Dave,
I agree with Jake, sand it off.
To get it to look shiny, 2 part poly clear coat, I like the water based System Three LPU. Doesnt smell, you can work with it inside without killing yourself.
It doesnt last as long as the solvent based poly, but its so easy to redo, that you just hit the area with some 100 grit and put on more clear coat if it needs a touch up. Foam brushes can be tossed when you are done, or regular brushes clean up with water.
I've done all my carbon parts with it, masts, beams, spin poles, booms. Every couple of years I rough up the spots that need touch up and reapply more poly.
Bill
