Internal Barber Hauler #157624
10/19/08 09:56 PM
10/19/08 09:56 PM
ButchG Offline OP
ButchG  Offline OP
The Good News: I am the proud new owner of a slightly used Prindle 19.
The Bad News: The Owners Manual from Performance Cats sux root.
After having searched all throughout the forums I think I have the 4-way
Jib controls figured out. With one exception. At some point in time a
previous owner installed the barber hauler system that runs INSIDE
the front cross beam. For the life of me I can find no information on
how this thing is rigged.
Can someone here help me out?
Lead me to the info?
Shoot me in the head??
"There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order."
ButchG
Prindle 19 w/Spi
Re: Internal Barber Hauler [Re: ButchG] #157625
10/19/08 10:23 PM
10/19/08 10:23 PM
japan
erice Offline
erice  Offline
japan
seem to remember that airborne's nacra 5.2 also used an internal BH
try a search for a link to his many photos
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Internal Barber Hauler [Re: erice] #157628
10/19/08 10:46 PM
10/19/08 10:46 PM
ButchG Offline OP
ButchG  Offline OP
Airborne's internal hauler was his own design. The one I have is/was
a marketed optional/upgrade for cats. I remember it from wish books
in the early to mid '90's.
ButchG
Prindle 19 w/Spi
Re: Internal Barber Hauler [Re: ButchG] #157649
10/20/08 08:10 AM
10/20/08 08:10 AM
Lake Norman, NC
Doug_P182_LKN Offline
Lake Norman, NC
What would be the point? To simply clear the front crossbar of one more control line? The barberhauler never really gets in the way. The previous owner would have to have drilled out the front crossbar for line access. This would also no longer make the bar watertight - fun to right when water gets inside.
I would re-install the stock design which works fairly well by mounting the Harken cam-matic cleats to the top outside of the crossbar and plug/seal any drilled holes. In all honesty, the barberhauler is probably the LEAST used control line on the boat. It's only meant for pulling the clew of the jib to the outer edge of the crossbar for broadreach or downwind sailing. You can actually sail just fine without it.
IMHO.
Doug Bernstein
Prindle 18.2 'Special Treat' #590
Lake Norman, NC
Re: Internal Barber Hauler [Re: Doug_P182_LKN] #157651
10/20/08 08:25 AM
10/20/08 08:25 AM
ButchG Offline OP
ButchG  Offline OP
IMHO.
Some of what you say I agree with....most I don't. But thats for another post
and time. What ever we think, its there and budget considerations make rigging
what is there more important than changing it out.
I'll have some pics up tonight. Maybe that will jog someones memory.
ButchG
Prindle 19 w/Spi
Re: Internal Barber Hauler [Re: ButchG] #159618
11/06/08 12:14 AM
11/06/08 12:14 AM
jcasto1 Offline
jcasto1  Offline
I think I had the Murray's aftermarket barberhauler (internal to front beam) system to which you refer, on an old 5.2.
Here's a decription.
System had two cleats, one on each end of front beam, mounted in front of a hole in the beam in which which was a "exit block". Asingle line ran though cleat, into exit block, through the beam and out the other exit block & cleat at other end. It was about 4-5' longer than beam. At each end of line, either a 2-3" ring, or a pulley with becket, grabbed the jibsheets. When you are on stbd tack, you pull the stbd side line, and cleat it. That pulls port side jib sheets out near the beam, instead of sheeting down/in on tramp.
When you tack, you have to first uncleat the barberhauler & release jib, change sides, pull in barberhauler on other side, then sheet in jib. Just two more things to screw up in a jibe.
I always thought it would be better to have one cleat that could pull both barberhauler lines outward at the same time, be set once at top of downwind leg, released at bottom, but I never rigged it tha way.
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: Internal Barber Hauler [Re: jcasto1] #159627
11/06/08 03:11 AM
11/06/08 03:11 AM
UK
Cheshirecatman Offline
UK
The system sounds identical to the Hurricane 5.9 system using a block c/w becket at the ends to guide the jibsheets. On the 5.9 with the barber hauler length set up carefully the system self-uncleats when you sheet in on the new tack after gybing.
Cheshirecatman
Re: Internal Barber Hauler [Re: Cheshirecatman] #159629
11/06/08 03:26 AM
11/06/08 03:26 AM
Cheshirecatman
Cheshirecatman
The H59 system was a re-set on each gybe, jcasto1 is talking about a system where you set both barberhaulers at the same time with a single cleat, so you pull one bit of rope, and both barberhaulers move the same amount.
The H59 system needs re-setting after each gybe.
Re: Internal Barber Hauler [Re: scooby_simon] #159651
11/06/08 06:39 AM
11/06/08 06:39 AM
UK
UK
Hi Simon,
at least the 5.9 setup removes the requirement to uncleat (often forgotten) and can easily be trimmed from either side. I also suspect barber hauling both sides at once may slow the sheet running through the blocks during gybing. Do you have a copy of the 5.9 manual showing the barber hauler arrangement to post here for ButchG as the diagram no longer appears on the website?
Cheshirecatman
Re: Internal Barber Hauler [Re: Cheshirecatman] #159666
11/06/08 08:48 AM
11/06/08 08:48 AM
Nope; got rid of my old copy!
Re: Internal Barber Hauler [Re: Cheshirecatman] #159947
11/08/08 05:30 PM
11/08/08 05:30 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Have one on my Taipan. It arrives at through block off centre in main beam and as one cord through a swiveling cam cleat. Pull one line and both haulers engage and can be trimmed from either side of boat at any time.
Re: Internal Barber Hauler [Re: warbird] #159994
11/10/08 09:38 AM
11/10/08 09:38 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Doug, P18-2,
You want your crossbars water tight?
Usually, there are so many lines inside the front and REAR crossbar, that in a capsize, they drain out equally as well.
NOt using the inside of the crossbars for things like trap bungees, downhauls, barberhaulers, reaching lines (aka chicken lines), etc. is a huge waste of potential space.
My Nacra 6.0, that I bought from a rigging shop owner in the area,
had the barberhauler all internal, where on a jib, you didn't have to do anything, it was on or not.
With the spins I ran though, it was NEVER used, only without spins and going deep, or Really light air.
F-18 Infusion
#626- SOLD it!
Re: Internal Barber Hauler [Re: Doug_P182_LKN] #160006
11/10/08 12:47 PM
11/10/08 12:47 PM
andrewscott
andrewscott
Unless you are turtled... i doubt you will get more than a cup of water in your beam.... water tight is really not needed here... IMHO
