| Re: Rudder toe in
[Re: DanWard]
#20282 06/05/03 10:17 PM 06/05/03 10:17 PM |
Posts: 364 | With toe-in and a bit of weather helm, the windward rudder runs straight while the leeward one carries load. This was helpful on both of my Nacras (5.O and 5.5u) with their large rudders, but parallel is working better on the Prindle 19. sail fast
Andrew Tatton
Nacra 20 "Wiggle Stick" #266
Nacra 18 Square #12
| | | Re: Rudder toe in
[Re: DanWard]
#20283 06/06/03 07:34 AM 06/06/03 07:34 AM |
Posts: 117 Northern VA | On a 16 with the asymmetric hull, the toe-in allows the leeward rudder to "smooth" the flow coming off the curve of the inside hull. When the windward hull is flying, the windward rudder has little effect. On symmetric board boats, I believe that a very small amount of toe-in "preloads" the rudders so that they don't flop around as much. Given that almost all rudder systems have some slack; two perfectly parallel rudders would tend to "hunt" slightly, whereas a very slight angle of attack would tend to keep them from moving. I've been told that most new cars run very little toe-in (definitely less than 10 years ago) for less tire scrub, less drag, better mileage. However, IMO, they are a little "twitchier" on the road. From that standpoint, maybe a little rudder toe-in adds some "feel" even if does add drag. 1/8" total toe-in is only 1/16" per rudder; over a 12" chord works out that each rudder is at a 2.4 degree angle of attack. I'll leave it to someone else to figure out the extra drag caused by that angle. Most boats seem to have a little weather helm, anyway; even perfectly straight rudders might see that angle or more upwind. Chris | | | Re: Rudder toe in
[Re: jollyrodgers]
#20286 06/06/03 12:50 PM 06/06/03 12:50 PM |
Posts: 183 | We put a small amount of toe in on our boats, the reason we do this is that when you are sailing upwind, you will usually have an amount of weatherhelm, and so the rudders are travelling through the water pointing slightly to weather. If you have parallel rudders, and fly a hull, the windward rudder comes out, then when it re-enters the water it is not travelling straight, the result is usually that the rudder stalls, if have have a degree of toe-in this stops this.
regards
john p
John Pierce
[email]stealthmarine@btinternet.com /email] | | | Re: Rudder toe in
[Re: john p]
#20288 06/10/03 08:54 PM 06/10/03 08:54 PM | Anonymous
| Anonymous
Unregistered | Hi John, You have it right! Boats sail faster to windward with the rudders loaded, carrying some of the side force equal and opposite to the sail side force. The windward rudder in this situation which in moving into and out of the water vertically as the windward hull moves up and down will stall if it has the same angle of attack as the leeward rudder which is totally submerged. Reduce the angle of attack of the windward rudder a couple of degrees, rudder toe-in, and the windward rudder does not stall as it moves in and out of the water vertically and as the boat travels ahead. Good Sailing, Bill | | | Re: Rudder toe in #20290 06/11/03 03:17 AM 06/11/03 03:17 AM |
Posts: 183 | As you say Bill boats work better to windward if the rudder is used as an additional centreboard, this is why the Tornados all changed to very raked rigs during the late 90s, something you used years ago on your boats with the forward placed daggerboards.
regards
john
John Pierce
[Re: DanWard]
#20292 06/12/03 04:23 PM 06/12/03 04:23 PM |
Posts: 183 | Dan, the idea is that the windward rudder is running parallel to the direction of travel, so minimum drag, the leeward rudder is pointing high, giving you lift and balancing the weather helm, this will be the same in all wind strengths upwind, where parallel rudders would be a bit quicker is if you are sailing with no weather helm.
john
John Pierce
175
guests, and 87
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
