Re: Team Philips [Re: CharlesLeblanc] #16254
02/27/03 09:31 AM
02/27/03 09:31 AM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Charles,
There were three approaches to mast configuration in the Race:
The unstayed rotating wing masts of Team Philips were the more radical - and the alternative that concentrated more efforts in the mast base. As you pointed out, more flexibility would have dissipated part of the energy - but would probably reduce the speed as well.
The Multiplast boats' rotaing wingmasts were less radical, distributing part of the efforts to the rest of their structure via stays. Still, afterwards they had problems in the mast base and in the mast itself.
Playstation's mast was the most conventional, being fixed.
When one puts the facts in this order, it could be imagined that the problem is with the degree of mobility of the mast, but I don't think this true. Self supporting masts can be very safe. Gary Hoyt's Freedom line and many other boats have been using unstayed masts successfully for a long time.
Probably the main problem has to do with the higher dependence on each iindividual fiber, resulting from the use of a smaller total number of fibers due to the higher moduli fabrics. I read somewhere that the ORMA open 60 designers are questioning the use of high modulus carbon in masts on this grounds.
Do you know anything about it?
Luiz
Re: Two Masts; One On Each Hull [Re: Jake] #16255
02/27/03 05:21 PM
02/27/03 05:21 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
If I recall the unstayed masts on Team Philips rotated at the base: This was a huge engineering problem to solve. What if a short sleeve, lets say a 10% height outer sleeve, was placed such that the modified wing mast plus soft sail rotated inside it? It could then have some stays, and not be such an engineering nightmare. Who has done this already?
Dacarls:
0 registered members (), 541 guests, and 22 spiders.
