Nacra 5.2 Hulls #121822
10/31/07 07:43 AM
10/31/07 07:43 AM
College Station, Texas
chloemac00 Offline OP
I am going to have to repair some delaminatin on my '77 Nacra 5.2 starboard hull.
Can somebody pass on some good instruction as to how I would go about removing the decks.
What is the proper releasing agent to remove the decks?
My pride and joys and my daughter, Chloe and our Nacra 5.2!!!
Re: Nacra 5.2 Hulls [Re: chloemac00] #121823
10/31/07 08:07 AM
10/31/07 08:07 AM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Just recently this was discussed. Do a search on this site. There was some really good details.
Clayton
Re: Nacra 5.2 Hulls [Re: Clayton] #121824
10/31/07 09:11 AM
10/31/07 09:11 AM
Clayton: I have been searching this site and came up with no listings. Is there a specific word or phrase that I am missing that I should insert in the "search" box?
In Christ
George
Re: Nacra 5.2 Hulls [Re: chloemac00] #121825
10/31/07 09:40 AM
10/31/07 09:40 AM
release agent is a chisel lightly and slowly tapped with a hammer. With some patience, you should be able to remove the decks in one piece with very little damage.
Re: Nacra 5.2 Hulls [Re: Jake] #121826
10/31/07 11:00 AM
10/31/07 11:00 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
It was my thread, and it can't be more than 1-2 pages back.
Re: Nacra 5.2 Hulls [Re: gree2056] #121827
10/31/07 11:28 AM
10/31/07 11:28 AM
Rockledge Cay, FL
Fearless_Rider Offline
Rockledge Cay, FL
When removing the aft decks, I used a dremmel to cut lateral seams (port to starboard) before and aft of the dagger wells in the decks. This allowed the removal of a mojority of the aft decks without tearing up the dagger well structure. Once inside I added bulkheads in addition to repairing stringers. When repairs were complete, sand clean the over lapping edges of the decks and the hull lip. I used epoxy and a single layer of nondirection cloth between the decks and the hull lip with weights on top to squish it all together when curing.
BTW, my BBQ Rocks!
Re: Nacra 5.2 Hulls [Re: Fearless_Rider] #121828
10/31/07 11:31 AM
10/31/07 11:31 AM
"Formula 52!
ALL Adrenaline!
pure imagination. "
I like Helen better.
Re: Nacra 5.2 Hulls [Re: chloemac00] #121829
10/31/07 11:45 AM
10/31/07 11:45 AM
FYI - I saw a Nacra 5.2 on ebay in texas the other day. No mast but the hulls looked solid.
Re: Nacra 5.2 Hulls [Re: Jake] #121830
10/31/07 12:03 PM
10/31/07 12:03 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
NOOOOOO, don't tell people about that! I am looking to by it, because I just bought Airborne's old mast.
It is actually for a friend but we were thinking we might be able to get him in a boat cheap with it.
Re: Nacra 5.2 Hulls [Re: fin.] #121831
10/31/07 01:33 PM
10/31/07 01:33 PM
Rockledge Cay, FL
Rockledge Cay, FL
"Formula 52!
ALL Adrenaline!
pure imagination. "
Just for you...
BTW, my BBQ Rocks!
Re: Nacra 5.2 Hulls [Re: Fearless_Rider] #121832
11/01/07 12:47 AM
11/01/07 12:47 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
Hey Fearless,
what did you build your bulkheads out of?
Re: Nacra 5.2 Hulls [Re: chloemac00] #121833
11/01/07 06:05 AM
11/01/07 06:05 AM
dallas tx
airborne Offline
airborne  Offline
dallas tx
For some reason I could not reply to your PM. It would not let me post a reply.
I think gree answered your question.
airborne
nacra 5.2 #2410 live long and prosper
Re: Nacra 5.2 Hulls [Re: airborne] #121834
11/01/07 08:27 AM
11/01/07 08:27 AM
There was a 5.2 on craigslist two days ago, now I can't find it.
Re: Nacra 5.2 Hulls [Re: gree2056] #121835
11/01/07 08:30 AM
11/01/07 08:30 AM
Rockledge Cay, FL
Rockledge Cay, FL
Hey Fearless,
actually used the cheap "home depot" pink foam with Epoxy resin and several layers of cloth. Polyester resin wont work with the cheap foam as it will melt it into goo... First thing I did was create cardboard cutouts of the shape of the bulkheads by inserting in the hulls at the desired locations and trimming to fit. Then trace the cardboard onto the foam and cut the bulkhead shape. Layed up 2 layers of cloth and resin on wax paper, then the foam cutout over that, then 2 more layers of cloth and resin. One last layer of wax paper and some weight ontop to apply pressure when curing. Came out sweet, made 8 bulkheads (4 per hull) that way. 2 bulkheads for each of the forward hulls, 2 for each aft hull, immediately in front and behind the dagger wells.
BTW, my BBQ Rocks!
Re: Nacra 5.2 Hulls [Re: Fearless_Rider] #121836
11/01/07 09:01 AM
11/01/07 09:01 AM
Did you weigh the results?
Re: Nacra 5.2 Hulls [Re: fin.] #121837
11/01/07 10:55 AM
11/01/07 10:55 AM
Rockledge Cay, FL
Rockledge Cay, FL
I added 6 lbs per hull for all the bulkheads and many stringer repairs! The boat is significantly stiffer and Im not worried about the forward hulls twisting off during a hot spin reach!
BTW, my BBQ Rocks!
Re: Nacra 5.2 Hulls [Re: Fearless_Rider] #121838
11/01/07 11:05 AM
11/01/07 11:05 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
That is what I am going for, since i have added a spin to the boat and plan to keep her sailing for a while i just want to stiffen her up.
Re: Nacra 5.2 Hulls [Re: Fearless_Rider] #121839
11/01/07 11:05 AM
11/01/07 11:05 AM
That sounds like a rational trade to me. I think the obsession with minimum weight has gotten w-a-a-y out of hand.
Re: Nacra 5.2 Hulls [Re: fin.] #121840
11/01/07 11:58 AM
11/01/07 11:58 AM
TurboCat Offline
TurboCat  Offline
Hey Gree..
Did you see the link on TCDYC...Its not the best but gives you the idea. Be patient on the corners, be carefull and it will all work out.
1 registered members (nutsy), 297 guests, and 31 spiders.
