| Re: Home building a mast..
[Re: valtteri]
#134227 03/05/08 05:15 AM 03/05/08 05:15 AM |
Posts: 9,582 North-West Europe | Let's continue this when I have properly measured the mast when I have access to better scales in few months.
Yes, please. Again, I really want to find out what happened here as I may well have access to adressing the cause of this issue if indeed it is related to the production of the mast section. It is a serious possibility that a new F16 alu mast design and new die will be made then. Wouter
[Re: Gato]
#134228 03/05/08 05:21 AM 03/05/08 05:21 AM |
Posts: 9,582 North-West Europe | Gato http://www.formula16.org/content/view/13/36/lang,en/ 1.4.5 The weight that is measured at the mainsail hoist height of a mast lying perfectly horizontal with its base supported at the bottom edge of the mast section is referred to as the "mast tip weight". The minimum mast tip weight of a fully fitted mast, excluding standing rigging, is set at 6.00 kg for reasons of seaworthiness and to guarantee fair racing. Standing rigging is defined as sides stays and forestay. All the rest remains on the mast, that includes for example shackles used to secure the stays to the hound fitting. 7.17 Standing rigging All the stays connected to the mast, excluding the diamond wires. Just as additional data; ISAF certified measurer has measured 7.8 - 8.2 kg tipweights on alu superwing F16 masts. Carbon masts typically are down to what is minimally allowed 6.0 kg although exceptions to this rule of thumb have been measured. Taper won't help you much in the weight department, it can help in the way of sail shape control in thetop of hte mainsail however. Wouter
[Re: Stewart]
#134232 03/05/08 12:19 PM 03/05/08 12:19 PM |
Posts: 548 MERRITTISLAND, FL | I also can't recall where I last saw the ultrathin aero-grade ply.. Think it was at the local hobby shop.. Used for model gliders and planes..But the issue will be scarfing 1 mm thick ply!! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> That sounds like an ungodly amount of work to do right. When you are all done the you have 1 mast that in all likely hood is not quite what you really want. Why not build a gypsum/screed mold and lay up a traditional full carbon stick? The process for the mold is very simple to do at home and could be used for several attemps to dial things in. The actual mast build process is fairly straight forward as well. The biggest A class mast builders do not use autoclaves, even though ideally they should produce a slightly better finished product. | | | Re: Home building a mast..
[Re: scooby_simon]
#134235 03/05/08 04:20 PM 03/05/08 04:20 PM | Anonymous
| Anonymous
Unregistered | Could one of the people who know, Phill, Wouter etc. Please post the moments of inertia for the "superwing" so I don't have to start from scratch if I develop a laminate spec for Gato. | | | Re: Home building a mast..
[Re: ]
#134236 03/05/08 07:20 PM 03/05/08 07:20 PM |
Joined: Oct 2005 Posts: 951 Brisbane, Queensland, Australi... ncik
Posts: 951 Brisbane, Queensland, Australi... | http://www.composites.com.au/there are some wing mast section properties in their products section...the AC145W is the A-class one (60 x 145 mm, 167 x 37.5 cm^4 (although they have an equivalent aluminium second moment of area value too?)). Weight of 1.29kg/m. Although not of the same scale, during my model multihull building phase a few years ago, I built some very simple carbon wing masts of up to 1.8m (about an inch of chord length). They were great! Extremely stiff and easy to build, not to mention more durable than the equivalent aluminium ones. They were a similar weight. It's good to see ppl willing to try building their own carbon masts. I may be convinced to give it a go sometime (just sketching up some ideas now). | | | Re: Home building a mast..
[Re: ncik]
#134237 03/09/08 12:15 AM 03/09/08 12:15 AM | Anonymous
| Anonymous
Unregistered | A thought just came to mind while designing Gato's mast. When the "tip weight" criteria was added to the mast rule what calculations were done in determining a suitable number? The reason I ask is concentrated point loads can have a big effect on the mast's dynamic behavior. | | |
280
guests, and 32
