| pointing: uni v sloop #186756 08/02/09 08:32 AM 08/02/09 08:32 AM |
Posts: 5,525 | I was able to out point most other boats with my H17, but I don't see this with the F16 uni. Seems to point about equally with the sloop.
Pete Pollard Blade 702
| | | Re: pointing: uni v sloop
[Re: Robi]
#186763 08/02/09 09:27 AM 08/02/09 09:27 AM |
Posts: 5,525 | But were you getting to the weather mark before the sloops?
Here's my problem: when I started sailing the Blade, I sailed to weather like on my old H17. The Blade would go into irons without any warning and I was always last to the weather mark. It seems the lower and faster I sail the better vmg I have.
[Re: pgp]
#186765 08/02/09 09:51 AM 08/02/09 09:51 AM |
Posts: 2,718 St Petersburg FL | When I sailed the Blade I was racing against hot shot sailors. Usually I20s Tornadoes etc. ON a few occasions yes I did get to the weather mark before them.
If you are going into irons, I dont think it has to do with the rig, I would say its more like a wind shift. The biggest thing that I think has improved my sailing is paying attention to wind shifts.
[Re: Gilo]
#186772 08/02/09 12:38 PM 08/02/09 12:38 PM |
Posts: 5,525 | I CAN sail very high with the Blade. It just doesn't seem to pay off. Lower, faster seems to yield a better vmg. At least for me.
[Re: pgp]
#186783 08/02/09 05:01 PM 08/02/09 05:01 PM |
Posts: 1,121 Eastern NC, USA | I CAN sail very high with the Blade. It just doesn't seem to pay off. Lower, faster seems to yield a better vmg. At least for me. I think you need to power up by sailing lower and dig the bows in (when conditions allow). The Blade hull design allows the leeward hull to act like another daggerboard and provides lift - especially with the low aspect boards on the early models. It'll feel like footing, but you'll get speed and lift and viola, at the A mark earlier.
Tom | | | Re: pointing: uni v sloop
[Re: Gilo]
#186796 08/03/09 12:10 AM 08/03/09 12:10 AM |
Posts: 120 | Pete,
I agree with you that uni the Blade sails the same upwind angle as sloop. Next weekend (Dutch nationals) I'll compare my angle to the one of Hans :-) One team at our club sailing an Infusion is a great reference for us. Sailing sloop we sail about the same angle and speed. Uni I also had the best result by sailing about the same angle as them. When I sailed uni together with them they were double trapping. Maybe with a bit less wind it's possible to point a little higher... Just be careful when comparing to the F18s. When we where testing the VIPER last summer we where doing some straight line speed testing against the CAPRICORN and in 12-15 knots the VIPER sloop was no slower but it pointed higher and therefore had a greater VMG. We basically put this down to the extra weight on the CAP and the fact that you have to get the nose down wind it up like a freight train. In general the same boat/rig will sail higher uni rigged than sloop rigged. As a matter of fact the power to weight ratio on an F16 uni should have it pointing higher than almost anything (including F16 sloop rigs) and if it not you should be looking at you rig set-up. The irons problem shouldn't happen, period. wind shifts are the only real explanation for that. | | | Re: pointing: uni v sloop
[Re: Brett Goodall]
#186830 08/03/09 09:03 AM 08/03/09 09:03 AM |
Posts: 606 Maryland | As a matter of fact the power to weight ratio on an F16 uni should have it pointing higher than almost anything .... Almost anything = A-Cats. They'll nail you.....spin envy!
Kris Hathaway | | | Re: pointing: uni v sloop
[Re: Kris Hathaway]
#186857 08/03/09 12:39 PM 08/03/09 12:39 PM | DougSnell
| DougSnell
Unregistered | I think it has a lot to do with the jib changing the apparent wind?
Doug | | |
295
guests, and 19
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
