| Re: Tell me about the Prindle 19
[Re: TurboCat]
#186977 08/04/09 04:59 PM 08/04/09 04:59 PM |
Posts: 70 | Welcome to the "Giant Killer"  From experience....don't ask how I know.... Sqare tops are the way to go, BUT reenforce your hulls. Install an internal bulkhead just forward of the FWD crossbeam, will help with the stress loads from the increase in dynamic lift. Go with the F18 or N20 Spin. The Tornado Spin is waaaay to big. This is MY opinion....YMMV
"There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order."
ButchG Prindle 19 w/Spi | | | Re: Tell me about the Prindle 19
[Re: ButchG]
#186995 08/04/09 06:43 PM 08/04/09 06:43 PM |
Posts: 1,200 Vancouver, BC | Go with the F18 or N20 Spin. The Tornado Spin is waaaay to big. This is MY opinion....YMMV The T spin is not much different than the I20...infact I believe it's flatter and likely smaller overall in square footage. The I20 rig is 31 ft compared to the puny ~29 ft T rig.
[Re: Tornado]
#186996 08/04/09 06:45 PM 08/04/09 06:45 PM |
Posts: 1,200 Vancouver, BC | Googled it:
N20 Spin: 25 m2 Tornado Spin: 25 m2
[Re: Tornado]
#187001 08/04/09 07:20 PM 08/04/09 07:20 PM |
Posts: 3,224 Roanoke Island ,N.C. | Do a search on here for P-19 MX , and look at that mod. It's definitely the way to go.You can have your pinhead modified to a MX square top if you don't want to buy a new one. I had the MX rig with a 475 sq ft chute and it was excellent in light air and good on up the scale. I would say GO with a newer cut Tornado kite over an I/N 20 kite. They are flatter and faster.
[Re: TurboCat]
#187018 08/04/09 10:12 PM 08/04/09 10:12 PM |
Posts: 70 | TurboCat They should be just far FWD enough to clear the mounting plates for the forward cross beam thru bolts. Also make sure the bulkhead has a drain cut out at the bottom to let any water drain. This does two things, it reenforces the cross beam stress area as well as stiffening the hulls for less "walking" when cutting waves. This (I think) was done on the P19's made after 90 or 91. I know there is an aft bulkhead on boats made after 90. But I am not sure about the FWD ones. I had mine done after watching stress fractures appear on two P19's in my area that went to an MX rig. Mr. Dobbs is correct...and I stand corrected. The spin I got was a tornado spin for a T sailor made by Smythe. BUT, it turns out it was a special order oversize kite...which I am having cut down for controllability. A square top main, with a standard size jib and a 24 to 26 square meter spin will bring your D-PN to 64 and change. Sailed properly (which I am still learning to do) it will wax N20's....seen it done
[Re: TurboCat]
#187021 08/04/09 10:23 PM 08/04/09 10:23 PM | DougSnell
| DougSnell
Unregistered | Teddy:
There is a whole chapter in "Catamaran Racing for the 90"s" on the Prindle 19 by Randy Smyth. Won't help you on the spinnaker part, but should with setting up rest of boat.
Doug | | | Re: Tell me about the Prindle 19
[Re: ]
#187024 08/05/09 12:14 AM 08/05/09 12:14 AM | andrewscott
| andrewscott
Unregistered | if i recall correctly, Tornado masts are 31' i sail a 5.5 with a 30' mast. i started with a H Tiger spin.. it fit ok but my pole was pretty high.
I now fly a T spin and my pole sits a little low and i have an inch of downward pre-bend in the pole.. and my spin luff is JUST barely tight enough..
I doubt you could rig it on an 29' stick.
I have sailed the P19,.. it was great.. i am sure you will enjoy it when you get it out. | | | Re: Tell me about the Prindle 19
[Re: TurboCat]
#187038 08/05/09 07:07 AM 08/05/09 07:07 AM |
Posts: 264 Long Island, NY | The MX package is definately the way to go. Glaser sails has a very good guide for rig tuning and sail adjustment. It's a fast and forgiving boat. I didn't realize how resistant it was to pitchpoling until I sold it and bought a Blade. I never used a spin on it but there's a lot of spaghetti on it with the barber hauler, 4-way jib lead adjustment etc... The newer style rudders are much better.
G Gove
Blade #728
Long Island, New Yawk
[Re: HMurphey]
#187050 08/05/09 10:14 AM 08/05/09 10:14 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin
Posts: 3,655 Portland, Maine | as I stood there I could just visualize the beach full of cats and the anchorage full of boats after the NASS Race ... That beach still covered in pea-gravel and oyster shells? I'd pull my laser up on that beach no problem, I'd cringe when pulling the 20 up on it  | | | Re: Tell me about the Prindle 19
[Re: ]
#187057 08/05/09 11:20 AM 08/05/09 11:20 AM |
Posts: 1,200 Vancouver, BC | if i recall correctly, Tornado masts are 31' i sail a 5.5 with a 30' mast. i started with a H Tiger spin.. it fit ok but my pole was pretty high.
I have sailed the P19,.. it was great.. i am sure you will enjoy it when you get it out. Tornado stick is under 30'...29 and change. The max luff length on the spin is also a factor of where the halyard block sits alone the mast relative to the tack block on the pole, the pole length also contributes (4 meters from tack block to front of beam is the limit) and finally mast rake.
[Re: TurboCat]
#187058 08/05/09 11:31 AM 08/05/09 11:31 AM |
Posts: 1,200 Vancouver, BC | Ok just went outside to take a pic and my shop light is burnt out so no pic yet. So is a F18 chute too small? I keep hearing that F18's can carry a chute a lot higher than a N20. Is this simply the cut of the chute or the size? I am very interested in making this a fast boat so a chute is a must. The F18 chute is smaller and flatter...so it will perform better sailing closer to the wind. This can make it fast in races like hte Tybee where you're broad reaching all day long. But, on proper windward/leeward courses, the N20 is faster at deeper angles, and the Tornado faster still. Though the T spin is not cut deep like the old cut of the N20. I think the superior downwind (& up) performance of the T comes mainly from the extra beam. The P19 is a mini Tornado...hull shape & bow design are nearly identical to the T. Rigging is straight off the the classic T. Even has centerboards like the T, though they appear to be even less capable then the relatively poor performing blades of the T. I once hopped aboard a P19 for a short sail off the beach with it's new owner. I was impress with how similar it felt to the T. Within a few minutes we were the fastest boat moving that day, passing all comers including a 20 ft Mystere and several Hobies and even two rather beat up/delapidated old Tornado's.
1 registered members (FredL),
505
guests, and 97
