| Re: windage
[Re: Gilo]
#189363 08/28/09 07:58 AM 08/28/09 07:58 AM |
Posts: 6,049 Sebring, Florida. | Gilo, I beileve that is part of the "concept" behind all the new cut back bows we are seeing on the newer A cats, F16's and F18's. Some call them wave piercing, but in fact, every bow is wave piercing, right? So it must be to reduce windage while out of the water.
Blade F16 #777
| | | Re: windage
[Re: Gilo]
#189378 08/28/09 08:37 AM 08/28/09 08:37 AM |
Posts: 548 MERRITTISLAND, FL | If a snuffer bag has that much windage that it causes a cat to run deeper then one without, what about the higher bows of the Viper versus the Blade. Would a Blade sail higher because the bows have less windage? Welcome to the world of boat design. Every feature and descision is compromise. Big volume and high freeboard provide more wave drag and windage. Lower of these can cause beam slap and increaded wetted surface. The list of compromises is imense. Most boats have gradualy drifted into a minor range varience where the whole thing works pretty well. Changes to stuff like this is really nit picky and of such marginal difference between plaforms as to be ridiculous. I doubt there are more than a couple sailors in the world who could actually tell a difference. It all goes back to the ballance thing as Rolf said. Nothing you can do or change on the boat will equalize things exactly. Get it close and go sail. If you worry about it, then it is slow no matter what. If you think it is fast then it is.  | | | Re: windage
[Re: Rolf_Nilsen]
#189385 08/28/09 08:59 AM 08/28/09 08:59 AM |
Posts: 548 MERRITTISLAND, FL | If you worry about it, then it is slow no matter what. If you think it is fast then it is. I definately agree 100% on that! Rolf - You get your ticket to come over for the Global Challenge yet? We will find you a spot to rack up. | | | Re: windage
[Re: Rolf_Nilsen]
#189396 08/28/09 10:08 AM 08/28/09 10:08 AM |
Posts: 571 Hamburg | Sharp egdes give more drag than well rounded egdes Rolf, I have never seen sharp edges on the bow of any boat/cat. They are blunt enough not to stall and generate lift when sailing upwind. So cutting them away for aerdynamic reasons is not as clever as some people think. You will find a chapter in Marchaj's book about some of the effects involved. I have a furling genaker on my boat. I sailed the boat with and without it, never realised any difference, so I don`t care even if it is an easy exercise to calculate it. I wouldn't care about the drag of a snuffer as well, maybe about the blocked airstream to the trampoline. But only if I am bored and want to invent problems  Maybe somebody else has tested his boat with and without snuffer and can us tell the difference? Cheers, Klaus | | | Re: windage
[Re: Smiths_Cat]
#189409 08/28/09 11:04 AM 08/28/09 11:04 AM |
Posts: 6,049 Sebring, Florida. | Since everyone is racing with basically the same setup, does it really matter at all? Fugedaboutit and sail fast!
Blade F16 #777
| | | Re: windage
[Re: Rolf_Nilsen]
#189458 08/28/09 07:07 PM 08/28/09 07:07 PM | DougSnell
| DougSnell
Unregistered | Doug,
have you ordered a F16 Falcon? No, got to do the catering circuit for a year and get the internet business going. Hopefully next season. Being boatless is KILLING me. Doug | | | Re: windage
[Re: David Ingram]
#189468 08/29/09 12:20 AM 08/29/09 12:20 AM |
Posts: 1,479 Thailand | So who died and named you spokesmen for the class?... I would be racing F18 now if not for their crappy weight handling.
Matt, do you REALLY want to go down this road? Ding, I stand my my statement and for me it is true. (essentaily there was no F16 available when I wanted to go spin but the issues above with F18 pushed me to building 1) You and I HAVE been down this road and are pretty familiar with eachothers points. I would be more than happy to discuss it with anyone else - just bring beer or rum Matt, it's your choice of words not the content. I have absolutely no issue with the F18 not being right for you. But don't make your point in such a way "crappy weight handling" that it is directed as a slight at my class. Don't trash the F18 class because you want to make a point about weight in your class. Do unto others Matt.
| | | Re: windage
[Re: Buccaneer]
#189486 08/29/09 09:52 AM 08/29/09 09:52 AM |
Posts: 893 | So who died and named you spokesmen for the class?... I would be racing F18 now if not for their crappy weight handling.
Matt, do you REALLY want to go down this road? Ding, I stand my my statement and for me it is true. (essentaily there was no F16 available when I wanted to go spin but the issues above with F18 pushed me to building 1) You and I HAVE been down this road and are pretty familiar with eachothers points. I would be more than happy to discuss it with anyone else - just bring beer or rum Matt, it's your choice of words not the content. I have absolutely no issue with the F18 not being right for you. But don't make your point in such a way "crappy weight handling" that it is directed as a slight at my class. Don't trash the F18 class because you want to make a point about weight in your class. Do unto others Matt. What a tetchy useless piece of drival, why is it that people can't see the lighter side of the internet and its forums, this is supposed to be a good natured humour filled piece of reading not a bun fight because someone is all pissed about dissing their particular class of boat. Go back to the F18 Forum and play there before we all start dissing the F18 for bit of good wind up banter.
| | | Re: windage
[Re: Smiths_Cat]
#189499 08/29/09 12:08 PM 08/29/09 12:08 PM |
Posts: 4,451 West coast of Norway | Rolf, I have never seen sharp edges on the bow of any boat/cat. They are blunt enough not to stall and generate lift when sailing upwind. So cutting them away for aerdynamic reasons is not as clever as some people think. You will find a chapter in Marchaj's book about some of the effects involved. I have a furling genaker on my boat. I sailed the boat with and without it, never realised any difference, so I don`t care even if it is an easy exercise to calculate it. I wouldn't care about the drag of a snuffer as well, maybe about the blocked airstream to the trampoline. But only if I am bored and want to invent problems  Maybe somebody else has tested his boat with and without snuffer and can us tell the difference? There is some references to pratical experience on sailing without spi gear earlier in the thread and on the F16 class forum. I think we can agree that there is a difference and that the difference is due to increased drag.(AAGH! I got to stop connecting drag with The Adventures of Priscilla, Queen of the Desert) About bows and drag. You should know.. John Shuttleworth had an article about how he loocked at minimizing drag from wind passing over the hull in his Tektron and Dogstar designs. He reported that the optimalization done was worth the effort as far as I remember. The articles I read about the design and build phase of Cogito said similar things. They looked at minimizing drag from the platform. Minimizing exposed area and rounding off surfaces sounds like a logical thing to do to reduce drag? Please do share your thoughts. Interesting topic and something that we can adjust as compared to drag from our bodies while trapeezing. Is this drag tiny compared to going the wrong way or not knowing how to trim the sails.. Indeed  Doug, hope you succeed and get finally get that F16  | | | Re: windage
[Re: Rolf_Nilsen]
#189510 08/29/09 01:03 PM 08/29/09 01:03 PM | DougSnell
| DougSnell
Unregistered | Built one successful before. I will be back up again...thanks Rolf. It is killing me not to sail...Although Ike took away our local place to sail. 1 1/2 hrs drive now
[Re: Rolf_Nilsen]
#189561 08/30/09 08:28 AM 08/30/09 08:28 AM |
Posts: 571 Hamburg | Rolf,
I am always very careful if people tell me something about minimising drag. I don't want to have a boat minimised for drag. I rather want to have a boat optimised for speed or efficicncy or whatever. To make it clear, a boat optimised for drag is a boat without a sail, or even better: no boat at all. And it should be clear that this should not be the target for any trade.
Yes, bows generate drag, and no bows generate no drag, however bows generate also some lift (like a sail) if sailing upwind, and as with sails, bows with higher aspect ratio are more efficient than bows with low aspect ratio. Apart from that hulls accelerate the flow at the low part from the sail by displacing a volume of air and reduce the tip vortex (at the boom) around the sail. As mentioned this is explained in Marchaj's book. Last but not least, the hulls of a beach catamaran help to make the flow around the trampolin more efficient, hence it generates more lift and less drag (this effect might be offset with a spinnaker kit). The lift of the trampolin lifts the boat (slightly) and reduces hydrodynamic drag.
All of these effects are of secondary order. But it shows that optimising a single component (the bows) of a boat for a single reason (aerodynamic drag) doesn't guarantee an improvement of the whole system (which includes much more than just aerodynamics).
Regarding the drag of the sailor traping out: The same sailor would have about the same drag while sitting on board, but he interfers less with the sail when trapping out (although I don't know if this is good or bad). Again this is a second order effect.
A bit off-topic: When building your rudders and boards, you shoudn't round the tips. Maybe you know that already.
Cheers,
[Re: Smiths_Cat]
#189687 08/31/09 10:36 AM 08/31/09 10:36 AM |
Posts: 118 Pensacola, FL | Klaus, Can you explain your comment on not rounding the boards and rudders. My blade boards are cut straight at the bottom with the same cord from top to bottom. I think the falcon's boards taper a little from the trailing edge at the bottom. The infusion's boards round from the trailing edge down to a straight leading edge and the wildcat tapers from both the leading edge and the training edge. I am just trying to get an idea of what each design is trying to achieve hydrodynamic-ally. Thanks.
Chris Trident F16
| | | Re: windage
[Re: Cab]
#189712 08/31/09 12:50 PM 08/31/09 12:50 PM |
Posts: 571 Hamburg | Hi Chris,
I meant rounding the tip edge of the rudder, not the planform. The planform is what you see from your rudder, if you lay it flat on the ground. The wing tip edge is best seen if you look from the leading to the trailing edge (e.g. front view). If you make it round, you help the tip vortex, which is always there, to be stronger and hence more dragy. If you make it sharp, you hamper the vortex a bit. Hence rountig or fairing the tip edge is not good. A simple cut is better, just have a look at modern aerobatic aircraft (which have a symmetrical foil as our rudders).
In terms of planform you have some degrees of freedom from an aerodynamic point of view, many shapes are possible. Some people "believe" in elliptical shapes, however a simple taper ratio of 0.4 is as "good" (depends largly on your figure of merit, which is not only drag) as an elliptical shape, but much simpler to fabricate. There is a small "improvement" possible if you have rounded leading edge on the last 5% of span, as you can see on many airliners when not equipped with wingtip devices. Again second order effects, most important parameters are area, span and the section shape(s). It is difficult to judge these rudders unless you know what are the most limiting factors (stalling at low speeds, cavitating at high speeds, structural strength), what are the design targets (optimising lift/drag) and what is design philosophy (rotating or sliding kinematics, designed to be loaded or unloaded when sailing straight) , etc.
When we broke the rudder of my friends T, we decided to keep the same area and span, but went for staright leading and trailing edge and designed a new section shape, which should have less cavitation, slightly less drag and better structural stability than a conventional NACA 4 digit section.
Cheers,
Klaus | | |
296
guests, and 8
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
