Then I installed a Weber DCOE and it stayed in tune for longer than 3 weeks.
I can remember driving across country from California and tweaking the SU's for the elevation, I'm anal like that hated to loose RPM’s......I guess it is like adjusting the sails?
Mike Shappell www.themanshed.com TMS-20 Builder G-Cat 5.7 - Current Boat NACRA 5.2 - early 70's
Re: Fun project 1960 MGA - remember them?
[Re: TheManShed]
#190116 09/03/0911:45 AM09/03/0911:45 AM
You got it. Since I am a power junkie, I really noticed if it started to fall off. I rebuilt them, put in Gross jets, and had the synchronizer in the glove box. That car was crying for a lightweight, small block V8. An aluminum headed, Ford 302 was less than 100lbs more than the stock 4.
E-Scow 24' ULDB
[Re: FasterDamnit]
#190119 09/03/0912:02 PM09/03/0912:02 PM
Yup, all aluminum 215 (or more depending on year). Nice light motor, but if you wanted more than 250hp, go with the SBF. My current 347 should hit right at 500hp.
E-Scow 24' ULDB
[Re: TheManShed]
#190123 09/03/0912:07 PM09/03/0912:07 PM
At a recent IBMD car show, one of the other A's had his crank handle in the bumper with a sign on it "MGA Remote Starter". Unfortunately, my crank handle is missing, but I don't drive mine if the temp is below about 50.
I do drive mine a lot in the summer. At the shows, people with museum restorations see all the dents and smudges and say "You really drive this car, don't you? And you're not afraid to leave it in a parking lot, are you?" Sometimes I accidently leave the key in it, but I don't think a thief could figure out how to start it, no less drive it.
The only problem I have with my SU's is when a float sticks, the bowl overfills, and it dumps gas on the ground. That and parts rattling loose.
What - Me Worry?
2006 Hobie Wave 7358 "Ish Kabibble"
[Re: TheManShed]
#190125 09/03/0912:09 PM09/03/0912:09 PM
I don't know about other people, but I used the hand crank a lot. I was disappointed when my MGB didn't have one.
I was always careful using the crank, though, because a lot of people have broken their hands or wrists when the crank kicks back. My grandfather broke his right hand cranking his car, and it put an end to his career as a court reporter.
[Re: TheManShed]
#190127 09/03/0912:22 PM09/03/0912:22 PM
Ha! That's funny. I have a set of dual Weber 40 IDFs on my '66 bus (2110cc) and when we go up in elevation I always pull over and give them a little adjustment. J
[Re: SurfCityRacing]
#190128 09/03/0912:23 PM09/03/0912:23 PM
Motorcycle kick starters can be brutal on ya in a kick back as well.. i had a 750 with both elec and kick starts but while serving in Greece (Crete) my regulator rectifier went bad and parts were non existent so i had to kick every time..
[Re: pgp]
#190131 09/03/0912:37 PM09/03/0912:37 PM
Between my dad and I we have owned many british cars. Currently have a '52 MGTD, '74 Midget, '78 midget, and a '79 MGB. Also have an '87 300zx lowered with nitro. Worked on many SU carbs in the past. My fav was the XKE Jag inline 12 with six of those babys to syncronize.
[Re: TurboCat]
#190145 09/03/0903:10 PM09/03/0903:10 PM
I gotta get one of these to tow the boat to the beach
That must be the "sport" option (520hp Porsche 993 twin-turbo drivetrain)
My first car was a 74 bus. We dumped all the smog stuff first, then after about 50K miles we rebuilt the engine and re geared the trans axel. Helps to have friends who worked for VW. Punched it out to a 2.2 liter, dumped the Solex Carbs for Weber etc.....
CHP said they clocked me 90 MPH and I still had some room on the tach for more.
[Re: ]
#190162 09/03/0904:50 PM09/03/0904:50 PM
