| mainsheet #148015 07/03/08 08:35 PM 07/03/08 08:35 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen OP
Posts: 1,037 Central California | What would any of you recommend for a new mainsheet?
| | | Re: mainsheet
[Re: ejpoulsen]
#148016 07/03/08 08:55 PM 07/03/08 08:55 PM |
Posts: 3,293 Long Beach, California | Trey Brown. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
| | | Re: mainsheet
[Re: _flatlander_]
#148018 07/04/08 06:40 AM 07/04/08 06:40 AM |
Posts: 93 virginia beach, VA | Salsa, been two years now on the H16, Rick's right, great stuff. just don't forget the chips <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Jason DiPietro
supercat 19
| | | Re: mainsheet
[Re: ejpoulsen]
#148020 07/04/08 09:47 AM 07/04/08 09:47 AM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I can sell 8mm Maffioli Evolution Swiftcord at £3.50/m converting to $6.94 Thats a really competitve price here in the UK as it normally retails at around the £4.15 mark. How does that compare to your US prices? MP*MULTIHULLS | | | Re: mainsheet
[Re: H17cat]
#148024 07/05/08 11:56 PM 07/05/08 11:56 PM |
Posts: 1,037 Central California | Thanks for all the input so far.
I like the looks of several material mentioned and I'll need to handle them to decide.
What about diameter?
3/8" or 5/16"? 8mm or 9mm?
| | | Re: mainsheet
[Re: ejpoulsen]
#148025 07/06/08 01:18 AM 07/06/08 01:18 AM |
Posts: 571 Hamburg | Hi all,
is there any rational reason, why a main sheet should contain dyneema?. On large boats with winches I understand it, but on a beach cat... Diameter would be around 8mm or more and you will not pull with more than 50kg on it, which is 1/30 of the breaking load of a simple polyester 8m sheet. Stretch would be about 8%*1/30 = nothing, you will sail it anyway from the hand and not cleated... So why dyneema <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> I use simple plain 8m polyester, it doesn't kink, holds in the cleat and on the ratchet, but it doesn't look Gucci.
What about the spi sheet? Here I looked around for the lightest stuff for 8mm diameter and not water absorbing. I found 8mm life line (the yellow - red stuff), easy to splice, light and with 0.70€/m also cheap.
Is there any other property of dyneema (other than strngth and low stretch)?
Cheers,
Klaus | | | Re: mainsheet
[Re: Smiths_Cat]
#148026 07/06/08 05:16 AM 07/06/08 05:16 AM |
Posts: 1,884 Detroit, MI | Is there any other property of dyneema (other than strngth and low stretch)? Light weight, low water absorbancy. Polyester soaks up water like a sponge. | | | Re: mainsheet
[Re: Smiths_Cat]
#148027 07/06/08 05:29 AM 07/06/08 05:29 AM |
Posts: 586 Hobart, Tasmania, Oz. | Hi all,
Cheers,
Klaus Bear in mind most mainsheets are 8:1 or even 10:1 so your 50 kilo's now equals 400-500kilo's. On a two man boat where the crew has 2 hands to use (and legs), you may see more like 100x8 kilo's!
| | | Re: mainsheet
[Re: H17cat]
#148028 07/06/08 06:31 AM 07/06/08 06:31 AM |
Posts: 3,355 Key Largo, FL and Put-in-Bay, ... | Switched to 5/16" Salsa on my H-17. Works great, after two regattas. West Marine, about $1.00 ft.
Caleb Ouch! West Marine? What about www.OnLineMarineStore.com right here on this site? As for size, since Salsa is so easy on the hands I use 1/4" (6mm) on the Wave and F16.., really runs through the blocks easy. I would never go to 3/8" though, Rick | | | Re: mainsheet
[Re: H17cat]
#148033 07/06/08 06:57 PM 07/06/08 06:57 PM |
Posts: 586 Hobart, Tasmania, Oz. | My Bad. Its a distrubuted load, there may be 400 kilo's of load on the rope, but its shared by 8 peices of rope. The biggest selling point for me, as rick has pointed out is the texture. can anyone bring up http://www.onlinemarinestore.com/ for me its a dead stick.
| | | Re: mainsheet
[Re: mbounds]
#148034 07/08/08 10:21 AM 07/08/08 10:21 AM |
Posts: 3,969 | Salsa on the H-17 Bzzz on the H-16 Swiftcord on the Tiger Marstron on the H-14
I like the Salsa best - after it's broken in a bit (too slippery when new)
Bzzz is a close 2nd.
Swiftcord is nice, but $$$ and it wears too fast.
Marstron is cheap, hard on the hands and wears out way too fast. Hey Matt, Can you elaborate on the differences that make one line better for one boat model than another? Mike | | |
192
guests, and 14
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
