| Re: maintenance
[Re: fin.]
#165751 01/22/09 03:43 PM 01/22/09 03:43 PM |
Posts: 118 Pensacola, FL | Pete, You may want to check you spreader adjustment turnbuckles. One of mine had seized and I broke the threaded stainless steel part trying to free it up.
Chris Trident F16
| | | Re: maintenance
[Re: fin.]
#165826 01/23/09 07:20 AM 01/23/09 07:20 AM |
Posts: 6,049 Sebring, Florida. | WD40 lube on everything metal, let it soak in before you try to turn it. I always wash my mast boom, hulls, etc. as soon as I get home from a salt water event.
Blade F16 #777
| | | Re: maintenance
[Re: Smiths_Cat]
#165898 01/23/09 12:23 PM 01/23/09 12:23 PM |
Posts: 3,348 | Thanks Klaus.
There was a discussion about this on the main board, but I can't find it.
Anybody?
| | | Re: maintenance
[Re: Rolf_Nilsen]
#166077 01/25/09 03:55 PM 01/25/09 03:55 PM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | The Taipans were made with anti-corrosion paste between all the surfaces where SS might touch Al- a sort of yellow compound- I have been unable to get the exact same stuff here in the US, but they do have similar compounds and it should go on every screw,plate, etc. that contacts Al- ideally even between cast and extruded Al IMO. I haven't had a problem with my Taipan in 10 years but then I only "visit" salt water and, as Timbo says, religiously flush it with fresh water ASAP. I would suggest carefully taking corroding components apart (see WD-40 note above), cleaning very well to remove any corrosion/salt, dry carefully and reassemble with plenty of anti-corrosive gel (Tef-Gel is one brand I have used here).
Kirt
Kirt Simmons Taipan, Flyer
| | | Re: maintenance
[Re: CaptainKirt]
#166084 01/25/09 05:29 PM 01/25/09 05:29 PM |
Posts: 9,582 North-West Europe | That stuff is called Duralac
| | | Re: maintenance
[Re: fin.]
#166239 01/26/09 08:26 PM 01/26/09 08:26 PM |
Posts: 6,049 Sebring, Florida. | Double check your tiller crossbar, look for any signs of cracking at the mid point hole where the tiller extension fitting is attached. Mine snapped right there at the hole during a gybe and I lost the tiller extension overboard before I could grab it.
Blade F16 #777
351
guests, and 26
