1975 hobie 16 trapeze setup #151892
08/07/08 01:19 PM
08/07/08 01:19 PM
C
CanadianCat Offline OP
C
I have a 1975 hobie 16 and I'm installing the trapeze rigging. I need to know if, on the older models, the trapeze wires attach to the same D ring as the forestay and shrouds? All the diagrams I've seen have seem to have two rings but my mast seem to only have the hole for one.
Re: 1975 hobie 16 trapeze setup [Re: CanadianCat] #151893
08/07/08 06:55 PM
08/07/08 06:55 PM
The mast tang (hound) was changed sometime after '75 to the current with an extra hole above to attach a shackle for double trapeze wires.
One set (single) of trapeze wires will work with your set up. You can hang a smaller shackle, on each side, if you are installing a double trapeze.
Re: 1975 hobie 16 trapeze setup [Re: _flatlander_] #151894
08/08/08 10:24 AM
08/08/08 10:24 AM
C
C
Thanks that's what I needed to know
Re: 1975 hobie 16 trapeze setup [Re: CanadianCat] #151895
08/17/08 12:30 PM
08/17/08 12:30 PM
Phoenix, AZ
Cousin_Eddy Offline
Cousin_Eddy  Offline
Phoenix, AZ
How do you attach the smaller shackle? Drill thru the mast and use a thru bolt?
Re: 1975 hobie 16 trapeze setup [Re: Cousin_Eddy] #151896
08/18/08 08:40 PM
08/18/08 08:40 PM
Oklahoma, USA
H
hobieokc Offline
hobieokc  Offline
H
Oklahoma, USA
flatlander is referring to hanging the smaller shackles on either side of the main shackle that attaches the forestay and shrouds.
Re: 1975 hobie 16 trapeze setup [Re: CanadianCat] #151897
08/18/08 10:08 PM
08/18/08 10:08 PM
Albuquerque NM
Banzilla Offline
Banzilla  Offline
Albuquerque NM
[b] Sail Like you have a Pair
0 registered members (), 534 guests, and 34 spiders.
