| Spin pole Tack line exit block #197919 12/01/09 11:46 AM 12/01/09 11:46 AM | andrewscott
| andrewscott
Unregistered | I have had a couple issues with my tack line at pole end (the interenal block turns sideways) and i think i am going to switch to this style block. Any pros or cons (or comments) about using this style? Thanks for the input in advance | | | Re: Spin pole Tack line exit block
[Re: ]
#197921 12/01/09 11:56 AM 12/01/09 11:56 AM |
Posts: 1,382 Essex, UK | Make sure you put it in right way round! A colleague with a recently purchased used Inter 18 was having a hell of a time with his sets and douses. After a few weeks he asked me if I'd take a look. At first I couldn't see any problems - it all looked OK, but there was a lot of friction generally. Then I just glanced at the tack block while saying that I didn't use one like that and spotted that it was rivetted wrong way round and was getting all chewed up from the line jumping off. We turned it round and AFAIK he's happy with it.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Spin pole Tack line exit block
[Re: ThunderMuffin]
#197922 12/01/09 11:57 AM 12/01/09 11:57 AM |
Posts: 1,152 tampa, fl | What Tadd said is a big concern. I had a tack line come apart during the Tybee because of fraying from that type of block. I would not use it again.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Spin pole Tack line exit block
[Re: ksurfer2]
#197931 12/01/09 12:59 PM 12/01/09 12:59 PM | andrewscott
| andrewscott
Unregistered | What Tadd said is a big concern. I had a tack line come apart during the Tybee because of fraying from that type of block. I would not use it again. what would you use? | | | Re: Spin pole Tack line exit block
[Re: ]
#197932 12/01/09 01:00 PM 12/01/09 01:00 PM |
Posts: 12,310 South Carolina | I use the double micro (H368) in the pole and a small air-block (H340) on an eyestrap with a standing spring on the end. with the double thru-deck placed 6 or 8 inches away from the block on the eyestrap (on top at the very end of the pole), the thru-deck doesn't see any significant side angles...which they're not designed to handle. Haven't experienced any chaffing issues with it.
Jake Kohl | | | Re: Spin pole Tack line exit block
[Re: ]
#197933 12/01/09 01:00 PM 12/01/09 01:00 PM | andrewscott
| andrewscott
Unregistered | PS thanks guys for the data | | | Re: Spin pole Tack line exit block
[Re: ]
#197934 12/01/09 01:17 PM 12/01/09 01:17 PM |
Posts: 1,152 tampa, fl | What Tadd said is a big concern. I had a tack line come apart during the Tybee because of fraying from that type of block. I would not use it again. what would you use? I use one of these: http://www.gobarefootstudio.com/TackGuide_09.html
[Re: ksurfer2]
#197936 12/01/09 02:17 PM 12/01/09 02:17 PM |
Posts: 976 France | I do use a similar CNC machined piece of aluminum, not made by those guys, but really similar. I only use the middle hole however for all three lines to go in.
[Re: pepin]
#197938 12/01/09 02:27 PM 12/01/09 02:27 PM | andrewscott
| andrewscott
Unregistered | ahhh yes.. we covered that.. it looks fantastic but i have a 2" pole so the snu version wont work and i think Pepin also stated he had a 1.5".
PS Pepin, I found a super "PLUG" for the cookie cutter end.. thanks for that tip! | | | Re: Spin pole Tack line exit block
[Re: ]
#197954 12/01/09 04:56 PM 12/01/09 04:56 PM |
Joined: Feb 2005 Posts: 4,118 Northfield Mn Karl_Brogger
Posts: 4,118 Northfield Mn | it looks fantastic but i have a 2" pole so the snu version wont work Have one made. Stop at a local machinest's shop, show em a picture. It'd take longer to put the stock in the lathe than it would to turn it. Aluminum is like butter, I could damn near turn one by hand with my wood lathe. Drill the center hole yourself to save him some time as well. | | | Re: Spin pole Tack line exit block
[Re: Dlennard]
#197964 12/01/09 07:00 PM 12/01/09 07:00 PM |
Posts: 4,118 Northfield Mn | I have turned a few on a wood lathe and it took about an hour. Most of the time was spent making the inside hollow. and I did drill it out first. Really. I was half joking when I mentioned it. Did you use std knives, or something else? How did you hold it in place? I don't have a chuck to put something like that in, but I was thinking about picking something up just so I could turn simple aluminum items like this. | | | Re: Spin pole Tack line exit block
[Re: Karl_Brogger]
#197989 12/02/09 08:52 AM 12/02/09 08:52 AM | andrewscott
| andrewscott
Unregistered | Karl, please turn me a plug! (NOT OUT OF ICE) You da man' | | | Re: Spin pole Tack line exit block
[Re: Dlennard]
#197993 12/02/09 09:41 AM 12/02/09 09:41 AM |
Posts: 807 Hillsborough, NC USA | I don't know the name of all the tools. I think I just used a chisel point tool about a 1/4 wide and used the bridge to balance the tool. Aluminum can be turned on a wood lathe with hand tools. A piece this size could be mounted on a bowl chuck with either small jaws or pin jaws. The chuck can grip the piece either by the outside (for boring out the center) or by the inside (for shaping the exterior. The cutting tools are all called "chisels", but there are many types. It sounds as if you used a "parting tool" or a very small scraper. I think I'd go for a scraper. You brace the chisel on the "tool rest", after adjusting the "banjo". You can also use a file for final shaping, and sandpaper to get a nice finish. Now you know Regards, Eric | | | Re: Spin pole Tack line exit block
[Re: Isotope235]
#197994 12/02/09 09:46 AM 12/02/09 09:46 AM |
Posts: 5,525 | I think I'd try pouring some thickened epoxy into a mold. My epoxy is very old (who knew it had a shelf life).
Maybe I should just keep a few epoxy billets around.
Pete Pollard Blade 702
175
guests, and 109
Mod | | Forums26 Topics22,405 Posts267,058 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
