Page 2 of 4 1 2 3 4
Re: '87 nacra 5.7 [Re: AzCat] #123520
11/17/07 12:44 AM
11/17/07 12:44 AM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
I said rotate the crossbar brackets not the tiller arms. the set-up is the same.
maybe there are no 5.7 sailors responding because they haven't been able to turn their boats around.
Re: '87 nacra 5.7 [Re: hokie] #123521
11/17/07 01:03 AM
11/17/07 01:03 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
That must be it, the rudders on the 5.7 don't turn because Nacra knew once you got on it you would never want to turn back to the beach....reaching forever!
Re: '87 nacra 5.7 [Re: AzCat] #123522
11/17/07 01:41 AM
11/17/07 01:41 AM
japan
erice Offline
erice  Offline
japan
well someone's not getting it
have dug through my pics and this seems to be the best shot i have of the join that seem to be giving you the problems
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: '87 nacra 5.7 [Re: erice] #123523
11/17/07 02:19 AM
11/17/07 02:19 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
Eric, I have been drinking so I might be seeing things but looking at that it shouldnt turn....does the bar rotate upright? In that picture the "hinge" is 90 degrees off where it needs to be.
Re: '87 nacra 5.7 [Re: gree2056] #123524
11/17/07 02:23 AM
11/17/07 02:23 AM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
OH, and clean that boat up!!! I can see myself in the side on my 5.2, and it is older than yours. That boat is due a good cleaning and buffing with teflon wax.
Re: '87 nacra 5.7 [Re: gree2056] #123525
11/17/07 06:49 AM
11/17/07 06:49 AM
japan
erice Offline
erice  Offline
japan
that pic is from when i first got and assembled the boat
like azcat my rudders sometimes bind and as per my original post to this thread i tracked it to those "universals", as i called them, rotating into a binding position
when i feel them bind my solution has just been to twist the rudder extension which moves the joints out of the bound position and allows the rudders to turn
Rhino pointed out that murrays sold an updated part where the joints were fixed at a certain angle, presumably because many early nacras suffered this problem
my 5.2 is now in parts out at the lake but next spring when i put it back together i will be experimenting with ways to fix those joints at the correct angle to stop the rotation and binding
OK, now about my scruffy hulls, attached is what they looked like when the boat was first offered to me!. the rudder shot is after basic scrub down. since then i've spent a few hours sanding and using compound to get the hulls looking like gelcoat again. now the boats in bits for winter i can proceed with a bottom job and then start on my planned graphics job
http://www.catsailor.com/bb_files/119481-hullscoolcatbluebigtilt.jpg
eric e
2009 weta tri - 294
Re: '87 nacra 5.7 [Re: AzCat] #123526
11/17/07 07:46 AM
11/17/07 07:46 AM
Largo, Florida
papayamon2 Offline
papayamon2  Offline
Largo, Florida
Hi Azcat, just a word from someone else who is toward the newbie end compared to most of the guys on this forum. I've found them to be extremely helpful, but it does help if you post a pic or two (as someone suggested) so that everyone can see your exact issue. In the meantime, I've found that the regular posters usually do see the picture and are aware of the various differences (or similarities) in models more than I am. But post a pic of that rudder joint if need be!
Re: '87 nacra 5.7 [Re: papayamon2] #123527
11/17/07 12:47 PM
11/17/07 12:47 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
Eric, I think to redeem yourself you will have to show us a picture of the boat once she is cleaned up.
Azcat, give us a picture to see and when can help alot more just like papyamon2 said.
ALso for some more forum advice....if you ever see that my post was after 2am, ignore it! The odds of it making any sense or being relevant are slim.
Re: '87 nacra 5.7 [Re: Rhino1302] #123528
11/17/07 10:24 PM
11/17/07 10:24 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Here are some pics
Re: '87 nacra 5.7 [Re: AzCat] #123529
11/17/07 10:35 PM
11/17/07 10:35 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
to port
Re: '87 nacra 5.7 [Re: AzCat] #123530
11/17/07 10:37 PM
11/17/07 10:37 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
to center
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: '87 nacra 5.7 [Re: AzCat] #123531
11/17/07 10:38 PM
11/17/07 10:38 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
to center close up
Re: '87 nacra 5.7 [Re: AzCat] #123532
11/17/07 10:39 PM
11/17/07 10:39 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
to starboard
Re: '87 nacra 5.7 [Re: AzCat] #123533
11/17/07 10:40 PM
11/17/07 10:40 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
to stbd closeup
Re: '87 nacra 5.7 [Re: AzCat] #123534
11/17/07 10:42 PM
11/17/07 10:42 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
from the rear you can se how much angle the crossbar would need in order not to bind.
To port
Re: '87 nacra 5.7 [Re: AzCat] #123535
11/17/07 10:47 PM
11/17/07 10:47 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
in each of the pics the crossbar is being held paralell to the rear main beam
to center
Re: '87 nacra 5.7 [Re: AzCat] #123536
11/17/07 10:48 PM
11/17/07 10:48 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
from the rear, to stbd.
Re: '87 nacra 5.7 [Re: AzCat] #123537
11/17/07 11:15 PM
11/17/07 11:15 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
These pics should give a pretty good idea of what's happening.
When the crossbar is hooked up, it is very limited in the amount it can be turned to either side
It makes the tiller stay centered when released.almost like it's spring loaded.
If left like it is, it would eventually distort the holes in the tiller arms.
even if I force the tiller to the side very hard, the rudders will not go even half way to there full turn position.
It seems to me that the tiller should be able to be turned all the way from full port to full stbd. without binding.
There is only 6" of tiller travel before it begins to bind. this travel is only allowed by the slop between the attachment pins,the attachment holes in the tiller arms, and the same in the crossbar.
Note that the tiller crossbar is not being held in the raised or lowered positions, but is bound there by the angle of the tiller arm in relation to it.
I dont think that its a good idea for the tiller to self center. if the boat were to find itself sailing solo, It would potentially go in a pretty straight line, pretty fast.
And i'm not a strong enough swimmer to catch a cat straight up.
All you vets, dont be afraid to chirp in.
By the way, how long do I retain the title of newbie.
Re: '87 nacra 5.7 [Re: AzCat] #123538
11/17/07 11:25 PM
11/17/07 11:25 PM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
have you tried flipping the brackets around?
The bracket should pivot on the crossbar, not on the tiller. I could be wrong though, I'm still a newbie too!
Re: '87 nacra 5.7 [Re: hokie] #123539
11/17/07 11:32 PM
11/17/07 11:32 PM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
The crossbar would not be long enough to do that. Even so, it ould only bind in a different place.I talked to the original owner today, and he said that this is the way he bought it new 20 yrs ago. he also said it turned on a dime. I dont think he has sailed a boat with unrestricted tiller travel though.
Page 2 of 4 1 2 3 4
1 registered members (nutsy), 297 guests, and 31 spiders.
