Action pics #107185
05/15/07 02:13 PM
05/15/07 02:13 PM
Knokke-Heist - Belgium
Gilo Offline OP
Gilo  Offline OP
Hi everyone,
These are our first action pics.
I don't know if you can really see the shape of the spi but we tend to loose places going downwind.
These pics are taking with 2/3 beaufort.
Any comments?
Gill
Re: Action pics [Re: Gilo] #107186
05/15/07 02:13 PM
05/15/07 02:13 PM
Gilo Offline OP
Gilo  Offline OP
another one
Re: Action pics [Re: Gilo] #107187
05/15/07 02:26 PM
05/15/07 02:26 PM
That spin luff looks a little tight to me....
Re: Action pics [Re: Gilo] #107188
05/15/07 02:48 PM
05/15/07 02:48 PM
Hi everyone,
Any comments?
Gill
IMHO the spi looks fine, its just collapsing but thats pretty normal. I cant tell from the pictures but was the traveller centered and the mainsheet tight?
Have you tried sailing with the crew on the leeward hull, with the skipper sitting far forward? (Near, or in front of the boards(Depending on your weight)).
Re: Action pics [Re: Jalani] #107189
05/15/07 03:00 PM
05/15/07 03:00 PM
What kind of boats are you losing places to? Other F-16s of the same make with the same sails?
Are the boats set up alike?
Are you sailing the same angles and is your crew weight similar?
How does the skill level at downwind sailing on cats with spis compare?
There is a lot of skill involved in downwind sailing under spi, especially in the lower windrange.
Your spi remind me a lot of Tornado spis, I guess Landenberger is transfering technology. Funny shape at the tack, almost looks like it have stretched? I dont agree with John that the luff looks a bit tight (I like it), but is the spi set up according to Landenbergers recommendations?
Re: Action pics [Re: Rolf_Nilsen] #107190
05/15/07 04:19 PM
05/15/07 04:19 PM
Id say the shape of the Spi looks OK.
However, you don't have the windward hull flying quite high enough;
I'd always say 3 inches too high is better then 3 inches in the water !
As Rolf asks who are you loosing out to ?
Re: Action pics [Re: Gilo] #107191
05/15/07 05:05 PM
05/15/07 05:05 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
HEAT IT UP HEAT IT UP HEAT IT UP. That's all I have to say.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Action pics [Re: ejpoulsen] #107192
05/15/07 05:11 PM
05/15/07 05:11 PM
also just noticed it looks like the mainsail traveller is not centered
Re: Action pics [Re: Tony_F18] #107193
05/15/07 06:02 PM
05/15/07 06:02 PM
Victoria, Australia
C2 Mike Offline
C2 Mike  Offline
Victoria, Australia
Hi everyone,
Any comments?
Gill
Technique technique technique which = practice practice practice. The spi looks fine to me. The better guys are able to work the waves and take every opportunity to steer down wind a foot or two each time without loosing any speed.
Tiger Mike
Re: Action pics [Re: C2 Mike] #107194
05/15/07 06:26 PM
05/15/07 06:26 PM
Pensacola Beach, Fl.
C
CaptainKirk Offline
CaptainKirk  Offline
C
Pole needs some prebend in it, it looks from the pic to be way to straight and if anything bent up abit. Then adjust the luff tension my adjusting the halyard length. Thats what we do on the F 18 and the N 20.
Capt. Kirk
OLD DOG
Re: Action pics [Re: CaptainKirk] #107195
05/16/07 12:37 AM
05/16/07 12:37 AM
Yes, traveller looks like it is in 'depower' position.
We dont adjust luff tension with the halyard, but with the tack line if we want to depower or head higher. But for normal downwind sailing we have the luff line inside the spis luff tape set up with the tension we want.
Re: Action pics [Re: Rolf_Nilsen] #107196
05/16/07 01:02 AM
05/16/07 01:02 AM
ncik Offline
ncik  Offline
It's interesting that you cat guys talk about depowering the kite, or for pointing higher under kite, by releasing luff tension.
On dinghies we would lower the spinnaker pole to flatten the kite and enable higher pointing and for depowering.
I need to investigate further...
Re: Action pics [Re: ncik] #107197
05/16/07 06:23 AM
05/16/07 06:23 AM
100% drop the halyard to de power and flatten; just try it on land - it's so obvious its great <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Action pics [Re: scooby_simon] #107198
05/16/07 07:12 AM
05/16/07 07:12 AM
guess it would make sense that if you drop the halyard insted of the tack then you keep the same heeling moment rather than increasing it. Harder to see how far the halyard is down though- much easier to see how far the tack is out
Re: Action pics [Re: PTP] #107199
05/16/07 02:02 PM
05/16/07 02:02 PM
Gilo Offline OP
Gilo  Offline OP
Thanks for the replies guys, I'll try put some things into practice.
It is true indeed that I still need to practice practice practice....
Is pre-bend so important? Now the boom is straight and not under very much tension. I always thought, that when you pull the mainsheet, there will be extra tension on the boom, which should be enough....
Gill
Re: Action pics [Re: Gilo] #107200
05/16/07 02:42 PM
05/16/07 02:42 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
Pre-bend on the spinnaker pole is important to avoid breaking the pole, and to keep it fixed. With some pre-bend, the loads from the kite put the pole into compression and the tip of the pole is well braced.
0 registered members (), 295 guests, and 19 spiders.
Posts267,059
