| Re: Spin pole Tack line exit block
[Re: Dlennard]
#197999 12/02/09 10:02 AM 12/02/09 10:02 AM |
Posts: 3,906 Clermont, FL, USA | Where do you get the aluminum stock?
[Re: David Ingram]
#198000 12/02/09 10:08 AM 12/02/09 10:08 AM |
Posts: 12,310 South Carolina | Where do you get the aluminum stock? I would recommend www.mcmaster.com - super quick shipping and reasonable prices for small quantities of raw materials. A standard 6061 alloy would work just fine.
Jake Kohl | | | Re: Spin pole Tack line exit block
[Re: Dlennard]
#198025 12/02/09 03:26 PM 12/02/09 03:26 PM |
Posts: 2,490 On the Water | We have a Metal Supermarket franchise in my area. Most items are in stock, local and cheap.
Philip USA #1006 | | | Re: Spin pole Tack line exit block
[Re: ThunderMuffin]
#198091 12/03/09 02:58 PM 12/03/09 02:58 PM | andrewscott
| andrewscott
Unregistered | thats pretty neat.. are there 24 other people with 2" poles interested? | | | Re: Spin pole Tack line exit block
[Re: ]
#198094 12/03/09 03:28 PM 12/03/09 03:28 PM |
Posts: 807 Hillsborough, NC USA | thats pretty neat.. are there 24 other people with 2" poles interested? Is 2" the inside or outside diameter of your pole? I might be interested in making one (or more) of these if I had all the desired dimensions (Overall length, outside diameter, tenon length, tenon diameter, tack line hole diameter, counterbore diameter, counterbore length - I assume the inside and outside edge radii are not critical). Regards, Eric | | | Re: Spin pole Tack line exit block
[Re: Isotope235]
#198104 12/03/09 05:22 PM 12/03/09 05:22 PM |
Posts: 12,310 South Carolina | I've got a Solidworks drawing somewhere I drew up for those...I made a couple myself (though I don't use one). I'll see if I can find that drawing tomorrow and post it.
[Re: ]
#198134 12/03/09 10:19 PM 12/03/09 10:19 PM |
Posts: 1,911 South Florida & the Keys | If I had a 2" pole I would keep it to myself, if you know what I mean.
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Spin pole Tack line exit block
[Re: arbo06]
#198135 12/03/09 10:22 PM 12/03/09 10:22 PM |
Posts: 1,911 South Florida & the Keys | The OD on the "spinnaker pole" of the ARC21 is 2". They used a material that looks like delrin for the tack guide. It is 4 years old, lightly used and has no signs of wear. Maybe you can order it from Aquarius Sail. Call them, they are good folks.
[Re: arbo06]
#198163 12/04/09 09:10 AM 12/04/09 09:10 AM | andrewscott
| andrewscott
Unregistered | If I had a 2" pole I would keep it to myself, if you know what I mean. I have a 13' pole.. with a 2" OD... slightly different... | | | Re: Spin pole Tack line exit block
[Re: waterbug_wpb]
#198482 12/07/09 07:51 PM 12/07/09 07:51 PM |
Posts: 1,200 Vancouver, BC | I've had the standard single thru deck fold up on my in the spin tack line application...though it might have been due to the rivet pulling through the carbon pole first. Here is my current setup...basically a Harken hi-load wire block fits through an opening in the top side of the pole end. It is lashed with vectran to the vertical carbon post. The post protrudes out the top so that my pole end stay can loop over it (thereby maximizing the down-angle to the bow tips) Has worked flawlessly for a few regattas now. More pics starting with this one: Marstrom Rigging Shots
[Re: Tornado]
#198511 12/08/09 09:43 AM 12/08/09 09:43 AM | andrewscott
| andrewscott
Unregistered | thanks Mike. i was originally going for a similar design but didn't have power at my boat parking so i had to have our local sail shop do it.. and he didn't do it as requested. I think i am going to try and modify what he did to emulate this... but if it doesn't fix the problem.. i think i will try what Jake has... a double thru deck exit block and an external block on the end of the pole. | | | Re: Spin pole Tack line exit block
[Re: pgp]
#198534 12/08/09 12:02 PM 12/08/09 12:02 PM |
Posts: 805 Gainesville, FL 32607 USA | Pete- Why not imbed a piece of stainless steel tubing in the epoxy? You could bend it first to point in the correct direction. It does not matter if your epoxy is old. (My half-used West System epoxy is at least 25 years old and still good. The price was right- donated to me)
236
guests, and 133
Mod | | Forums26 Topics22,405 Posts267,057 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
