Re: Full-batten jib - better? [Re: macca] #103511
04/12/07 07:30 AM
04/12/07 07:30 AM
L
Laruffa Offline
Laruffa  Offline
L
Hi Macca, yes sheeting angle is important, but the veiw was that just lowering the jib 1.5" made it faster without considering were the sheeting angle is. PS are you sailing this weekend call me tomorrow LOV Mark
Re: Full-batten jib - better? [Re: Laruffa] #103512
04/12/07 07:31 AM
04/12/07 07:31 AM
L
Laruffa Offline
Laruffa  Offline
L
goodnight all <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Full-batten jib - better? [Re: Laruffa] #103513
04/12/07 07:51 AM
04/12/07 07:51 AM
Thanks Mark, and goodnight <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
I am not taking recognized best practice from the "gods" as gospel, thats how this thread got started after all. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
But I am a bit surprised that you are hesitant to post your opinions/views due to different interpretations of your writings. Hope you continue to post here and don't let the "mob" get to you! It's pretty civilized here compared to other forums.
Re: Full-batten jib - better? [Re: Jake] #103514
04/12/07 08:15 AM
04/12/07 08:15 AM
ncik Offline
ncik  Offline
Lowering the jib on the forestay has the same effect as moving the track aft, it opens the slot. It's all relative to the geometry of the jib and the track.
Re: Full-batten jib - better? [Re: Rolf_Nilsen] #103515
04/12/07 10:37 AM
04/12/07 10:37 AM
John Williams Offline OP
So, Rolf - I think what I have gleaned here is that;
  • 1. Fully-battened jibs have a finer entry, but as a result, potentially a narrower performance groove.
    2. Fully-battened jibs hold shape better in certain conditions, and jib-life is somewhat extended.
    3. The lowered tack position (sans furler) can be an advantage if sheeting angle, luff tension and slot are adjusted properly.
    4. Battens in the jib are as critical as battens in the main, and adjustment to tension will be as important (no surprise there).
    5. Mark Laruffa needs to get more sleep.
That sum it up so far?
Re: Full-batten jib - better? [Re: John Williams] #103516
04/12/07 10:51 AM
04/12/07 10:51 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
[color:"green"]So, Rolf - I think what I have gleaned here is that;
That sum it up so far? [/color]
Sounds like the sum up that I would have concluded.
Dan
Re: Full-batten jib - better? [Re: John Williams] #103517
04/12/07 12:49 PM
04/12/07 12:49 PM
maui
jollyrodgers Offline
maui
hi guys
here is my perhaps unusual take on jibs...
lowering the tack has the the same effect as moving the jib leads aft. this lets the head fall to leeward, opening the top of the slot, but possibly causing leech flutter. all common knowlege.
i sail in strong winds and came up with a fully battened 110%jib that roller furls. the battens are parallel with the luff. it made us point better and stopped leech flutter w/o moving the leads forward. actually, only the bottom batten is full. the other 2 are just very long. i have done sail making and have an industrial machine. this idea is offered for free. i'm not trying to sell jibs here. for our sailing this has been a huge improvement in both sailing performance and ease of jib furling. there photos if intrest is there.
ciao
Re: Full-batten jib - better? [Re: jollyrodgers] #103518
04/12/07 01:03 PM
04/12/07 01:03 PM
Roller furling, vertical battens:
Standard on the Hobie Bravo! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Re: Full-batten jib - better? [Re: TEAMVMG] #103519
04/12/07 01:14 PM
04/12/07 01:14 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
i never get the argument that the battens make a jib last longer - JUST PULL A LINE AND ROLL IT UP! if its flogging on the beach.
Good point. For this reason I will try a full battened jib but with battens PARALEL TO THE HEADSTAY. It will be like the old Supercat battens, only extended to the foot.
The idea is to gain area and maintain shape while still being able to roll it up.
Anyone tried this? Suggestions and comments are welcome.
Luiz
Re: Full-batten jib - better? [Re: Luiz] #103520
04/12/07 03:05 PM
04/12/07 03:05 PM
John,
I have not concluded on much yet, except on your point 5. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Hope Mark is back tomorrow.
Finer entry? Why is this not possible without full battens? Longer life, perhaps? The low foot.. no big deal in my opinion, as there are more turbulence and less wind further down. But no reason against having the same geometry/outline with or without full length battens.
All in all, with over 600 views on this thread, no reports have been made on superior performance with fully battened jibs. Why? Perhaps becouse there have not been done much testing on it? I dont know, but would dearly like to.
BTW: I asked earlier wether there had been selftacking fully battened jibs before the Tornado. I got an reply by e-mail explaining that the RC-27 had a fully battened jib from the late '80s and the Supercat 22 from '91.
Re: Full-batten jib - better? [Re: jollyrodgers] #103521
04/12/07 03:43 PM
04/12/07 03:43 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
I would love to see those photos please.
Re: Full-batten jib - better? [Re: Luiz] #103522
04/12/07 03:46 PM
04/12/07 03:46 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Yes, yes, yes..why do roller furling jibs flog???like people who can't find the indicater before turning.
Lip luff..piut a little tension on the jib... why do jibs flog?
Re: Full-batten jib - better? [Re: Laruffa] #103523
04/12/07 04:51 PM
04/12/07 04:51 PM
Victoria, Australia
C2 Mike Offline
C2 Mike  Offline
Victoria, Australia
Lowering the jib 1.5" would be impossible to notice any difference, if there is, even though we all do it at the front end of the fleet?? I would say that Tigermike was having a good day, and when lowering your jib there is more to consider, did you get the some rig tension, a small and I mean small change would alter the performance of the boat in any given condition.
Fair comment - To be honest the rig may be some what tighter which I hadn't really considered till now. On the other hand - maybe it was just a good day out. Ask me again tomorrow night <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
>>That was the only thing I changed.<<
Pointing angle may not improve significantly as a result of dropping the jib 1-1/2". However, if the only change was lowering the jib, then the jib lead angle would also have changed as a result of lowering the jib. Changing the jib lead angle could have a significant effect on pointing angle.
Once again you could be right. I did move the jib sheet up 1 hole on the normal setting though. I don't have enough knowledge to pinpoint exactly what the cause was beyond what I tried and what I observed.
Tiger Mike
Re: Full-batten jib - better? [Re: warbird] #103524
04/13/07 07:06 AM
04/13/07 07:06 AM
Because nothing keeps the traveler from moving inward. The wind pressure can swing it back and forth too.
Re: Full-batten jib - better? [Re: Jake] #103525
04/13/07 04:09 PM
04/13/07 04:09 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
ah. I understand..self tacker...
Re: Full-batten jib - better? [Re: warbird] #103526
04/15/07 01:33 PM
04/15/07 01:33 PM
maui
maui
pdf attached.
this is the 3rd batten setup on this jib. works for me.
Re: Full-batten jib - better? [Re: jollyrodgers] #103527
04/15/07 08:12 PM
04/15/07 08:12 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
many thanks for that.
1 registered members (Team_Cat_Fever), 338 guests, and 35 spiders.
