Rating: 5
Page 7 of 7 1 2 3 4 5 6 7
Re: This one is for the kids. [Re: Wouter] #124876
11/30/07 05:10 PM
11/30/07 05:10 PM
japan
erice Offline
erice  Offline
japan
wouter, you're not hijacking someone else's thread are you?
we all occasionally do it but try not to take it over and then poison it
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: This one is for the kids. [Re: erice] #124877
11/30/07 10:09 PM
11/30/07 10:09 PM
You are right.
I'll shut up now.
Re: This one is for the kids. [Re: Mary] #124878
12/01/07 07:49 AM
12/01/07 07:49 AM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Lets be clear its not Phil v the rest of the world. My efforts on this project are directed firmly on the under 12 and always have been as I agree with Phil as this is the market that needs addressing.
Gareth
YES!! <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Since there's agreement that a cat under 12 ft is not viable at all, a compromise is possible with a single platform and two sail plans:
a) School - kids under 12, single handed.
b) Standard - kids over 12, singlehanded and kids under 12, doublehanded.
An oversized sail plan for adults is also possible. It could require structural reinforcements adding some weight and longevity, which is probably an acceptable compromise as well.
I believe this is already compatible with the F12 project. What about the Blade 12? Can it be done?
Luiz
Re: This one is for the kids. [Re: Vinny_M] #124879
12/02/07 01:33 AM
12/02/07 01:33 AM
Arizona
AzCat Offline
AzCat  Offline
Arizona
"It appeared as though the tiller arms were longer, and the tiller crossbar simply was in front of the traveler tack with the tiller extension attached."
That's how the SolCat 18 is set up.
I like the way it works except it has to miss the rear stays, the crew, controll lines and hiking straps. I got used to it pretty quick.
It looks like a lot of these challenges would be irrelevent on this configuration.
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
0 registered members (), 967 guests, and 34 spiders.
