| Re: Help finding a sailbox for a trailer
[Re: Kris Hathaway]
#199372 12/22/09 03:40 PM 12/22/09 03:40 PM |
Posts: 917 Issaquah, WA, USA | For a lower cost alternative, you can make a sailbox out of wood for under $100. Now making two, one for trailer, other for storage at Sail Sand Point. Boxes will be 11.5 ft by 2ft, 10in deep. Lid, 3/8in plywood, with 1 by 2 in edge. Sides and bottom 1/2 plywood. 1 by 2in framing with 2 by 4 ends. Paint inside and out with white semigloss exterior paint. Had the last one for over 20years, and sold with H-17 and trailer. Caleb | | | Re: Help finding a sailbox for a trailer
[Re: H17cat]
#199386 12/22/09 07:42 PM 12/22/09 07:42 PM |
Posts: 396 Annapolis Md. | Thanks Caleb. What grade of plywood do you use? I wonder about the weight though. Ed
Still hazey after all these beers. F-16 Falcon #212
[Re: LuckyDuck]
#199389 12/22/09 08:24 PM 12/22/09 08:24 PM |
Posts: 917 Issaquah, WA, USA | Thanks Caleb. What grade of plywood do you use? I wonder about the weight though. Ed All plywood, exterior grade. Standard construction grade on 1/2, sanded finish on 3/8 lid. Total weight about 150lbs, based on material list. Will weigh after completion. Caleb | | | Re: Help finding a sailbox for a trailer
[Re: Kris Hathaway]
#199405 12/23/09 02:43 AM 12/23/09 02:43 AM |
Posts: 1,459 Annapolis,MD | Are the lunchboxes long enough to hold an 11'3" spin pole? Kris - see Alec's trailer with dual TreyBoxes - one of them is modified to take long spin poles. Basically a length of PVC pipe with a cap attached to front end. I miss the trailer and TreyBoxes... I was hoping for a more elegant solution than strapping on a hard condom. Unfortunately, I think that there are few metal fabricators that have 12' breaks (bending machines) that would consider such low budget jobs. He, he, you said "elegant"... It's a short length that he attached to the front of the box, pole goes in box and into the protuberance. | | | Re: Help finding a sailbox for a trailer
[Re: Keith]
#199444 12/23/09 03:05 PM 12/23/09 03:05 PM |
Posts: 67 Daytona Beach | I made mine out of 1/4 inch birch ply Framed with 1X2 fir. Wrapped the outside in glass then gel coated it. Two coats of resin on the interior no glass. I put a 2 inch curve in the top for strength. I go 250 and no problems standing on it. Still Strong after 15 years. I backed the trailer into a tree without the boat on it and the 1 1/2 in galvanized support bar bent around the box. More than strong enough. I prefer and lipped slide on lid. You can get the lid out of the way. Get into the box then the boat is on the trailer and water tight. About $150 in material and 20 hours of labor.
Jeff Bowers Mystere 6.0(sometimes XL)
[Re: Jeff_Bowers]
#199445 12/23/09 03:15 PM 12/23/09 03:15 PM |
Posts: 5,590 Naples, FL | +1
I made mine out of "door skin" laid on a 1" x 1" wood skeleton and "painted" with polyester resin. Sat out in the weather for a few years with no problems. I had hinged doors on each end which rotted on the ends after about 2 years, but those were easily replaceable.
I think the whole shebang cost about $75 a few years back
[Re: Jeff_Bowers]
#199563 12/27/09 01:14 PM 12/27/09 01:14 PM |
Joined: Jan 2004 Posts: 196 Arkansas, USA CaptainKirt
Posts: 196 Arkansas, USA | You can also make a nice, cheap "box" from PVC/plastic pipe- either just a section of pipe w/ wooden ends/plastic end caps (use bunji to keep on or latches) or split pipe and use plywood for "floor"- join in middle to reduce cost and can cut a "hatch" (or two!) and/or wooden ''door" on end.
Kirt
Kirt Simmons Taipan, Flyer
[Re: ThunderMuffin]
#199580 12/28/09 09:57 AM 12/28/09 09:57 AM |
Posts: 5,590 Naples, FL | There are disadvantages to a box thats just too big.
Ever drop a drain plug in there and it rolled to the exact middle of the box? Pain in the butt to get it out! Not sure if I had that happen, but I can see your point. I had the doors on each end so I could open them with the boat on top... Maybe some sort of opening on the top would really facilitate access... But for $75 all in, it was a good temporary solution (this was way before you started making boxes, by the way) for a few years. Couldn't you just tip the trailer up to help the drain plug roll to the low side?
[Re: waterbug_wpb]
#199583 12/28/09 10:17 AM 12/28/09 10:17 AM |
Posts: 5,525 | If you build your own, be mindful of ample clearance for the dolphin striker, at all angles.
Don't ask. . .
Pete Pollard Blade 702
[Re: pgp]
#199615 12/28/09 05:46 PM 12/28/09 05:46 PM |
Posts: 196 Arkansas, USA | Offsetting the box to one side can help with dolphin striker clearance depending on the box- Don't ask me how I know--
Kirt
[Re: DVL]
#199622 12/28/09 07:30 PM 12/28/09 07:30 PM |
Posts: 2,844 42.904444 N; 88.008586 W | I've built two different boxes out of wood. (Two different boats and trailers). The first was bascially 3/4 inch marine plywood. Treated 2x4's, SS screws, etc.
Trailer shapes are basically a rectangle with a triangle, or trapezoid on the front end of it.
I always built using all available space, as in the rectangle 4' x 8', by 12" high, with an additional 4' base, by 4' sides, by ~ 2ft front trapezoid. You can keep 2 set of sails, several poles, extra everything, etc. in a bos with this much Sq. Ft.
By second box was built much lighter, out of of 2x2's frame 12' long, x 4' wide (fender to fender), by 12" tall, A series of two doors, that always stayed relatively water tight. I used T=111 treated siding sheets, lasted for years, never rotted. It had a spine in the middle, so you could easily stand on it, dance on it, etc. The guy I sold it to took it off, not really sure why, it was very functional. It was the the 'table' at many a regatta on the Tx Gulf coast for skippers meetings, award ceremonies, and many an after regatta dinner table, etc.
I always strapped the cat wheels to the bows, underneath in front of the box, lock to the trailer, an never had a problem with it.
You have had some great suggestions, go for it!
F-18 Infusion #626- SOLD it!
[Re: H17cat]
#200171 01/09/10 12:33 AM 01/09/10 12:33 AM |
Posts: 917 Issaquah, WA, USA | Thanks Caleb. What grade of plywood do you use? I wonder about the weight though. Ed All plywood, exterior grade. Standard construction grade on 1/2, sanded finish on 3/8 lid. Total weight about 150lbs, based on material list. Will weigh after completion. Switched to 1/4 in plywood on lid, 3/8 in plywood on sides, and bottom. Final weight 120 lbs. Caleb | | | Re: Help finding a sailbox for a trailer
[Re: H17cat]
#200179 01/09/10 09:44 AM 01/09/10 09:44 AM |
Posts: 5,525 | I used 1/4" construction grade ply, and aluminum channels for edges and corners. It required some internal bracing. I wanted access when the boat is on the trailer, so there are doors at both ends and a sliding hatch on top at one end. This has not proved entirely satisfactory, due to leakage, but a cheap tarp from Lowe's has solved that.
[Re: alsail]
#200232 01/10/10 02:23 PM 01/10/10 02:23 PM | andrewscott
| andrewscott
Unregistered | sweet~ and you can be buried in it when your "all done" | | |
330
guests, and 33
