Nacra 5.5 Dolphin striker failed #198645
12/09/09 10:45 AM
12/09/09 10:45 AM
Hong Kong & Thailand
rustyhelms Offline OP
This was an awesome; dolphin striker v bar was first failed then the mast plunged into front cross beam and create a crater....it was happened during port reach, 18 kts wind.
Anyone had same experience before? Is it worth to replace aluminium V bar with stainless steel?
N5.5 4.JPG (301 downloads)
/Skuly
H.Tiger # 2019
N 5.5 sl spi #454
Re: Nacra 5.5 Dolphin striker failed [Re: rustyhelms] #198671
12/09/09 01:12 PM
12/09/09 01:12 PM
was that an aluminum striker bar? I thought all nacra bars were stainless steel?
Re: Nacra 5.5 Dolphin striker failed [Re: Jake] #198717
12/09/09 04:59 PM
12/09/09 04:59 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
I had the same thing happen to my P19. I was lucky and saved my beam. Just had to replace the aluminum bar. This is a wear item. That aluminum bends like a tin can and eventually fails at the first bolt. Easy inspection. If you see a crack developing near that first bolt buy a new bar.
Mike Hill
N20 #1005
Re: Nacra 5.5 Dolphin striker failed [Re: Mike Hill] #198719
12/09/09 05:33 PM
12/09/09 05:33 PM
japan
erice Offline
erice  Offline
japan
presumably started from a stress crack at the bend where it failed, nacra owners take note and check
is the spin an after market fitment?
doubling up the sail area from what the boat was originally designed for may have led to excessive flexing in the strap
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Nacra 5.5 Dolphin striker failed [Re: rustyhelms] #198725
12/09/09 06:33 PM
12/09/09 06:33 PM
catandahalf Offline
catandahalf  Offline
There should have been a compression tube in the main beam to absorb the beam - loading from the striker rod (stainless) and the mast base. I saw no evidence in your photos of striker bar (aluminum) failure; therefore, I am presuming the mast/rig pressure caved in the main beam. Were you sailing with a tight or loose rig?
That attachment fitting for the spin strut may have weakened the main beam at a very critical point. We used an aluminum windsurfing mast and snapped it onto the stainless striker rod, secured at the bridle foil. Our tack was internal. Our bag was on the deck - not in a snuffer.
Do you know a former NACRA 5.2 sailor, Nori Osada?
Re: Nacra 5.5 Dolphin striker failed [Re: catandahalf] #198732
12/09/09 08:16 PM
12/09/09 08:16 PM
the first picture shows the dolphin striker snapped where it attaches to the end of the main beam. I think you can also make out the compression tube still on the mast post laying on the trampoline in the second photo.
How many of you guys have aluminum dolphin strikers on your Nacras?
Re: Nacra 5.5 Dolphin striker failed [Re: Jake] #198738
12/09/09 08:55 PM
12/09/09 08:55 PM
catandahalf Offline
catandahalf  Offline
I stand corrected. We have always used aluminum on the earlier NACRA designs. I missed the details in the top photo. The new 20s and F 18s might be using stainless. I'm scratching my head:-)
My guess now is that salt water/corrosion and a loose rig/rod - fit through the main beam via the nuts for compression led to the bar failure. Now, what effect would a stainless bar have on the aluminum main beam other than add weight and electrolysis? Do not forget the four drilled holes for the spin strut.
One half inch of pre - bend in the main beam was good for us in the 5.5 SL "Golden Days." We kept the rig tight and the beer cold.
We even beat NACRA 6.0s on a good day - boat for boat (circa 1993).
Keep it Rollin' in 2010,
Bert
Re: Nacra 5.5 Dolphin striker failed [Re: catandahalf] #198743
12/09/09 09:34 PM
12/09/09 09:34 PM
Bert
I've just never seen an aluminum striker bar. Sure, there would be some additional electrolysis but not any more than with the striker post. The stainless has better fatigue resistance - particularly at bends. It would also tend to elongate at mounting holes more than shear like aluminum.
Re: Nacra 5.5 Dolphin striker failed [Re: Jake] #198744
12/09/09 09:51 PM
12/09/09 09:51 PM
Gainesville, FL 32607 USA
dacarls Offline
dacarls  Offline
This is classic aluminum part failure at a drilled-hole. Mini cracks develop on both sides of the hole due to flexing. Twink!
Does anyone remember the British Overseas Airways Comet airliners of the 1950s? Anodizing does not help.
Dacarls:
Re: Nacra 5.5 Dolphin striker failed [Re: dacarls] #198745
12/09/09 10:44 PM
12/09/09 10:44 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
I believe all of the round beams have aluminum striker bars. I have never seen a SS striker bar on the round beams as a factory setup. I ordered a new front beam a couple of years ago for the 5.8, it came with a new aluminum striker bar.
Philip
USA #1006
Re: Nacra 5.5 Dolphin striker failed [Re: P.M.] #198746
12/09/09 10:45 PM
12/09/09 10:45 PM
hm. I honestly can't recall what the striker looked like on my old 5.2 or the 6.0NA I had.
Re: Nacra 5.5 Dolphin striker failed [Re: Jake] #198748
12/09/09 11:13 PM
12/09/09 11:13 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
Just zoomed in on some pics of my '99 6.0... it had an aluminum striker too.
I could have sworn it was stainless but from the pictures it is clear it's aluminum... kinda scary to think about.
Haven't seen any failures like this on a N20 or F18 but I did see it happen to a 6.0 or 2.
Re: Nacra 5.5 Dolphin striker failed [Re: Jake] #198749
12/09/09 11:16 PM
12/09/09 11:16 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Here is the reason I replaced my beam and dolphin striker . . .
Philip
USA #1006
Re: Nacra 5.5 Dolphin striker failed [Re: P.M.] #198750
12/09/09 11:18 PM
12/09/09 11:18 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
and pictures from the bottom and the bar bolts . . .
Philip
USA #1006
Re: Nacra 5.5 Dolphin striker failed [Re: P.M.] #198755
12/10/09 02:48 AM
12/10/09 02:48 AM
japan
erice Offline
erice  Offline
japan
i notice that the bar that broke had very rounded edges
the bar on my 1982 5.2 has very sharp square edges
i took it all apart last year to treat corrosion but found no cracks
eric e
2009 weta tri - 294
Re: Nacra 5.5 Dolphin striker failed [Re: erice] #198756
12/10/09 03:23 AM
12/10/09 03:23 AM
Netherlands
DennisMe Offline
DennisMe  Offline
Netherlands
Sorry for what happened bu thanks very much for the heads up! Will check up on my 5.2 before I go sailing next season.
Dennis
Re: Nacra 5.5 Dolphin striker failed [Re: DennisMe] #198768
12/10/09 07:52 AM
12/10/09 07:52 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
A fact that has been missed is that the bar is probably 25 plus years old.
Re: Nacra 5.5 Dolphin striker failed [Re: Hullflyer1] #198839
12/11/09 04:34 PM
12/11/09 04:34 PM
TeamChums Offline
TeamChums  Offline
I noticed there is no teflon washer between the stainless washers and the cross beam. I added some on my N20 to help fight the electrolosis. I dont think Nacra sends them out that way, so if you have one, it's not a bad idea to add them.
Lee
Re: Nacra 5.5 Dolphin striker failed [Re: P.M.] #198940
12/14/09 08:13 AM
12/14/09 08:13 AM
Finally my buddy was odered the beam,striker v bar from Nacra dealer in Australia. Right now we done a temporary repair,weld,etc. while waiting for original parts. Not sure if the v bar failed becuase of too much load on the mast+after market spi (normally we use 19 sqft and on the day with light wind we put 21 sqft). I guess that aluminium v bar became stretch due to aging ,recalled that we can't keep max tension of v bar through stricker rod(we adjusted the rod's nut until mast ball was almost touching the beam!!)...that was before sh_t happened.
/Skuly
H.Tiger # 2019
N 5.5 sl spi #454
Re: Nacra 5.5 Dolphin striker failed [Re: P.M.] #198943
12/14/09 08:40 AM
12/14/09 08:40 AM
Oh exactly, it looks the same on my boat
/Skuly
H.Tiger # 2019
N 5.5 sl spi #454
0 registered members (), 236 guests, and 133 spiders.
Posts267,057
