| 2010 F18 Rules Published #209163 04/22/10 07:21 AM 04/22/10 07:21 AM |
Joined: Jun 2001 Posts: 3,906 Clermont, FL, USA David Ingram OP
Posts: 3,906 Clermont, FL, USA | 2010 F18 Rules If you are an F18 Fleet Measurer you will want to take a look at the new drawings they are considerably more helpful than the old set.
| | | Re: 2010 F18 Rules Publised
[Re: David Ingram]
#209300 04/22/10 07:40 PM 04/22/10 07:40 PM |
Posts: 586 Hobart, Tasmania, Oz. | Thanks for that Dave,
I thought this was interesting:
(b) The cross section of each centreboard/daggerboard shall be symmetrical about its fore and aft centre line.
so that means we can have curved boards as long as we use symmetrical shapes like nacra's f20.
I also note we are allowed to use dyform diamonds, does anyone actually use them?
[Re: Dazz]
#209326 04/23/10 06:30 AM 04/23/10 06:30 AM |
Posts: 3,906 Clermont, FL, USA | It doesn't look like dyform is permitted to me. What are you seeing that indicates dyform diamonds are allowed?
F.6 STANDING RIGGING F.6.1 MATERIALS (a) The standing rigging shall be of stainless steel. (b) Fittings may be made from or include carbon fibre in their construction. 20 International Formula 18 Class Rules 2010 F.6.2 CONSTRUCTION (a) MANDATORY (1) A forestay and bridles of 1 x19 or 1 x 7 stranded wire of minimum diameter of 3mm. (2) Shrouds of 1 x 19 or 1 x 7 stranded wire of minimum diameter of 3mm. (3) Trapeze wires of stranded wire and minimum diameter of 2.5mm. (4) Dyform® or similar construction is prohibited. (b) OPTIONAL (1) A pair of diamond wires
[Re: Tony_F18]
#209330 04/23/10 06:56 AM 04/23/10 06:56 AM |
Posts: 3,906 Clermont, FL, USA | Yes a GPS receives data the same way the velocitek device does so it's out, please notice item (4) in the same section that allows an NOR to permit the devices for long distance races.
4) When required by the Notice of Race for long distance courses, organisers may require further equipment, such as VHF, mobile phone, GPS or tracking devices, Emergency Positioning Indicating radio beacons (EPIRB) devices, knife, mirror, whistle, flares, flashlights, first aid set.
[Re: David Ingram]
#209355 04/23/10 08:40 AM 04/23/10 08:40 AM |
Posts: 586 Hobart, Tasmania, Oz. | (b) OPTIONAL (1) A pair of diamond wires
Diamond wires are not compulsory, and there fore not part of the standing rigging. is that not fair?
[Re: Dazz]
#209356 04/23/10 08:48 AM 04/23/10 08:48 AM |
Posts: 3,906 Clermont, FL, USA | But if they are on the mast wouldn't they then be considered standing rigging?
[Re: David Ingram]
#209357 04/23/10 09:04 AM 04/23/10 09:04 AM |
Posts: 586 Hobart, Tasmania, Oz. | rigging, the wires, ropes, and chains employed to support and operate the masts, yards, booms, and sails of a vessel. Standing rigging is semipermanent, consisting mainly of mast supports, the fore-and-aft stays, and the stays running from the masthead to each side of the vessel. Running rigging includes the ropes, blocks, and other apparatus needed to brace the yards, make or take in sails, and hoist cargo
Most definitions seem to say standing rigging is stays and shrouds.
The Australian slang dictionary says standing rigging = time wasting...
[Re: Dazz]
#209358 04/23/10 09:08 AM 04/23/10 09:08 AM |
Posts: 3,906 Clermont, FL, USA | I've sent this question along with several others to the World Council for clarification. Things like this need to be crystal clear.
Additionally since diamond wires are specifically referenced in the standing rigging section of the rules I would interpret the intent of the rule to say if diamonds are on the boat they are considered standing rigging and therefore not permitted to be Dyform. My 2 cents.
[Re: David Ingram]
#209360 04/23/10 09:17 AM 04/23/10 09:17 AM |
Posts: 586 Hobart, Tasmania, Oz. | good work Dave!
I think if they wanted to ban dyform then they need a (2) Dyform® or similar construction is prohibited. in the diamond wire section. Because it is outside the mandatory section.
[Re: Dazz]
#209361 04/23/10 09:20 AM 04/23/10 09:20 AM |
Posts: 3,906 Clermont, FL, USA | I agree, wiggle room always leads to issues down the road.
[Re: David Ingram]
#209409 04/23/10 06:15 PM 04/23/10 06:15 PM |
Posts: 4,119 Northfield Mn | Yes a GPS receives data the same way the velocitek device does so it's out, please notice item (4) in the same section that allows an NOR to permit the devices for long distance races. Does a GPS actually recieve a signal telling the unit where it is? I thought it worked kinda like a VOR and triangulated its self off of radians from a whole mess of satellites. Grey area I know, but.... | | | Re: 2010 F18 Rules Publised
[Re: Karl_Brogger]
#209413 04/23/10 07:39 PM 04/23/10 07:39 PM |
Posts: 586 Hobart, Tasmania, Oz. | Global Positioning System satellites transmit signals to equipment on the ground. GPS receivers passively receive satellite signals; they do not transmit. GPS receivers require an unobstructed view of the sky, so they are used only outdoors and they often do not perform well within forested areas or near tall buildings. GPS operations depend on a very accurate time reference, which is provided by atomic clocks at the U.S. Naval Observatory. Each GPS satellite has atomic clocks on board.
There you go Karl, you learn something every day!
[Re: Karl_Brogger]
#209430 04/24/10 08:05 AM 04/24/10 08:05 AM |
Posts: 3,906 Clermont, FL, USA | Yes a GPS receives data the same way the velocitek device does so it's out, please notice item (4) in the same section that allows an NOR to permit the devices for long distance races. Does a GPS actually recieve a signal telling the unit where it is? I thought it worked kinda like a VOR and triangulated its self off of radians from a whole mess of satellites. Grey area I know, but.... It receives data and uses it, that alone makes it pretty clear to me. You just have to ask yourself does the device work without the "data" it receives? The rules also call the GPS out as something that 'could be' allowed on distance races if it was so stated in the NOR. Again, this one isn't grey.
| | | Re: 2010 F18 Rules Published
[Re: Dan_Delave]
#209548 04/26/10 01:14 PM 04/26/10 01:14 PM |
Posts: 3,906 Clermont, FL, USA | I just had a chat with the International Class President.
The intent of the 2010 rules was to get them into into SCR format and not to change any of the rules contained within.
Dyform is still out, the idea to try and control costs. Yes I know this the line in the sand and can be debated.
You can change rig tension while NOT racing. I have to send a request through the ISAF process to get the wording made more precise.
VHF for buoy racing is still out, reason being outside assistance could be had and cannot be regulated, same goes for iphones and other similar devices.
1 steering compass is required, this rule is unchanged.
1 tow line 15m long 6mm diameter is required, this rule is unchanged. I still don't know if the main sheet or other similar sheet can double as tow line, that answer is still pending. Can someone tell me if this is something that is checked at Worlds, has anyone ever been tossed for not having a tow line?
[Re: David Ingram]
#209561 04/26/10 02:19 PM 04/26/10 02:19 PM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | Can someone tell me if this is something that is checked at Worlds, has anyone ever been tossed for not having a tow line?
At the Worlds in France they were going to toss you for any rule that you did not meet. There was a run on paddles and compasses at all the sailing related stores, and they ran critically low on lead weights at the dive store. At that time they were able to use the main halyard as a tow line providing it was 5mm. I do not think that is allowed anymore, as they were going to discuss that at the follow up meeting. I would place money that the tow line is needed this year. I remember it was required to be 5mm then. It is 6mm now, but still the same 15 meters. There were teams tossed that came in 1 kg light after racing all day. I would not tempt them. Later, Dan | | | Re: 2010 F18 Rules Publised
[Re: Karl_Brogger]
#209646 04/27/10 02:44 PM 04/27/10 02:44 PM | andrewscott
| andrewscott
Unregistered | Yes a GPS receives data the same way the velocitek device does so it's out, please notice item (4) in the same section that allows an NOR to permit the devices for long distance races. Does a GPS actually recieve a signal telling the unit where it is? I thought it worked kinda like a VOR and triangulated its self off of radians from a whole mess of satellites. Grey area I know, but.... Get (your viper lovin butt) back to the F16 forum~! just kiddin, but you had it comin since you kicked me out of the hobie forum!
[Re: Tony_F18]
#209647 04/27/10 02:45 PM 04/27/10 02:45 PM | andrewscott
| andrewscott
Unregistered | But a sextant would be ok right? Only for night races | | | Re: 2010 F18 Rules Publised
[Re: F-18 5150]
#209682 04/27/10 11:16 PM 04/27/10 11:16 PM |
Posts: 3,293 Long Beach, California | Magnetism is not a "signal." It is a closed dipole of electric current.
[Re: John Williams]
#209860 04/29/10 04:39 PM 04/29/10 04:39 PM |
Posts: 71 | Magnetism is not a "signal." It is a closed dipole of electric current. Radio signals are also electro magnetic. They both transmit data (which is what the rule says). When I read the rule, I assumed it allowed GPS too. Really, a GPS is just a very accurate timing device. The satellites are just guiding beacons like stars. Furthermore the next rule says that a GPS may even be required without says that it is an exception. Which suggests that they are not against the rules. This is one rule that I object to because it outlaws a device that can be used for safety and promotional purposes. The rule should at least allow a GPS, EPIRB, and VHF radio so that you can be rescued in the case of an emergency. GPS's that log information for future playback can be very useful for coaching and showing people what happened at an event that they didn't attend (think about what they did with the America's Cup). I don't think it saves much either. The RRS already outlaw outside assistance. So, no one is getting an advantage. A GPS or VHF radio are far from cost prohibitive. Plus, for a lot of $$, it is possible to make an electronic device that measures speed and position with inertial guidance technology that does not receive or transmit anything. | | | Re: 2010 F18 Rules Publised
[Re: F18_VB]
#209862 04/29/10 05:16 PM 04/29/10 05:16 PM |
Posts: 3,906 Clermont, FL, USA | I guess it will have to be settled in the room.
[Re: David Ingram]
#209864 04/29/10 06:16 PM 04/29/10 06:16 PM |
Posts: 586 Hobart, Tasmania, Oz. | I agree with F18 VB, the GPS technology costs about the same as a digital compass anyway. I know the spirit of the rules is to keep costs down, but in this case i do believe the technology over the last 10 year years has reduced in cost to a point where it is now not an issue.
The other rule I have issue with is the ban on synthetic trapeze lines. It was fair enough when stainless wire was a fraction of the price of dyneema, but now in many areas the dyneema is actually cheaper. By the time you don't have to pay some one to swage up a set of lines it is now significantly cheaper to use synthetic.
How do we get these rules updated to reflect what is actually going on in the real world?
[Re: macca]
#209882 04/30/10 02:14 AM 04/30/10 02:14 AM |
Posts: 246 Kiel, Germany | A representative of the german class association told me the other day that the reason to ban signal receiving items is to avoid help from third parties. Imagine somebody on a hill or tower close to the regatta aera who can overlook the whole field, can watch out for wind changes, etc, ...
F18: C2 / A-Cat: Minelli
[Re: macca]
#210044 05/02/10 05:42 AM 05/02/10 05:42 AM |
Posts: 3,528 Looking for a Job, I got credi... | Easy, simply write to the class (in French) and request them to be reasonable.... Good luck! Macca, Bit confused here; why would anyone want to write to the international F18 class in French when the official langiage of the class us English?
F16 - GBR 553 - SOLD I also talk sport here | | | Re: 2010 F18 Rules Publised
[Re: macca]
#210155 05/04/10 01:36 AM 05/04/10 01:36 AM |
Posts: 3,528 Looking for a Job, I got credi... | Simon, If you ever have the misfortune that requires you to deal with the class you will understand.. Haa; Haa. I know where you are coming from Macca...... Some people just make life too difficult....!
[Re: scooby_simon]
#210158 05/04/10 03:14 AM 05/04/10 03:14 AM |
Posts: 586 Hobart, Tasmania, Oz. | Macca, whats going on with you? your just falling down all over the place!
I believe Olivier Bovyn is the International F-18 president and generally helpful individual.
Darren Flanagan May 3 at 11:38am Hi Olivier,
Just a quick question, If I wanted to send a letter to the international F-18 association, would it need to be in English or French?
Best Regards
Darren. Olivier Bovyn May 4 at 5:00pm Hi Darren,
Being an International Association, English is preferable to post messages to IF18CA, but French can be accepted too.
Best regards,
Olivier
388
guests, and 71
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
