| Re: Batten Tension
[Re: TEH]
#195750 11/10/09 07:59 AM 11/10/09 07:59 AM |
Posts: 976 France | One was simply where do you put the stick when taking down the spin? (I sail single handed). Throw it overboard. Let it drag behind the boat. I throw it away when I raise the spi and if I don't need to go on the wire I leave it there for all the downwind leg, steering with the rudder bar. I use my feet on the rudder bar to steer while I set and douse the spi. | | | Re: Batten Tension
[Re: Dazz]
#195797 11/10/09 12:41 PM 11/10/09 12:41 PM | andrewscott
| andrewscott
Unregistered | Am i the only one completely releasing the tension from ALL the battens every week? I don't think I could sleep right with them under tension all week....
barbarians! YEA YOU BARBARIANS!!!! haha,... most of the guys i sail with don't EVER release them during the week, nor do they even take the spin off the boat (out of the snuff) during storage. I am in the same boat except i have done a bunch of testing with my sail/tension this year, and i put a tarp over my snuffer bag to protect the bag/sail inside from UV | | | Re: Batten Tension
[Re: ]
#195807 11/10/09 01:04 PM 11/10/09 01:04 PM |
Posts: 1,246 Orlando, FL | I am in the same boat except i have done a bunch of testing with my sail/tension this year, and i put a tarp over my snuffer bag to protect the bag/sail inside from UV
Conclusion?
USA 777
| | | Re: Batten Tension
[Re: tback]
#195948 11/11/09 09:53 AM 11/11/09 09:53 AM | andrewscott
| andrewscott
Unregistered | I conclude that adjusting tension was needed for my sail/mast.. i had overly tight battens and it moved my draft to far forward and caused a ton of grief when tacking in light air. it also made raising the sail much harder. i have since lightened the tension and those problems are gone. i do not release my battens when not in use.. i sail every weekend and do all i can to reduce set up/tear down time (still takes about 70 min). I am positive i would extend the life of my spinnaker by 30-50% if i removed it from the snuffer, washed it down, hung it to dry and flaked it.. but i live in an apartment, and that isn't easy to do. i am sure i would extend the life of the sail by 5-10% if i did the same (release battens, wash, dry) but dont have the facilities to do that either... either way.. i will have to buy new sails every few years regardless.. and would rather sail more, and rig less... | | | Re: Batten Tension
[Re: Rolf_Nilsen]
#195960 11/11/09 11:20 AM 11/11/09 11:20 AM | andrewscott
| andrewscott
Unregistered | I do not have any conclusive data but:
it is recommended by every sail maker (that i have seen or read from) that washing the salt off your sails and drying will extend the sails life. it seems very reasonable to me. Also i have read on many occasions to release/remove the battens for long term storage.
Almost everyone swears that removing/washing/drying and flaking will extend the life of a spinnaker (significantly) and it seems reasonable to me...
but as i said... I would rather sail more, and rig less... | | | Re: Batten Tension
[Re: ]
#195964 11/11/09 11:37 AM 11/11/09 11:37 AM |
Posts: 976 France | [...]i put a tarp over my snuffer bag to protect the bag/sail inside from UV Well, I store my boat mast up, with the spi in the snuffer. My current snuffer bag is completely cooked by UV exposure after 14 months (and that's in the UK!). So I've ordered a new snuffer bag which is UV resistant, hopefully it will last a lot longer without changing the way I store my boat... | | | Re: Batten Tension
[Re: Smiths_Cat]
#196003 11/11/09 05:06 PM 11/11/09 05:06 PM | andrewscott
| andrewscott
Unregistered | good info... as i said.. i leave the battens in.. and i leave the spin in the bag...
Pepin, i cooked my firt spin bag in about 9 months. i now coat with 303 (it claims to be spf40) and use a very small tarp that covers the tube (with sail inside). this takes about 30 seconds for me to secure. | | | Re: Batten Tension
[Re: Smiths_Cat]
#196547 11/17/09 06:02 AM 11/17/09 06:02 AM |
Posts: 1,383 Kingston SE South Australia | I've still got my A cat sail that I bought with warped fibrefoam battens from being stored in the sail long term. I had the battens taped to straight timber for 6 months and they still twist up.
229
guests, and 120
Mod | | Forums26 Topics22,405 Posts267,057 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
