| Re: sshhh
[Re: Gato]
#151844 08/20/08 09:27 PM 08/20/08 09:27 PM | Anonymous
| Anonymous
Unregistered | Try brushing on a layer and letting it kick before putting on the actual laminate. Or wetout and squeeggee your cloth off the part and then lay it on, the foam shouldn't wick resin out of the glass if you have the right amount there.
Do you know how much resin you used on the DS? | | | Re: sshhh
[Re: Gato]
#151849 08/25/08 11:02 AM 08/25/08 11:02 AM |
Joined: Oct 2007 Posts: 199 Constanta, Romania isvflorin
Posts: 199 Constanta, Romania | Gato, do you ever sleep ? <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> As this is actually a retorical question, judging by your activity - then the most interesting question is: how do you do it ? Now seriously, great work !!!
How do you find working with foam compared to wood/plywood ?
Florin
| | | Re: sshhh
[Re: Gato]
#151856 09/01/08 03:10 PM 09/01/08 03:10 PM |
Posts: 1,307 Asuncion, Paraguay | Don’t know if I shall recommend the way I joined the halves, at least not before I have smashed the cat into a big wave... The good way is with flanges, but I wanted to go fast... Usually the worst loads are beaching and trailing, not necessarily sailing.
Luiz
441
guests, and 10
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
