The sail fairy visited #146070
06/17/08 05:30 PM
06/17/08 05:30 PM
scooby_simon Offline OP
And brought me something...
Hopefully get some pics up the mast this weekend before I take the boat to bits for the Rutland open.
Will also put the old and new sail beside each other when I bring the boat home.
Ready for the Mumbles Global Challenge ? [Re: scooby_simon] #146071
06/17/08 05:55 PM
06/17/08 05:55 PM
Ready for the Mumbles Global Challenge now, are you not ? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Re: Ready for the Mumbles Global Challenge ? [Re: Wouter] #146072
06/17/08 06:05 PM
06/17/08 06:05 PM
Nope; Need to settle the above sail; re-work "default" settings, learn what it does differently to the other sail. Oh, and try and sail the boat a few times between now and then. Re-rig the downhaul; change Spi pole settings (nothing to do with the mainsail); re-fair my daggerboards; fix a couple of spare rudder blades and make some new trap lines.
And get a shed load of "proper" work done as well.... <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Re: Ready for the Mumbles Global Challenge ? [Re: scooby_simon] #146073
06/17/08 06:49 PM
06/17/08 06:49 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Using the soccer ball as a scale, you must have the worlds biggest F-16, and some REALLY big kids to fit in that swing set <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Re: The sail fairy visited [Re: scooby_simon] #146074
06/17/08 08:19 PM
06/17/08 08:19 PM
Nice! New sails are cool.
They don't look that expensive laying on the lawn though do they? Don't look all that complicated either. amazing transformation when it is put up a mast
Re: The sail fairy visited [Re: scooby_simon] #146075
06/18/08 05:27 PM
06/18/08 05:27 PM
Marcus F16 Offline
Marcus F16  Offline
The sail looks reasonably flat.......Why, becuase it sits really flush on the ground & the luff has not pushed out much.? Just an observation. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
Intersted to see some pics of the new rags up on your rig.!
Marcus Towell
Re: The sail fairy visited [Re: Marcus F16] #146076
06/18/08 05:32 PM
06/18/08 05:32 PM
Yes I'd say it is farly flat; difficult to really say on the grass; Battens have not been tightend yet as the sail has niot been up the mast yet - hopefully have pictures on Sunday.
Re: The sail fairy visited [Re: scooby_simon] #146077
06/22/08 12:08 PM
06/22/08 12:08 PM
Sorry, no pics of it up the stick as is was windy with a capital F
Boat blew down the field when just on its trolly and I had to pull the mast down when I was de-rigging.
Some fools went sailing...
3 Lasers went out and came back again.
1 Flying 15 went out - broken mast
1 29er went out - broken mast
1 Dart 16 went out - pitchpoled after about 15 mins
1 Hobie 18 went out - caspized within about 200 yds of the beach.
Re: The sail fairy visited [Re: scooby_simon] #146078
06/22/08 01:19 PM
06/22/08 01:19 PM
Yep, we got the same wind overhere too and I'm already thinking about getting my high wind landyacht out of storage !
With these conditions for a couple of days the beach becomes very hard and flat, like a proper speedway !
Re: The sail fairy visited [Re: Wouter] #146079
06/22/08 01:40 PM
06/22/08 01:40 PM
I was out racing this weekend at the coast (scheveningen).
Saturday we had very little wind (+/-5kts), where today we started the first race in the morning with 15-20kts and finished it in about 20-25 (28+ in gusts).
We didn't do the 2nd race but from the beach I saw even the best sailors capsize sooner or later.
Re: The sail fairy visited [Re: Tony_F18] #146080
06/29/08 12:24 PM
06/29/08 12:24 PM
sailed it for about an hour over the weekend at Rutland (Put hole in Spi on the 2nd lap of the first race and by the time I'd fixed it the 3rd race had started; Woke up this morning feeling awful and could not cope with yotting)
Anyway, now have some pictures of the sail up the stick and new Downhaul set up (16:1)
Full sail shape
Nice and flat:
Mast bends a lot with loads of DH on !
And you can see the block attached to the sail
and now the Downhaul:
[img]http://www.catsailor.com/bb_files/149788-downhaul2.jpg[/img]
The DH is very powerful I can get it all the way down with one hand with ease!
All I did was attach some 4mm D12 to the top of the double blocks each side and then put a loop in the other end so It can pass thru the block on the sail to a bobble at the base of the mast.
Re: The sail fairy visited [Re: scooby_simon] #146081
06/29/08 01:56 PM
06/29/08 01:56 PM
That mainsail looks pretty sharp Simon! I like it a lot. Looks like Grant have a good design going. How does it feel when sailing? Looks like the leech could use a few short battens at the egde to stop flutter?
Re: The sail fairy visited [Re: Rolf_Nilsen] #146082
06/29/08 02:26 PM
06/29/08 02:26 PM
Thanks, yes it came out well.
As for the leach, my other sails have done the same. It's a function of loads of DH and mast bend. More battens might help reduce flutter but we'll see; I was sailing in a gusty F4 and there was a bit of flutter...
I think I'll be moving to the "Fat boys" setting on the spreaders to get more power in the light stuff as the downhaul is more than up to the Job.
Re: The sail fairy visited [Re: scooby_simon] #146083
06/29/08 02:32 PM
06/29/08 02:32 PM
It was the same with our mainsails. Once you added some real downhaul the leech had some small flutter. I think some 10-15cm battens taped to sail would have helped us. Just like we used to do with the overlapping Tornado jibs.
How did the sail feel? Going forward and accelerating in gusts?
Re: The sail fairy visited [Re: Rolf_Nilsen] #146084
06/29/08 03:10 PM
06/29/08 03:10 PM
Felt good upwind but needs more time for me to work out what exactly to do with it.
Downwind I was too busy keeping the boat upright to look at the mainsail much.
Re: The sail fairy visited [Re: scooby_simon] #146085
06/29/08 03:37 PM
06/29/08 03:37 PM
I must say that I am fascinated by your use of the stopper ball for the downhaul. I really like that. even without a cascading system like you have it would come in very handy to just run the downhaul through the block on the sail.. provided it is loaded enough all the time so that it doesn't come out.
Re: The sail fairy visited [Re: scooby_simon] #146086
06/29/08 05:41 PM
06/29/08 05:41 PM
Marcus F16 Offline
Marcus F16  Offline
Simon in this photo there is no leech pressure....ie///the sail is tight between the hound & the clew.
Out of curiousity how much do you weigh.? <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Marcus Towell
Re: The sail fairy visited [Re: Marcus F16] #146087
06/30/08 02:53 PM
06/30/08 02:53 PM
That was not taken while sailing; but in the bigger gusts on the lake it did not look much different!
Thinking about this a little more I think I will have to be carefull not to over-downhaul the sail with such an efficient system in place.
I'm about 75kg in by birthday suit and would like to be a little lighter; but work and injuries keep getting in the way of sailing and training.
Re: The sail fairy visited [Re: scooby_simon] #146088
06/30/08 07:10 PM
06/30/08 07:10 PM
Oxford, UK
pdwarren Offline
pdwarren  Offline
Oxford, UK
We wondered where you'd got to. You missed a good day's racing.
After a pretty frustrating day on Saturday when we weren't anywhere near the groove, let alone in it, we started off much better on Sunday. I think a few beers and 10 hour's sleep might have had something to do with it... We started to give the Spitfires some trouble - on the water, if not on handicap - and managed 2nd in race 4. We were doing OK in race 5 when we suffered a "minor" technical fault and had to get towed in. Let's just say that there was one less thing to do before putting the boat on the trailer.
Despite the technical problems we had a great weekend, and it was good to get back up to Rutland - a very nice spot to sail.
Re: The sail fairy visited [Re: pdwarren] #146089
07/01/08 10:28 AM
07/01/08 10:28 AM
Mark P Offline
Mark P  Offline
I bet this small technical problem was a result of the helm not doing something one ought to..... Had it been the crews fault or just general gear fatigue I'm sure even positive that we would have had the full low down!!
Would this problem have occurred if some electrical tape had been adopted? (you may answer yes or no)
Did it involve something 8.5m long? <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
MP*MULTIHULLS
1 registered members (nutsy), 320 guests, and 33 spiders.
