spinnaker handling tips required #118774
09/30/07 03:47 PM
09/30/07 03:47 PM
ISRAEL
segev Offline OP
segev  Offline OP
ISRAEL
hi
we have a new Inter 20 and we are getting into the spinnaker business. can any one send some tips about crew and helmsman work: rounding the weather mark & hoisting, snuffing before leeward mark rounding, gybing, etc...
thanks
Segev Eyal
Nacra F20C
Sdot Yam
ISRAEL
Re: spinnaker handling tips required [Re: segev] #118775
10/02/07 09:34 AM
10/02/07 09:34 AM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Snuffer or tramp bag segev?
Re: spinnaker handling tips required [Re: segev] #118776
10/02/07 10:42 AM
10/02/07 10:42 AM
If you are looking for an introduction to spinnaker sailing on cats in general, rather than the I20 in particular, there is some good information on the Catamaran Sailing DVD available here - http://tillard.georges1.free.fr/
Re: spinnaker handling tips required [Re: TEAMVMG] #118777
10/05/07 12:10 PM
10/05/07 12:10 PM
ISRAEL
segev Offline OP
segev  Offline OP
ISRAEL
snuffer, mid pole
Segev Eyal
Nacra F20C
Sdot Yam
ISRAEL
Re: spinnaker handling tips required [Re: ] #118778
06/05/08 01:28 PM
06/05/08 01:28 PM
california
F-18 5150 Offline
F-18 5150  Offline
california
Do you know where i can get a copy of that dvd?
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
R.Vilvens@yahoo.com
Fairfield, Ca
F-18 5150
Re: spinnaker handling tips required [Re: F-18 5150] #162155
12/07/08 11:01 AM
12/07/08 11:01 AM
Netherlands
Nacra inter 20 Offline
Netherlands
Hello, I find that the holding force on the spinakersheet is very high. my sheet runs from the spinaker through the ratched block on the sidestay and then trough a small block on the front beam to my crewmember. He is complaning over the amount of pulling force on the sheet. Does anyone have a suggestion on how to lower this force?
Re: spinnaker handling tips required [Re: Nacra inter 20] #162157
12/07/08 12:36 PM
12/07/08 12:36 PM
L
Lost in Translation Offline
L
Yes, put a second ratchet block where the small block is.
Re: spinnaker handling tips required [Re: Lost in Translation] #162173
12/07/08 07:40 PM
12/07/08 07:40 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I beleive that you can "double" the block on the sail to releive this issue.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: spinnaker handling tips required [Re: arbo06] #162216
12/08/08 11:09 AM
12/08/08 11:09 AM
Netherlands
Netherlands
My sheets is attached fix at the spinaker and from there the sheet runs trough the ratchedblock and then trough the small block at the front beam. Someone else suggested a second ratchedblock on the beam and that sounds to me as a simple but maybe sufficient solution.
Otherwise I have to try your solution. Thanks for the advise!
Re: spinnaker handling tips required [Re: Nacra inter 20] #162221
12/08/08 11:48 AM
12/08/08 11:48 AM
Two ratchet blocks make it a bit easier, but is your crew having difficulties in trimming the spinnaker, or holding it once it is trimmed?
As you know, spinnaker work is pretty constant (easing and trimming) and has to be coordinated with course changes by the helm.
I have found that in certain cases where we are pointing too high in order to fly the hull downwind, it is very difficult to trim the spinnaker (most likely because it's already as flat as it can be). If you are aware of your sailing angle when the crew is complaining, it may indeed be pretty high.
Either that, or your crew is like me and complains too much! smile
Re: spinnaker handling tips required [Re: waterbug_wpb] #162223
12/08/08 12:13 PM
12/08/08 12:13 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Sometimes no matter what you do, your crew will complain! grin
Re: spinnaker handling tips required [Re: ksurfer2] #162339
12/09/08 03:41 PM
12/09/08 03:41 PM
Cutler Bay, Florida
Bajan_Bum Offline
Bajan_Bum  Offline
Cutler Bay, Florida
I found the Agard videos on YouTube very helpful. There are about 4 of them. Here's one. Just query YouTube for the others.
Agard 2
Re: spinnaker handling tips required [Re: Nacra inter 20] #162421
12/10/08 04:03 PM
12/10/08 04:03 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
How old is your spinnaker? More than a season I bet - its blown out, get a new one.
Re: spinnaker handling tips required [Re: ksurfer2] #163321
12/22/08 12:01 PM
12/22/08 12:01 PM
I believe that is in my job description!
Glad to see your showing at Steeple. Any recap of what you did right/wrong? Did you do the "slog of shame" at Anne's Beach? Pick up any nice lobster pots on day 2?
How'd your crew fare? Is he up for 5 days of that stuff? smile
Re: spinnaker handling tips required [Re: waterbug_wpb] #165564
01/21/09 11:48 AM
01/21/09 11:48 AM
Netherlands
Netherlands
It is winter now in the Netherlands, but in april we start again. I can hardly wait, and try out the extra ratchet block for the genaker.
Re: spinnaker handling tips required [Re: TEAMVMG] #166154
01/26/09 09:58 AM
01/26/09 09:58 AM
Netherlands
Netherlands
Haha if money was no issue I would get a new one right aaway, but as most of us, I sail with a budget. Don't you have this problem? No, without kidding, the spinaker is fine, not blown out, but 25 sqm. is a lot on a single line!
A second ratchetblock is worth trying, I have a spare one lying around.
Re: spinnaker handling tips required [Re: Nacra inter 20] #166193
01/26/09 12:02 PM
01/26/09 12:02 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
So how old is it?
I spent 2 seasons with an early nylon kite on my 20 and kept telling myself that it was fine. got a new kite and no-one could touch us!
Re: spinnaker handling tips required [Re: TEAMVMG] #166426
01/27/09 08:13 PM
01/27/09 08:13 PM
arbo06 Offline
arbo06  Offline
Dammit, I really did not need to read that... I just plunked down $4k on a a jib and main... What does a good spi go for?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: spinnaker handling tips required [Re: Nacra inter 20] #166682
01/29/09 10:12 PM
01/29/09 10:12 PM
arbo06 Offline
arbo06  Offline
I run it from a block at the fore beam and then to a second beam at the shroud. The first block runs free and the second is a ratchomatick.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: spinnaker handling tips required [Re: arbo06] #166990
02/01/09 08:08 PM
02/01/09 08:08 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Eric,
I pd $950 for a new spin for the HT from Jay and Pease Glaser at the beginning of last season. Am very pleased with it.
Dave
0 registered members (), 489 guests, and 84 spiders.
Posts267,058
