I think what he is asking is; how do you reach the control line while out on the wire? If you run a long enough line all the way out to where you are trapped, you will get tangled in it when you come in to tack. I tie my rotator tail to my downhaul tail, around the base of my trap bungie line, so all I have to do to reach both while trapped is bend my knees, reach down, grab a handfull and then pull the correct string... which doesn't always work, as usually when a gust comes on, the last thing you want to do is bend your knees and reach inboard for the rotator or downhaul. I just ease the mainsheet in the gust, and if I want to change the rotation, I do it during the next tack or reach down in the next lull. Sometimes it would be nice to have a 100lb. (super hot) girl crew to do it for me though! <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Blade F16 #777
Re: mast rotation
[Re: Timbo]
#120632 10/22/0707:12 AM10/22/0707:12 AM
I got one. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Re: mast rotation
[Re: ]
#120633 10/22/0707:25 AM10/22/0707:25 AM
Has she got a sister? Something like that gal with the green Nike sneakers we saw here once? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Blade F16 #777
Re: mast rotation
[Re: ]
#120634 10/22/0707:47 AM10/22/0707:47 AM
I have a very, very simple system that works just fine. I run the mast rotator line (blue in the photo) around the shroud and then back across the tramp where I tie it to the other end of the blue line. Lines are yet tied in the photo, but I hope you get the idea. When in the trapeze, I just reach down and grab the line to adjust. When sailing with crew I like to keep the tramp cleaner, so I run the blue rotator line through the front beam. The crew just reaches down to grab it as needed. I do the same with the downhaul.
Eric: Thanks for the pic. I definitely have to do something before the Area D qualifier <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />.
Scooby: I think that's a little too complicated for me.
Bobcat: I'm not sure what I want to do at this point.
Pete,
It might look complex, but it works every time.
I now have the "uncleat line" going alonmg the boom, so as you come on to pop the kite it's one pull to uncleat the rope and go to max rotation, when the kite comes down, the tension in the downhaul rope pulls the rotation back on.
She has four sisters, but not quite to those specifications. : <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
Re: mast rotation
[Re: ]
#120641 10/25/0712:52 AM10/25/0712:52 AM
