Rating: 5
Page 5 of 17 1 2 3 4 5 6 7 16 17
Re: Kids F12 [Re: JeffS] #121574
11/07/07 05:55 PM
11/07/07 05:55 PM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
Jeff,
as per what appears to be the consensus here, sail is 7 sq.m but I could see going as high as 8.5 to 9 sq.m if you had a bit more weight on the boat.
cheers
RG
Re: Kids F12 [Re: RetiredGeek] #121575
11/07/07 06:36 PM
11/07/07 06:36 PM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
apart from the fact that it adds a little scale to the picture, every boat should be sold with one of these <grin>
cheers
RG
Re: Kids F12 [Re: RetiredGeek] #121576
11/07/07 08:15 PM
11/07/07 08:15 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
RG your a very naughty boy in two ways. Firstly my children and I would be ecstatic to hike out on that boat not really sold on the bars yet but happy without traps. Secondly I was hoping that boys would consider that rocket to be better than sex and therefore only be after my daughters for their boat <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Kids F12 [Re: RetiredGeek] #121577
11/08/07 03:15 AM
11/08/07 03:15 AM
yup, the gooseneck is a mess but the piece it's mounted on is tricky,
Why have a gooseneck at all. The mast is non rotating and the boom can even be totally free handing.
I think it is actually a drawback to use a conventional gooseneck, it will only prevent the rig from totally weathervaning or even being sheet out fully when on a dead downwind course.
As the mast section is round, one can just have a fitting on the end of the boom that is a fork and have that slide over the mast. Well, at least that is how my design has it.
Re: Kids F12 [Re: RetiredGeek] #121578
11/08/07 03:49 AM
11/08/07 03:49 AM
Allow me to play the devils advocate.
I did some spec checking and I compared some aspects of RG's proposal to the stated design goals.
RG wrote to me that he used a copy of the Moth rig in his drawings. The Moth rig is not an unstayed rig and it is highly unlikely that an unstayed mast will remain as straight a given in the pictures when loaded up. The Moth rig is actually 8.00 sq. mtr on a 6.250 mtr mast. More specs of other boats can of course be found on : http://www.xs4all.nl/~whijink/F12/
RG's design looks very well and is very succesful in attracting the sailors to the F12 idea. That is a very important development. Without some good promo the F12 project will be struggling. I too appreciate that very much.
Still, I'm a little bit at a loss in how to incorporate this design in the larger F12 scheme. Afterall it is basically his LR2 A-cat design scaled down in size with a Moth rig on it. Neither of these components is particulary inexpensive or easy to (home)build. But homebuilding is indeed regarded as the way to kick-start the F12 class till a more professional builder can be convinced to invest in the project. Of course the chined hull construction, as also shown by RG himself, is alot more in line with these design goals. It may be wise to focus on that part of the design and forget about the fully rounded version as I fear it will really problematic to prototype and build the class on the fully rounded version. We shouldn't give people to wrong idea by showing that version around to much either, for I fear they will never "get" the fully rounded version.
At this instance we must also appreciate how problematic it can be when the class is started and grown initiallly on the chined hull version only to have a professional builder do the rounded hulls later. Will all the boats build in the initial stages by outdated by that, how will their owners react to that, will they even consider building the boats when they are aware that such a thing may happen later. Such considerations are simply skipped over now.
RG comments on how chined hulls are draggy, or at least when compared to say his fully rounded hull. This may give further weight to the problems of transitioning from chined hulls to rounded hull later in the existance of the class. But I also believe it misses the F12 point somewhere. Indeed it stands to reason to expect the chined hull to be more draggy, but how important is this in the greater scheme. A Hobie 16 is seriously outdated in relation to say an F16 but the performance difference between them is only 15 %, most of it coming from the differences in the rig and overall weight. How much of that difference is the result of having inferiour hulls and lacking daggerboards ? Take a look at the Paper Tiger, a chined design that nobody regards as being slow.
This leads us to the following question, which is a very important one for the F12, how much additional cost and building effort is say 5% additional performance worth ?
It shall be obvious that I take a totally different take on things. I feel that it is far more valuable to have a very easily and inexpensively build F12 and work that quality into class growth. I don't believe that losing an X amount of performance (limited to 15% at max) is "worth it" if the class is strickt One-Design and will be beating a laser dinghy anyway.
At a certain point enough is enough and at that time there is more to be gained by optimizing the building time and costs. For a concept (sailing class) to be succesful, the whole picture must be right not just a few parts of it.
Welding ? Something I really tried to avoid in the F12 design. Homebuilders can not easily do it. It is also not needed. The same with bending the tubes.
Daggerboards have been covered already. Interesting to note is that assuming a chined hull is more draggy then it may well be more resistant to sideways slip ! I've sailed boardless cats for a long time and the pointing difference between say a nacra 5.7 and a nacra 5.8 wasn't very large at all. It is to us to decide whether the difference is large enough to decide to use daggerboards on the F12. In this balancing act we must not forget that daggerboards are a custom made item and do indeed add building costs and complexity to the design. They are also one more thing to get broken. To us the decision whether the advantages outweight the drawbacks.
Four of the more important design goals as stated explicetly last january were a F12 that could be build for 3000 Euro's or less by a relative homebuilder in 100 hours or less, fully rigged and derigged in max 5 minutes and fully assembled/disassembled in max 10 minutes. I still believe these to be critical for the succesful launch of the F12 class; otherwise I too would just have taken a CAD drawing of an F16 and scaled that down while replacing the 6 in the class logo by a 2.
Re: Kids F12 [Re: JeffS] #121579
11/08/07 04:13 AM
11/08/07 04:13 AM
Interestingly enough the Moths have similar bars as well an nobody is critical of those. I think we have a case of obsessing over a single item here. Most likely nobody gives a damn once the design is sailing. Notice how the Moths even use a bar going forward to stabilize the bottom of the mast. Even 18 foot skiffs have used rods for the same reasons. And yes that is Rohan Veals new Moth design and he is sailing it in the second picture. Now everybody feels it is the epithomy of coolness.
Re: Kids F12 [Re: Wouter] #121580
11/08/07 05:59 AM
11/08/07 05:59 AM
JeffS Offline
JeffS  Offline
How much harder to make the rounded hulls? are we talking another day in the building or another week? That boat is fast out of the water! RG do you have plans on the building of it yet.
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Kids F12 [Re: RetiredGeek] #121581
11/08/07 06:06 AM
11/08/07 06:06 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Yes my kids want one too! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
But the high aspect dagger boards are going to get whacked… I caste my vote for going with low profile boards (2/1 max.) for the kids.
Re: Kids F12 [Re: JeffS] #121582
11/08/07 08:04 AM
11/08/07 08:04 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
Aerynt called me tonight with another angle, his eldest son thinks it will be a babe magnet and is very happy about it <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
RG
Re: Kids F12 [Re: Wouter] #121583
11/08/07 08:10 AM
11/08/07 08:10 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
As a kid we used to have a half round welded to the boom that sat on an upturned oar rollack (plastic) that was riveted to the mast, vang held it in place and while it got chewed up in a season, could easily be replaced and was cheap. Problem here is that we have slip fit everything and you can't rivet into slip fittings....one way or the other even with this suggestion, you have to weld something
RG
Re: Kids F12 [Re: Wouter] #121584
11/08/07 08:31 AM
11/08/07 08:31 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
the first pics you got were indeed a scaled moth sail, but in case you hadn't noticed I redid everything for the pics that were posted, so thats irrelevant.
No its not an LR2, even an idiot can see that, but it does use a few tricks from that, but more so from my new F16...Oh and btw, the 3 LR2's were built at home, just by 2 skilled guys <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
While the round bilge version will take more time and probably a bit more skill it will win races (and there will be some over time) and it does look nicer.
As for building an F12 in 100 hours, your dreaming, for your average homebuilder (first time round) I'd say 400 hours was optimistic if not impossible (and in case you didn't know Ive built over 30 boats over time....and I think about 14 of those were wood) In case anyone wants to see what's inside a Paper Tiger go here.... http://www.bur.st/~h20melon/other/building/The%20Building%20of.pdf ... and then tell me if after you have looked at the pic without the deck whether your going to build that in a 100 hours. And thats just 1 hull <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
As for the draggyness of hard chined hulls...your comparison is invalid cause they weren't hard chined and a boat's performance is always (no exceptions) the sum of the drag angles (read Marchaj)...under no circumstances does drag make you more resistant to slip or improve your leeward angle.
RG
Re: Kids F12 [Re: JeffS] #121585
11/08/07 08:36 AM
11/08/07 08:36 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
The round bilge version would have to be done as a strip planked foam hull, then glassed and faired, in some ways quicker and in others slower, I'd guess that with 2 people a single cat this way is about 6 weeks work (500 hours approx) if your reasonably experienced. For a beginner I'd add another 200 hours.
RG
Re: Kids F12 [Re: Buccaneer] #121586
11/08/07 08:40 AM
11/08/07 08:40 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
Can change the profile to suit in a blink, and yes high AR tips can get ground down, but if they forget to lift them, you just have a longer chord to repair <grin>
RG
Re: Kids F12 [Re: RetiredGeek] #121587
11/08/07 08:52 AM
11/08/07 08:52 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
for those thinking of building, here's a good link on whats involved in building a Paper Tiger
http://building.papertigercatamaran.org/
Re: Kids F12 [Re: RetiredGeek] #121588
11/08/07 08:53 AM
11/08/07 08:53 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
Now for the good stuff....some decent renderings of the hard chined version
#1
Re: Kids F12 [Re: RetiredGeek] #121589
11/08/07 08:55 AM
11/08/07 08:55 AM
RG,
With all due respect from me as well, and heaps of appreciation for your participation and contributions.
Have you read all the previous posts begining with and including "Youth Recreation Trend" on the big forum from approximately one year ago?
While 100 hours may not be realistic for one amatuer on their first go, it should be an ideal, or easily attainable by a group of builders, i.e. a half dozen father/sons building a half dozen boats at the club over a weekend.
We've all let go of our "must haves" regarding catamarans (trapezes and the like) to strip ourselves down to #1) the mentality of child just learning to sail and about sailboats and #2) a parent who potentially is just learning to sail and about sailboats.
The daggerboards, and trunks, are a maintenance issue. A move in the wrong direction.
My two cents.
Thanks
Re: Kids F12 [Re: RetiredGeek] #121590
11/08/07 08:55 AM
11/08/07 08:55 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
hard chined #2
Re: Kids F12 [Re: RetiredGeek] #121591
11/08/07 08:55 AM
11/08/07 08:55 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
hard chined #3
Re: Kids F12 [Re: RetiredGeek] #121592
11/08/07 08:56 AM
11/08/07 08:56 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
hard chined #4
Re: Kids F12 [Re: RetiredGeek] #121593
11/08/07 08:57 AM
11/08/07 08:57 AM
NZ
RetiredGeek Offline
RetiredGeek  Offline
NZ
Now for the round bilge design
#1
0 registered members (), 1,496 guests, and 28 spiders.
