Re: Nacra 5.7 Pointing ability [Re: AzCat] #159301
11/04/08 08:21 AM
11/04/08 08:21 AM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
Originally Posted by azcat
Mast is straight up, no rake. So how close to daggered boats should I be pointing? Not counting the "S" turns.
Definitely try raking the mast back about 10-15degrees, if it is straight now maybe go up two holes in the forestay adjuster. The rake shouldn't be as severe as you might see on a H16. Make sure you tighten the shrouds after you do this. You should gain a few degrees pointing, but don't go overboard with the rake or your speed will suffer downwind.
Re: Nacra 5.7 Pointing ability [Re: hokie] #159315
11/04/08 09:23 AM
11/04/08 09:23 AM
andrewscott
andrewscott
Of course it is frustrating when a Porche 911 flies by my Honda Accord... but they are apple's and oranges.
You really should be comparing your cat performance to other 5.7's if you can find them.
It is good (or great) to learn about your boat, sails, fine tuning and all.. but its not really relevant to compare how a 25 year old design works against a newer boat (IMHO).
Re: Nacra 5.7 Pointing ability [Re: David Parker] #159401
11/04/08 03:14 PM
11/04/08 03:14 PM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
Originally Posted by David Parker
Make sure your weight is forward, the Leeward bow needs to be be more than 1/2 way submerged.
...Bows DOWN.
I just switched to a Nacra 5.0 and sure enough, it works GREAT on this boat, too. Light air or heavy, its the secret sauce!
Ditto--with my 5.0 it pointed well with 2-3" of bow visible above water.
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: Nacra 5.7 Pointing ability [Re: ejpoulsen] #159464
11/04/08 10:17 PM
11/04/08 10:17 PM
C
cattail
cattail
C
4th place in his first race bravo. Now do you have to finish 8th before you will invest in a newer sail. Check around a lot of guys have a spare you might be able to borrow for the day.
Re: Nacra 5.7 Pointing ability [Re: David Parker] #159612
11/05/08 11:09 PM
11/05/08 11:09 PM
jcasto1 Offline
jcasto1  Offline
AZcat - I agree in general with the comments about keeping the bow in as key to better pointing. You should not be pointing 15 deg lower than board boats. May 2-5deg, that is what I see on my 5.7 compared to board boats.
However, I'd caution the users posting who have experience on 5.0 but who have not sailed a 5.7. While in general the concept is the same, in fact the extra waterline length of the 5.7 compared to the 5.0 makes for a problem. When you push the 5.7 bow down, this extra length means the rudders are farther out of the water, and prone to cavitate/ventilate /stall out more quickly. This is the balance /walking the line I experience when racing the 5.7 - moving forward just to the point before the rudders are going to stall out.
When I sailed my 5.0, I never had that experience, I could bury the bow and still have enough rudder blade in the water.
Anoher thing to consider is the jib sheeting location of the 5.7, on the hull. I'm actually considering moving it inboard, locating it like on a NACRA 5.2.
Jim Casto
Jim Casto
NACRA 5.5 & NACRA 5.7
Austin TX
Lake Travis
Re: Nacra 5.7 Pointing ability [Re: jcasto1] #159623
11/06/08 01:07 AM
11/06/08 01:07 AM
Arizona
AzCat Offline OP
AzCat  Offline OP
Arizona
Thanks to all who posted on this subject. It looks like I have some homework to do. I will work on all of the above.
I think that it may be a great oppurtunity to upgrade to a mylar squaretop main also. I think that I may have major slot issues. I will get some pics while upwind and post them.
In fact, I think there may be some on "My Space- Wet Kitty Catamaran club." Google Wet Kitty,... it's the one with the boat.
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
0 registered members (), 649 guests, and 178 spiders.
