Rating: 5
Page 4 of 11 1 2 3 4 5 6 10 11
Re: New A-class with a radical bow shape [Re: Wouter] #112575
09/03/07 03:47 AM
09/03/07 03:47 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
the last people who were knocking the dolphin idea said it was stupid because dolphins went through the water not over it.............just sounds like white noise to me.
Re: New A-class with a radical bow shape [Re: warbird] #112576
09/03/07 04:34 AM
09/03/07 04:34 AM
Warbird,
Are you really that "intellectually challenged" or only acting like it ?
Re: New A-class with a radical bow shape [Re: Wouter] #112577
09/03/07 12:34 PM
09/03/07 12:34 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
For example is not really well developped. Afterall the centrehull is still very much a conventional shape. If that had been of the same shape as the floats then you example would have been a proper one in relation to this new cat design.
Yes. Also, the float volume is placed high in the bow, so it looks like the new shapes but differs in one relevant feature.
On the other hand, when it flies the mainhull the lee float behaviour becomes dominant.
I guess the similitude would be the relatively low volume float. How does float volume/total displacement ratio in the new A Cats and F16s compare to that tri's 110%?
Luiz
Re: New A-class with a radical bow shape [Re: Luiz] #112578
09/03/07 02:04 PM
09/03/07 02:04 PM
That or rather the lift provided by its bruce foil ?
Re: New A-class with a radical bow shape [Re: Wouter] #112579
09/03/07 05:34 PM
09/03/07 05:34 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
I think it should be both: the bruce foil is supposed to lift 50% of total weight. That would leave 60% of the float volume over the waterline and 50% under. I'll let you know after a real world test.
Luiz
Re: New A-class with a radical bow shape [Re: ] #112580
09/03/07 06:01 PM
09/03/07 06:01 PM
Pictures look good. Has the the A cat been tried against any other boats to see performance against them?
Doug
So has the A cat shown in pictures been tested against other boats? <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Doug
Re: New A-class with a radical bow shape [Re: Wouter] #112581
09/03/07 07:42 PM
09/03/07 07:42 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Don't be like that Wouter, we're only having fun. I can imagine it is tough to live with a huge ego and low self-esteem but an abusive outburst never really brings satisfaction in the long term.
Try sitting quietly with yourself (no touching), breath deeply and paint your boat a less lurid colour and maybe you won't feel such a desperate need to be right all of the time.
Re: New A-class with a radical bow shape [Re: warbird] #112582
09/04/07 03:37 AM
09/04/07 03:37 AM
I refer you back to my earlier comment.
Re: New A-class with a radical bow shape [Re: ] #112583
09/04/07 04:01 AM
09/04/07 04:01 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
[quote]Pictures look good. Has the the A cat been tried against any other boats to see performance against them?
Doug
Hi Doug, Im the designer and yes it has, but less exhaustively than one could have hoped for so far. It would appear that the boat is moderately faster and sails higher than Flyers etc in all windspeeds, down hill in any wind, it kills everything. This last weekend it was out in 25-30 knots all day with 10-15 gusts and it never put the bow down more than 150mm at any speed in any gust. That said, we are still learning to sail it, the windward case being the most challenging and we are still a ways short of what we think it should do.
Have attached a couple of pics from GPS action replays of the Velocitek data to show what it does in 9.4 knots, will post some 30 knot stuff in the not too distant future
RG
Re: New A-class with a radical bow shape [Re: RetiredGeek] #112584
09/04/07 04:01 AM
09/04/07 04:01 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
uphill 101m average speed in 9.4 knots
Re: New A-class with a radical bow shape [Re: RetiredGeek] #112585
09/04/07 12:38 PM
09/04/07 12:38 PM
Do you have a website with anymore info and a US price?
Doug
Re: New A-class with a radical bow shape [Re: warbird] #112586
09/04/07 12:53 PM
09/04/07 12:53 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Beautiful lines. Takes the wave piercing concept to the next logical step. How about some drawings head on and broad side profile?
Bob
Re: New A-class with a radical bow shape [Re: Seeker] #112587
09/04/07 01:11 PM
09/04/07 01:11 PM
I have to say that the bow shape is slowly growing on me...although it still looks "retro" for some reason.
Re: New A-class with a radical bow shape [Re: Jake] #112588
09/04/07 01:18 PM
09/04/07 01:18 PM
Southern Ontario
fredsmith Offline
fredsmith  Offline
Southern Ontario
Don't worry what it looks like,its a fast shape and handles a chop really well.
Fred A class cat
Re: New A-class with a radical bow shape [Re: Wouter] #112589
09/04/07 04:15 PM
09/04/07 04:15 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Wouter, I refer you to early data and heresay about performance against Flyers........would sir like pie or roast crow?
Re: New A-class with a radical bow shape [Re: Jake] #112590
09/04/07 04:39 PM
09/04/07 04:39 PM
Atlanta
GeoffS Offline
GeoffS  Offline
Atlanta
Like a fungus. I think the reason it looks retro is because it looks like the aluminum Sizzler 16 catamaran featured in Jaws 2.
Re: New A-class with a radical bow shape [Re: warbird] #112591
09/04/07 04:40 PM
09/04/07 04:40 PM
Are you now claiming the Flyer hulls look like dolphins as well ?
Re: New A-class with a radical bow shape [Re: RetiredGeek] #112592
09/04/07 05:55 PM
09/04/07 05:55 PM
LA
Acat230 Offline
Acat230  Offline
LA
Doug
RG
The best test will be for Ian to head to Bristol and test the boat against benchmark A-Class sailors like Ben Hall, Lars Guck, and Phil Kinder. Until he does that, any claims on performance are pure speculation. I would bet that Ian is simply a better A-Class sailor than the sailors he has been sailing against so even if the boat's performance is equivalent to a Flyer or something else current, it will look faster due to the sailor's ability.
The boat is quite interesting. The hulls look like missles!
Bob Hodges
A2 USA 230
Re: New A-class with a radical bow shape [Re: Acat230] #112593
09/04/07 07:12 PM
09/04/07 07:12 PM
Looks like a drop tank off of fighter aircraft.
Re: New A-class with a radical bow shape [Re: Acat230] #112594
09/04/07 07:31 PM
09/04/07 07:31 PM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
Bob Hodges
A2 USA 230
Bob, I agree that its real performance won't be known till then either, I believe that will happen when everyone goes to the Lake Hopatcong Regatta Sept 29th
RG
0 registered members (), 794 guests, and 26 spiders.
