Rating: 4
Page 8 of 10 1 2 6 7 8 9 10
Re: Alter Cup Updates from water [Re: PTP] #194291
10/23/09 07:34 AM
10/23/09 07:34 AM
I think I'll go put some tape on my spreader tips today, keep them from slipping upwards! Ouch!!
Re: Alter Cup Updates from water [Re: Timbo] #194293
10/23/09 07:46 AM
10/23/09 07:46 AM
andrewscott
andrewscott
is "slipping" common or even possible without some impact?
i had one spreader slip down (on my TheMightyHobie18) after a capsize (or demasting, or lowering the mast on the beach) and was able to smack it back into the right spot. but it needed a good amount of force.
Re: Alter Cup Updates from water [Re: ] #194295
10/23/09 07:49 AM
10/23/09 07:49 AM
I don't think it's common but it might have been hit by a flying body part on an earlier capsize. Either way, I'm taping mine today!
Re: Alter Cup Updates from water [Re: Timbo] #194301
10/23/09 07:55 AM
10/23/09 07:55 AM
can someone post the pic of the spreaders being out of whack? it can have phil's gooberness over it, I don't care.
Re: Alter Cup Updates from water [Re: Wouter] #194303
10/23/09 08:02 AM
10/23/09 08:02 AM
Originally Posted by Wouter
In my opinion the simple steel Harken small blocks are best in this use.
these work great with a line from luff track through the center of the block to the other side and a pigtail from the tang.
Re: Alter Cup Updates from water [Re: PTP] #194305
10/23/09 08:10 AM
10/23/09 08:10 AM
I have no count on how many blocks I have ruined with the spi halyard. Oversize or steel is a good move.
Re: Alter Cup Updates from water [Re: PTP] #194306
10/23/09 08:12 AM
10/23/09 08:12 AM
That's what I put on two years ago, no problems since, but I sail mostly in fresh water.
I think the salt water might be an issue with the original Ronstan plastic blocks, salt and sand eating into it and causing problems? Or is there just too much room between the sheeve and the wheel and the halyard gets in there?
Re: Alter Cup Updates from water [Re: Rolf_Nilsen] #194307
10/23/09 08:13 AM
10/23/09 08:13 AM
Last season I have seen all of them explode, no matter the make or type.
Just something to check a lot, it always fails at the worst times though,
like that time I had to take the spi down and the halyard slid of the block and jammed!
Re: Alter Cup Updates from water [Re: ] #194308
10/23/09 08:17 AM
10/23/09 08:17 AM
Dunedin Causeway, FL
David Parker Offline
Was the boat whose spreader slipped the same boat that had to be laid over on its side to fix the spin block? Could the spreader have been displace during that tip-over?
The spin block failure happened when the skinny halyard jammed between the sheave and the housing. I don't think the block "blew up".
Re: Alter Cup Updates from water [Re: David Parker] #194309
10/23/09 08:30 AM
10/23/09 08:30 AM
Portland, Maine
ThunderMuffin Offline OP
Portland, Maine
When I chartered my boat to Mischa for the 2007 T500, he put the tiniest little harken bullet block as the spin turning block on the mast. I was like "holy crap you trust that thing?!"
Its still going strong. Same one. I check it everytime I rig up the boat and its still as good as the day he put it on there.
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194310
10/23/09 08:32 AM
10/23/09 08:32 AM
I have put those on 5 boats and they all haven't have a problem. I guess if you decide to taper the halyard down to 1/16 line or some siliness like that then there might be a problem.
Re: Alter Cup Updates from water [Re: Brett Goodall] #194311
10/23/09 09:02 AM
10/23/09 09:02 AM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
Originally Posted by AUS-CAT
Button knot would be more reliable, but the dyneema is so slippery we decided to use the ball... a plain knot might be the way to go.
There are plenty of knots with a good enough nip to hold in dyneema. As a class, lanyard knots might retain their shape under load better than button knots, but I'm partial to the form of a 2-strand 8-part button. That's what I put in my soft shackles.
Eric
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194317
10/23/09 09:40 AM
10/23/09 09:40 AM
Pic, or do you know which model?
Re: Alter Cup Updates from water [Re: Rolf_Nilsen] #194319
10/23/09 09:47 AM
10/23/09 09:47 AM
Portland, Maine
Portland, Maine
its the tiniest little metal bodied blocks that harken makes I believe.
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194320
10/23/09 09:50 AM
10/23/09 09:50 AM
this small?
Re: Alter Cup Updates from water [Re: PTP] #194321
10/23/09 09:53 AM
10/23/09 09:53 AM
Is this the one?
http://www.harkenstore.com/uniface.urd/scpdinw1.ShowProd?B4RPMEB9Y98P5S
Dang, we are hijacking what was a really good thread.
Re: Alter Cup Updates from water [Re: PTP] #194322
10/23/09 09:53 AM
10/23/09 09:53 AM
Portland, Maine
Portland, Maine
that looks like it.
Also note that during the T500, I had to install a second inline cleat on the front beam to keep the halyard from slipping - and the head of my chute blew up - but the block is still ok.
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194323
10/23/09 10:04 AM
10/23/09 10:04 AM
We broke two or three of those on the Tornado when sailing with 200kgs crew weight (we also broke cleats and other stuff).
I think this little baby was what finally held together but things are getting a little fuzzy: http://www.harkenstore.com/uniface.urd/scpdinw1.ShowProd?409Z56LC3VXJE
Wouters suggestion is probably best if your halyard fits:
http://www.harkenstore.com/uniface.urd/scpdinw1.ShowProd?B4RPMEB9Y9AN94
Re: Alter Cup Updates from water [Re: Rolf_Nilsen] #194326
10/23/09 10:19 AM
10/23/09 10:19 AM
I like this one because you can thread the line through the center of the block and will then keep it in a nice alignment
Re: Alter Cup Updates from water [Re: ThunderMuffin] #194330
10/23/09 11:21 AM
10/23/09 11:21 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Tad,
Do you have a picture of the second cleat? How its arranged? I'm having a problem with my spin halyard at the moment.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
0 registered members (), 192 guests, and 14 spiders.
Posts267,059
