Page 2 of 3 1 2 3
Re: Spin pole Tack line exit block [Re: Dlennard] #197999
12/02/09 10:02 AM
12/02/09 10:02 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Where do you get the aluminum stock?
F18 USA 242
http://www.solarwind.solar
Re: Spin pole Tack line exit block [Re: David Ingram] #198000
12/02/09 10:08 AM
12/02/09 10:08 AM
I would recommend www.mcmaster.com - super quick shipping and reasonable prices for small quantities of raw materials. A standard 6061 alloy would work just fine.
Re: Spin pole Tack line exit block [Re: Jake] #198004
12/02/09 10:22 AM
12/02/09 10:22 AM
McMaster-Carr is da' bomb.
Re: Spin pole Tack line exit block [Re: Jake] #198005
12/02/09 10:23 AM
12/02/09 10:23 AM
pgp Offline
pgp  Offline
+1
Pete Pollard
Blade 702
Re: Spin pole Tack line exit block [Re: pgp] #198014
12/02/09 01:02 PM
12/02/09 01:02 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
I got mine at speedymetals.com
Re: Spin pole Tack line exit block [Re: Dlennard] #198025
12/02/09 03:26 PM
12/02/09 03:26 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
We have a Metal Supermarket franchise in my area. Most items are in stock, local and cheap.
Philip
USA #1006
Re: Spin pole Tack line exit block [Re: P.M.] #198073
12/03/09 12:20 PM
12/03/09 12:20 PM
waynemarlow Offline
waynemarlow  Offline
Wouldn't even bother to buy a bit of billet aluminium, most machine shops will have a piece knocking around from a previous job, should be way less than hour total machine time from starting the job to finishing if done freehand, would take about 20 minutes set up time for CNC and about 5 minutes machine time.
Re: Spin pole Tack line exit block [Re: waynemarlow] #198075
12/03/09 12:43 PM
12/03/09 12:43 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
I went to a machine shop and it was around 1hr plus metal which was around 100.00. I bought 1 foot of solid round aluminum with shipping for 15.00 and have already made three and sold two. I still have enough to make 3 or 4 more. The one off in a machine shop cost a lot. The price that is listed on this site is pretty good in my opinion.
Re: Spin pole Tack line exit block [Re: Dlennard] #198090
12/03/09 02:53 PM
12/03/09 02:53 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I can make them for $38 a pop at emachineshop.com
If I order 25. Less if I order more.
Re: Spin pole Tack line exit block [Re: ThunderMuffin] #198091
12/03/09 02:58 PM
12/03/09 02:58 PM
andrewscott
andrewscott
thats pretty neat.. are there 24 other people with 2" poles interested? smile
Re: Spin pole Tack line exit block [Re: ] #198094
12/03/09 03:28 PM
12/03/09 03:28 PM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
Is 2" the inside or outside diameter of your pole? I might be interested in making one (or more) of these if I had all the desired dimensions (Overall length, outside diameter, tenon length, tenon diameter, tack line hole diameter, counterbore diameter, counterbore length - I assume the inside and outside edge radii are not critical).
Eric
Re: Spin pole Tack line exit block [Re: Isotope235] #198104
12/03/09 05:22 PM
12/03/09 05:22 PM
I've got a Solidworks drawing somewhere I drew up for those...I made a couple myself (though I don't use one). I'll see if I can find that drawing tomorrow and post it.
Re: Spin pole Tack line exit block [Re: ] #198134
12/03/09 10:19 PM
12/03/09 10:19 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
If I had a 2" pole I would keep it to myself, if you know what I mean.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Spin pole Tack line exit block [Re: arbo06] #198135
12/03/09 10:22 PM
12/03/09 10:22 PM
arbo06 Offline
arbo06  Offline
The OD on the "spinnaker pole" of the ARC21 is 2". They used a material that looks like delrin for the tack guide. It is 4 years old, lightly used and has no signs of wear. Maybe you can order it from Aquarius Sail. Call them, they are good folks.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Spin pole Tack line exit block [Re: arbo06] #198163
12/04/09 09:10 AM
12/04/09 09:10 AM
andrewscott
andrewscott
I have a 13' pole.. with a 2" OD... slightly different... smile
Re: Spin pole Tack line exit block [Re: ] #198168
12/04/09 09:43 AM
12/04/09 09:43 AM
I can't bottom out a tuna can, but I can raise hell with the edges! laugh
Re: Spin pole Tack line exit block [Re: Karl_Brogger] #198203
12/04/09 01:12 PM
12/04/09 01:12 PM
like a cheese wheel?
Re: Spin pole Tack line exit block [Re: waterbug_wpb] #198482
12/07/09 07:51 PM
12/07/09 07:51 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
I've had the standard single thru deck fold up on my in the spin tack line application...though it might have been due to the rivet pulling through the carbon pole first.
Here is my current setup...basically a Harken hi-load wire block fits through an opening in the top side of the pole end. It is lashed with vectran to the vertical carbon post. The post protrudes out the top so that my pole end stay can loop over it (thereby maximizing the down-angle to the bow tips)
Has worked flawlessly for a few regattas now.
More pics starting with this one:
Marstrom Rigging Shots
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Re: Spin pole Tack line exit block [Re: Tornado] #198511
12/08/09 09:43 AM
12/08/09 09:43 AM
andrewscott
andrewscott
thanks Mike. i was originally going for a similar design but didn't have power at my boat parking so i had to have our local sail shop do it.. and he didn't do it as requested. I think i am going to try and modify what he did to emulate this... but if it doesn't fix the problem.. i think i will try what Jake has... a double thru deck exit block and an external block on the end of the pole.
Re: Spin pole Tack line exit block [Re: pgp] #198534
12/08/09 12:02 PM
12/08/09 12:02 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
Pete- Why not imbed a piece of stainless steel tubing in the epoxy? You could bend it first to point in the correct direction. It does not matter if your epoxy is old. (My half-used West System epoxy is at least 25 years old and still good. The price was right- donated to me)
Dacarls:
Page 2 of 3 1 2 3
0 registered members (), 175 guests, and 109 spiders.
Posts267,058
