by Karl_Brogger. 12/29/24 05:14 PM
Re: Outboard motor for cat [Re: igorn] #140335
04/18/08 06:03 AM
04/18/08 06:03 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Igor,
let us know how the electric motor works if you get one. I understand what you're trying to do.
We go out to a barrier beach/island in the summer and the powerboats can come and go as they please without a care for the wind, or tide. I'm always watching the wind, timing the tide, keeping an eye out for fog, sometimes I start thinking, "maybe a powerboat would be easier." But that thought is like gas, it passes and you feel better. I love not having to gas up my boat, and being free from the noise and actually having to think about getting from point a to point b instead of just pointing it and pushing a throttle.
Bill
Re: Outboard motor for cat [Re: warbird] #140336
04/18/08 06:03 AM
04/18/08 06:03 AM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
thank you all , last q: did you use any kind of safty line(rope) for kids ?
Re: Outboard motor for cat [Re: igorn] #140337
04/18/08 06:45 AM
04/18/08 06:45 AM
igorn,
The only thing I worry about with an outboard on the back of a catamaran is that if you have small children on board, you have to make sure that when the outboard is running, you do not let the children sit on the bows or hang over the front beam, because if, God forbid, somebody fell in the water between the hulls, they might get ground up by the propeller.
My golden retriever is a little clutzy, and I had him out on my Wave one day, and he fell off over the front beam between the hulls, and, as I passed over him, I grabbed his neck and pulled him back up onto the boat. It might have been a bad ending if I had been running an outboard motor and not been able to shut it off quickly enough. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
This applies to adults, too, for that matter.
Re: Outboard motor for cat [Re: igorn] #140338
04/18/08 07:05 AM
04/18/08 07:05 AM
Interesting question. If you are sailing, I would say NO, because if the boat capsizes, you do not want the child to be trapped under the boat by his tether line -- better for him to be thrown clear. (He is wearing a good life jacket, of course.)
If sails are down and there is no chance of capsize, and you are using an outboard motor, I would say it depends on how well the child obeys you as to where to sit on the boat. For a very young and active child, I would say you could use a tether from the center of the tramp that only allows him to roam to the edges and not enough to actually fall overboard -- same as what I would do with my dog in that situation.
If you put a long tether line, and the child falls overboard, even off the outside of the hull, there is a good chance that the line itself will get caught in the prop.
Re: Outboard motor for cat [Re: warbird] #140339
04/18/08 07:30 AM
04/18/08 07:30 AM
BTW. I would not want the hassle of batteries out in the wet.
You don't use a battery with a little, hand-pull outboard motor, do you?
Re: Outboard motor for cat [Re: warbird] #140340
04/18/08 07:32 AM
04/18/08 07:32 AM
dstgean Offline
dstgean  Offline
I would also call your attention to this attachment. Check in front of the port main beam.
That is a hatch cover...hinged..part of the boat. About the size of an average chilly bin.
This boat went like stink on a reach and was good enough on all points of sail yet it had heaps of buoyancy and easy storage etc etc.
The fact is we don't give enough though to multi-use in cats.
Good point. I like sailing fast and flying hulls, but I like to camp cruise and having a boat with the hatches and bulkheads of a kayak, integrated tent options, higher freeboard and so forth would be cool. the H 21SC comes close and I see the prices have finally started to come down. In the meantime I'm going to be using my H 18 but would love suggestions on how to imporve the boat for those uses.
I was thinking of adding a reef point possibly and figuring out better ways to use the hulls for storage than the 5" access hatch.
Ideas?
Dan
Re: Outboard motor for cat [Re: Mary] #140341
04/18/08 08:31 AM
04/18/08 08:31 AM
I GOT IT!!! THIS IS WHAT YOU NEED!!!!
Safe for the kids... helps if you run out of air!
Re: Outboard motor for cat [Re: ] #140342
04/18/08 09:06 AM
04/18/08 09:06 AM
dstgean Offline
dstgean  Offline
You could even use the little bike attachment for letting the little rug rats help.
It is interesting how versatile kayaks have become such versatile craft for daytripping, surfing, camping, photography, etc. Most cats are really single focused though. Racing cats should be single focused as that helps make them fast, but recreational designs should have some hatches, bulkheads to prevent flooding hulls, reefing options, and tent options that would make the hordes of kayakers green with envy. And all in a superior watercraft in most ways....
Dan
Re: Outboard motor for cat [Re: dstgean] #140343
04/18/08 09:23 AM
04/18/08 09:23 AM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
<img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> i know is odd to put motor on it , but is "THE only" boat i have and on vacations must be in use for all. i also found a tend that is selfmaking-you throw it and it pop up by it self, very useful for a couple of days trip( can sleep on cat) and a net at the front of the mast to make it biger
i call it fx adventure ( not very original)
<img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
mary ,thanks
Re: Outboard motor for cat [Re: igorn] #140344
04/18/08 10:40 PM
04/18/08 10:40 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I had a the 2hp 4 stroke Honda on the SC20, and it would push the boat 6 kts in flat water. I fabricated a mounting bracket that allowed the lower unit to be almost parallel to the tramp when raised. This worked well when sailing in up to about 12 kts of wind, but above that we started bashing thru the waves and it started to exert big forces on the motorandm mount. It was also difficult to motor in chop, because the pitching either pulls the prop out of the water or threatens to swamp the power head. On big air days I'd remove the motor and mount entirely and rely on the paddle if it shut off, which was substantially less likely than on the light air days.
I also had a lightweight, older two stroke Evinrude 2 hp on a Hobie 18 Magnum. It also did fine on flat water, but was a hindrance when waves developed. And 30 to 35 lbs hung off the rear beam of any cat encourages stern drag, which always needs to be compensated by moving crew weight forward. If you've got 2 adults and kids and a motor on a beach cat, you're pushing it pretty deep into the water. Avoid strong winds in these circumstances. Good luck!
Dave
Re: Outboard motor for cat [Re: davefarmer] #140345
04/19/08 03:08 AM
04/19/08 03:08 AM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
thanks for sharing. do you have long or short leg on motor?
and the motor where did you mont it , on center or near hull?
and 6 kts is very goood speed i wast thinking that 2hp motor is soo fast. how much time or miles do can you go with one tank ~ 1liter?
i found out that for same price 850€ there is a 3,5 HP motor, perhaps aditional HP would be useful or just consume more gas?
thanks for ans.
igor
another Q <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> :i was thinking to order smaler main sail for winds 20+ to depower the cat and make it more controlabile
how small shuld it be? original is ~16 m2. any idea what i can use for batens?
ps: dont be <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" /> at me, i like customize things <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
last year i made rigting pole and i must say that is working <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Outboard motor for cat [Re: igorn] #140346
04/19/08 08:19 AM
04/19/08 08:19 AM
FL
sail7seas Offline
sail7seas  Offline
FL
Perhaps a revised Hobie MirageDrive could be modified to put down a dagger board well?
http://www.hobiecat.com/kayaking/miragedrive.html
Re: Outboard motor for cat [Re: sail7seas] #140347
04/19/08 08:31 AM
04/19/08 08:31 AM
That's a great idea. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: Outboard motor for cat [Re: igorn] #140348
04/19/08 11:08 AM
04/19/08 11:08 AM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I've only used short shafts, long woud do a better job of keeping the prop in the water, and the head out of it. But they're harder to find, heavier and a biat harder to get completely clear of the water when sailing. I probably used one tank of gas(1 quart, internal) for the whole season., as I never had far to go to get to wind, or back home. I'd counsel against bigger motors, weight is your enemy on a small cat.
dave
Re: Outboard motor for cat [Re: davefarmer] #140349
04/20/08 03:40 PM
04/20/08 03:40 PM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
thanks dave, the diference in weight bitwin the 2,5 and 3,5 hp motors is 2kg.
it will be 2,5HP yamaha with long shaft.
thank you all
Re: Outboard motor for cat [Re: igorn] #140350
04/21/08 08:00 AM
04/21/08 08:00 AM
dstgean Offline
dstgean  Offline
I've got a cheata motor mount and a older merc 2. it does add weight in the worst possible location and the mount does throw a lot of spray all over the motor when sailing in any sort of wind. Moreover, we had a hard time getting it started when we needed it--probably user error on our part--but that's something to consider. I'll keep working on it to get it working better though for all the reasons mentioned.
Dan
Re: Outboard motor for cat [Re: igorn] #140351
04/21/08 01:39 PM
04/21/08 01:39 PM
C
carlm Offline
carlm  Offline
C
Jack Hoying adds a motor mount to his beachcat.
12 lb cruise n carry on a prindle
on the beachcats technical
suprised no one mentioned this
<img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
Carl
Re: Outboard motor for cat [Re: carlm] #140352
04/22/08 07:46 AM
04/22/08 07:46 AM
Slovenia
I
igorn Offline OP
igorn  Offline OP
I
Slovenia
Carl , i cant thank you enought
Re: Outboard motor for cat [Re: igorn] #140353
04/22/08 10:07 AM
04/22/08 10:07 AM
C
carlm Offline
carlm  Offline
C
you're welcome...but,
the cruise n carry as far as I know is out of production
I'll search ebay for you..I purchased one off of ebay for around 300.00 US dollars.
also check out Nautic 2.5 outboard ...google it
Carl
Re: Outboard motor for cat [Re: carlm] #140354
04/22/08 12:13 PM
04/22/08 12:13 PM
US Western Continental Shelf
hobiegary Offline
hobiegary  Offline
I've used the cruise N carry on many occasions and love them when they run. Unfortunately, they are no good in salt water environments; too many fasteners and other parts that are not built from stainless steel.
I use a standard shaft Honda 2hp on a Cheetah bracket on a Mystere 6.0 in seas that reach as much as 12 feet at times. Works great as long as I'm not trying to use the motor while the wind is blowing. When the motor is in the raised position it rarely if ever, takes a direct hit from the seas. It does get plenty of spray!
The motor is tilted on it's own pivot bracket. At the same time, the Cheetah bracket is in its lifted position.
This pictures was taken while surfing down a 6-foot wave at Channel Islands National Park.
GARY
Santa Monica Bay
0 registered members (), 141 guests, and 73 spiders.
Posts267,059
