Re: HCE Pearl [Re: Wouter] #152756
08/15/08 08:23 PM
08/15/08 08:23 PM
I know the A-Cats are wickedly delicate, but they're managing to build them underweight. Thats a foot longer than the FXone, and two over the F16. Losing the spin equipment is worth 25lbs, not having a main halyard, and making the hulls freakishly small are all things helping this along too. I guess shedding 85lbs is alot to get the FX down to the F16 weight, and halving the weight would be borderline impossible to get it down to A-cat weight. Unless you were comfortable owning a boat that would be destined for the landfill at the end of each day.
The more I thought about this improved FXone today the more upset I got about it. I can't even get anyone to buy the cheap model in my area. I'm screwed if I think I can get someone to buy a even more expensive model. The other downside is that I would want one of these, and at the moment there isn't another boat that I'm really all that interested in getting. I like the platform, ALOT. With this new carbon boat, I'm sure the current FXone will be tossed in the trash-can by HCE, so there will be no new boats coming in at all. I don't know what to do. I was psyched when I bought my FXone, even more so now cause I'm finally starting to get good on it, I really don't want to race on handicap, and I don't want to go back to a non-spin boat, a H16, or a Tiger. Not wanting crew either eliminates those two. I should just get back into racing motorcycles. Supermoto is way too much fun.
Next question, whats it rate?
Re: HCE Pearl [Re: Karl_Brogger] #152757
08/15/08 08:47 PM
08/15/08 08:47 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
F17.
Re: HCE Pearl [Re: pitchpoledave] #152758
08/15/08 08:52 PM
08/15/08 08:52 PM
Nope
Re: HCE Pearl [Re: Karl_Brogger] #152759
08/16/08 04:36 AM
08/16/08 04:36 AM
Karl,
Well, A-cats are not that fragile; you just can't abuse them like a H16 and leave unattended on the beach with sails up. Indeed, even F16 owners need to be careful with that in unstable winds. These light boats can tip over when the gust comes from the wrong side. Unhooking the mainsaheet is almost a must. But the A-cat will stand the sailing load in rough weather quite well. And simple tricks have been found to stabilize the mast on these boats so they won't shake themselves down. I think the modern A's are more robust then many people imagine them to be.
That is not Hobie Europe's way of doing things. They'll keep the old version and just add the CARBONE. Hoever, it does mock the OD policy of the hobie organisations and the old and new version are certainly not expected to be of equal performance.
That is hard to predict, but when I use the current Texel specs for the old tech FX-one and punch in the new mainsail area (16.0 sq. mtr up from 14.91 sq. mtr) and assume that they get the weight down to 120 kg then the Texel rating will be :
(ordered from fastest rating to slowest)
A-cat = 99.5 = 100 (no spi !)
CARB-ONE 100.4 = 100
F16 1-up = 100.7 = 101
F18 = 101.2 = 101
F16 2-up = 101.8 = 102
F17 US version = 103.1 = 103
FX-one = 105.9 = 106
EU inter 17 = 109
It should be noted that all boats given above are with spinnaker except the A-cat. And the A's really get hammered for lacking a spi and can't really sail to their rating against spi boats. A better rating for the A's is just behind the F18/F16 2-ups unless the winds are 5 knots and less and the spi's won't fill properly.
The CARBONE looks promising in the speed department but a rating difference of 0.3 to the F16 1-up and 0.8 to the F18 (2-up) is only a difference of respectively 11 secs and 29 sec per hour of bouy racing. Which is pretty negligiable in real life. Due to rounding off of the rating the CARBONE needs to beat both by at least 36 seconds per hour racing. Basically, I expect it to become a level performer to the F18 and F16 classes; which is certainly not a bad thing in my opinion.
Note however that the entlarging of the sail from 14.91 sq. mtr to 16.0 sq. mtr. is responsible for 1.6 points out of 5.5 (30%), the rest (3.9 points) comes from being assumed to be 29 kg (64 lbs) lighter. So roughly 1.34 points per 10 kg. The new Carbone no longer can satisfy the F104 class specs, not even with the old smaller mainsail.
The 30 kg of weight savings seems well founded on the data I have. 6.5 kg on the mast (based on shortened Tiger mast to F16 carbon) max 7 kg per hull in only replacing glass with carbon but keeping same construction as old boat. 1.5 kg per daggerboard (F18 daggerboards to best of F16 daggerboards) and then some 1 kg per rudder setup (stock and board); max 2.0 kg per beam. Total 29.5 kg. They can also replace the boom and spi pole with carbon but that won't save them that much about 1.0 kg while adding lots of costs. Afterall a 35x2 mm black anodised alu boom costs 25 bucks and weights 1.28 kg (used by FX-one currently). You can only save 0.4 kg on that by going to carbon, but pay at least 4 times as much. Note that Hobie has yet to make any daggerboard under 3 kg even the full carbon ones. Going down to 1.6 kg as the best F16 boards are today will be quite a challenge for them. The same for rudderboards and stocks. And that 10.5 kg carbon mast (bare) will not be build in house either.
I hope this clearifies some things or at least gives a feel for what is reasonably expected.
Re: HCE Pearl [Re: Wouter] #152760
08/16/08 08:48 AM
08/16/08 08:48 AM
Wouter- The FXone is listed as having 16m2 of main sail right now. A least thats what the HCE website says.
Re: HCE Pearl [Re: Karl_Brogger] #152761
08/16/08 09:36 AM
08/16/08 09:36 AM
All, you need to be carefull to compare like sailarea with like.
With my SCHRS hat on, we've had claimed sail areas in "publications" that are either including or excluding the mast area, mast area makes a big difference!
Re: HCE Pearl [Re: Karl_Brogger] #152762
08/17/08 03:57 AM
08/17/08 03:57 AM
I'll believe that after it is measured by independent measurers. Like TEXEL or SCHRS rating officials.
Over time the big builders have often been fast and loose with specs they publicize on their webpages.
As of yet the FX-one is registered as having 14.91 sq. mtr sailarea by 8.03 mtr luff by TEXEL and this measurement includes the mast area.
Source : www.texelrating.nl
SCHRS gives : 14.85 sq. mtr by 8.10 mtr again incl. mast area.
Source : http://www.schrs.com/index.php?page=class&id=77
And if the new FX-ones feature a 16 sq. mtr sail already then we can protest out any result over the last period for racing under an invalid handicap. That would be a serious class issue as the class is responsible for maintaining the One-Design status upon punishment of deletion of the standard class rating in favour of forcing every boat owner to get an individual measurement certificate and having him present that at each regatta.
Maybe we should notify the rating officials of this interesting discrepancy ? Simon ?
Re: HCE Pearl [Re: scooby_simon] #152763
08/17/08 04:09 AM
08/17/08 04:09 AM
Simon,
16.0 sq. mtr is significantly more then the area used now in rating calculation irrespectibally whether it includes or excludes the mast area. In both cases the current rating for the FX-one is no longer accurate, but at minimum 1.4 points too slow if not indeed more.
Re: HCE Pearl [Re: Jake] #152764
08/17/08 07:22 AM
08/17/08 07:22 AM
Alachua, FL
Mugrace72 Offline
Mugrace72  Offline
Alachua, FL
Pearl isn't exactly a very aggressive sounding name to follow Tiger.
Not to mention that to a surfer...."pearl" is not a good thing.
I don't think Hobie Alter would approve.
Actually, the 16 should have been called the Pearl.
"<pearl>...(surfing) to dig the nose of one's surfboard into the water, often on takeoff. also [pearl diving]"
Jack Woehrle
HCA-NA 5022-1
USSailing 654799E
Alachua FL/Put-In-Bay
Re: HCE Pearl [Re: Mugrace72] #152765
08/17/08 09:52 AM
08/17/08 09:52 AM
I'm going to have to say that the French arm of Hobie named that one.
0 registered members (), 794 guests, and 26 spiders.
