jib. Changing the jib lead angle could have a significant effect on pointing angle. Once again you could be right. I did move the jib sheet up 1 hole on the normal setting though. I don't have enough knowledge to pinpoint exactly what the cause was beyond what I tried and what I observed. Tiger Mike
[Re: warbird]
#103524 04/13/07 06:06 AM 04/13/07 06:06 AM |
Posts: 12,310 South Carolina | Yes, yes, yes..why do roller furling jibs flog???like people who can't find the indicater before turning. Lip luff..piut a little tension on the jib... why do jibs flog? Because nothing keeps the traveler from moving inward. The wind pressure can swing it back and forth too.
Jake Kohl | | |
345
guests, and 77
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
