Page 1 of 5 1 2 3 4 5
NACRA Inter 18? #171945
03/16/09 06:11 PM
03/16/09 06:11 PM
Charleston, SC, USA
krona Offline OP
krona  Offline OP
Charleston, SC, USA
Hi guys,
There is an Inter 18 for sale out there, that interests me.
What are the main difference between an Inter 18 and an F18 (non Infusion)?
I'd like to get my hands on an F18 (any manufacturer) but they are a little price for me. And despite occasional racing I do more recreational sailing still. Just got back from 10days in FL sailing "Frank The Tank" in the gulf, still a fun boat with friends. But is sucked moving it around the beach every morning end evening this thing has to be 500lbs and the beach was 100ft long.
I want something lighter and faster than my Getaway and newer than an old H16.
The new NACRA 570 Sport with Square Top and Spinnaker looks like a lot of fun at 19ft and 360lbs..... But that too is pricey.
Bjorn
NACRA 570 #90308
Hobie 16 #68973
Re: NACRA Inter 18? [Re: krona] #171947
03/16/09 06:26 PM
03/16/09 06:26 PM
Lake Murray SC
FasterDamnit Offline
Lake Murray SC
It is an F18 class boat.
Re: NACRA Inter 18? [Re: krona] #171948
03/16/09 06:28 PM
03/16/09 06:28 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
The I18 is the eighteen foot version of the Inter 20/Nacra 20. It is an 18 foot boat with volume before volume was cool.
There used to be one in the Melbourne area on the market for a very long time but sadly it finally sold and left the area.
F18 USA 242
http://www.solarwind.solar
Re: NACRA Inter 18? [Re: FasterDamnit] #171949
03/16/09 06:29 PM
03/16/09 06:29 PM
Clermont, FL, USA
Clermont, FL, USA
With an alloy stick. The carbon snuffer isn't F18 class legal either.
F18 USA 242
Re: NACRA Inter 18? [Re: David Ingram] #171950
03/16/09 06:32 PM
03/16/09 06:32 PM
Lake Murray SC
Lake Murray SC
So you have to use an Al pole and snuffer?
Re: NACRA Inter 18? [Re: FasterDamnit] #171953
03/16/09 07:08 PM
03/16/09 07:08 PM
You don't have to use aluminum...but it can't be carbon.
Re: NACRA Inter 18? [Re: Jake] #171956
03/16/09 07:21 PM
03/16/09 07:21 PM
Charleston, SC, USA
krona Offline OP
krona  Offline OP
Charleston, SC, USA
Is Inter 18 the old name for the F18 (Non Infusion)? That commonly is referred to as the NACRA F18?
NACRA 570 #90308
Hobie 16 #68973
Re: NACRA Inter 18? [Re: krona] #171957
03/16/09 07:24 PM
03/16/09 07:24 PM
The Inter 18 was around before F18 was born. It just happens to fit the F18 box rule. The I18 is probably not as optimized an F18 but it is a pretty solid boat.
Re: NACRA Inter 18? [Re: Jake] #171958
03/16/09 07:28 PM
03/16/09 07:28 PM
Charleston, SC, USA
krona Offline OP
krona  Offline OP
Charleston, SC, USA
OK, so how much for a 2001 with trailer and original "white" sails and a trailer, no Spinnaker frown Otherwise in OK shape.
NACRA 570 #90308
Hobie 16 #68973
Re: NACRA Inter 18? [Re: Jake] #171964
03/16/09 08:42 PM
03/16/09 08:42 PM
Clermont, FL, USA
Clermont, FL, USA
B.2.3. BOWSPRIT
The bowsprit shall be made of extruded aluminium profile of constant section.
The length shall not be greater than the distance, measured in total from its attachment point
from the centre of the front beam to the vertical line touching the most forward part of the hull,
with the bowsprit measured when level to the deck of the catamaran, plus an additional
800mm.
The bowsprit shall be fixed and approximately on the longitudinal centreline of the boat. See
diagram.
The forward end of the bowsprit shall be rounded and blunt.
F18 USA 242
Re: NACRA Inter 18? [Re: David Ingram] #171965
03/16/09 09:03 PM
03/16/09 09:03 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: NACRA Inter 18? [Re: krona] #171966
03/16/09 09:12 PM
03/16/09 09:12 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Bjorn
Do you want to race this boat in F18 class OD races?
The US Inter 18's were supplied with a carbon mast and larger then F18 Class legal main. The Inter 18 was also sold to Nacra Europe with an Alu Mast and F18 class legal sail and this boat was fully compliant with the F18 rule in Europe. (It competed at the time with Dart Hawk....) The design was replaced by Nacra with the F18 and later with the Infusion models. Some of the Inter18's in the USA were grandfathered into the NAF18 class with their carbon mast for a limited time. They were supposed to purchase a class legal mast to update the boat by some date certain.. You prospective boat could have one of these rigs so you should check.
So, If the boat in question has a carbon mast you won't be F18 class legal. This is not a problem though if you just want to go racing in any open class race in your area. If you are rec sailing... just keep the paint touched up and enjoy a nice ride.
crac.sailregattas.com
Re: NACRA Inter 18? [Re: Dazz] #171968
03/16/09 09:44 PM
03/16/09 09:44 PM
welp, chalk me up for two Razzberries tonight!
I had no idea F18 was around in 1996 (I started sailing in 2000) and I was definitely mistaken about the aluminum spin pole on the F18.
Re: NACRA Inter 18? [Re: Jake] #171976
03/17/09 04:28 AM
03/17/09 04:28 AM
I believe that was the Dart Hawk and it was the design that partly inspired the F18 class. The nacra Inter 18 however was designed to the F18 rules, then still young and exclusively in EU, much like the Hobie Tiger (1995). Initially the F18 class wasmade up by the Alado F18 (became Tiger later), Dart Hawk and some Mattia design.
Ohh, I see others had already reacted to these claims. Sorry.
Re: NACRA Inter 18? [Re: Wouter] #171979
03/17/09 05:50 AM
03/17/09 05:50 AM
So how would a Dart Hawk do against the current generation if fitted with new aft beam and updated sails?
Re: NACRA Inter 18? [Re: Rolf_Nilsen] #171981
03/17/09 06:28 AM
03/17/09 06:28 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
How about a set of HT hulls as a basis for a F18? Good idea or waste of time?
Can anybody comment on the differience between the Bimare F18 hull shape and the HT? In pictures it looks pretty similiar.
Re: NACRA Inter 18? [Re: bvining] #171982
03/17/09 06:38 AM
03/17/09 06:38 AM
They probably have a bit more resin in them!
Re: NACRA Inter 18? [Re: Jake] #171983
03/17/09 06:50 AM
03/17/09 06:50 AM
Will the HT hulls be able to take the loads from a jib bridle gracefully?
The Hawks around are in my price range so buying one of those with the aim of replacing the hulls with something else (homebuilt) later on is attractive. This is all pure conjecture for now as we are going to launch and enjoy our F16s, but we are looking at adding an F18 to the fleet. It looks like the F18 class is taking off here in Norway and we want to be part of that also. Going through an Hawk, if they can be competitive on national level with good sails, seems like an affordable way into the class.
Re: NACRA Inter 18? [Re: krona] #171985
03/17/09 07:07 AM
03/17/09 07:07 AM
andrewscott
andrewscott
Very hard to say. so many factors. Mostly revolve around, supply / demand and how badly the seller wants/needs to get rid of it.
There is some "blue book" value insurance companies would butts it at... but even that is probably "way off".
The better question (to yourself) is.... is the asking price seem fair for the value of the boat to me.
Not always possible, but i would ALWAYS suggest you take the boat out for a test ride to get a good look at its setup, rigging, check for issues... etc. You wouldn't buy a used car without a testdrive...
Re: NACRA Inter 18? [Re: ] #171988
03/17/09 07:18 AM
03/17/09 07:18 AM
wait...Jake's only been multihull racing since 2000? Jeeze, I thought you'd been at this way longer than that...
0 registered members (), 324 guests, and 82 spiders.
Posts267,058
