Re: C2 [Re: Matthew Whitehead] #211265
05/17/10 11:05 AM
05/17/10 11:05 AM
rexdenton Offline
rexdenton  Offline
I arrived at the beach to find a new C2 in my spot. Finders keepers?
Nacra F18 #856
Re: C2 [Re: rexdenton] #211285
05/17/10 05:28 PM
05/17/10 05:28 PM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
I wish we could figure out a way to keep it there.
Re: C2 [Re: rhodysail] #211292
05/17/10 08:43 PM
05/17/10 08:43 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Just curious...how many teams going to the Alter Cup have already sailed the C2? Wish Ian would let us sail his before we go...like that would happen. I think we would have to pry it from his cold dead hands. He will probably spend the first two days polishing and buffing it just to keep his hands on it. laugh Sorry Ian, I couldn't resist!
See you in Houston.
Later,
Dan
Re: C2 [Re: Dan_Delave] #211496
05/20/10 10:22 AM
05/20/10 10:22 AM
Branford, CT
rhodysail Offline
rhodysail  Offline
Branford, CT
So what's the trick with the main halyard lock? If I tie the halyard to the ring I can get the sail up but not down. If I tie the halyard to the shackle I can get the halyard down but not up. There must be a trick.
Re: C2 [Re: rhodysail] #211509
05/20/10 12:54 PM
05/20/10 12:54 PM
O
oxj Offline
oxj  Offline
O
On the Cap we've always tied it to the top which makes it easy to lock and we did the same with the C2. The trick to getting it off is to:
1) Pull halyard while mast is pointing straight back, then hold the tension on it while rotating mast to one side.
2) Pull down on main while easing halyard tension and it will come down.
Depending on your angle to the wind you may need to try either side.
Re: C2 [Re: oxj] #211512
05/20/10 01:23 PM
05/20/10 01:23 PM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
On my Capricorn, the starboard side always works better.
F18: C2 / A-Cat: Minelli
Re: C2 [Re: Baltic] #211515
05/20/10 02:15 PM
05/20/10 02:15 PM
M
maritimesailor Offline
M
Matt, so jealous of you and Taylor and all the sailing you have been doing. Chris and I are driving to Florida in a two weeks to pick up ours! Can't wait!!! By then you guys will have all the tuning figured out for us, right? ;-)
-Patrick
Re: C2 [Re: John Williams] #211614
05/21/10 10:46 AM
05/21/10 10:46 AM
andrewscott
andrewscott
Originally Posted by John Williams
Is Jon drinking a 40??
I think living in LB has turned you into an OG
Re: C2 [Re: maritimesailor] #212434
06/02/10 09:29 AM
06/02/10 09:29 AM
Panama City, Florida
M
Matthew Whitehead Offline OP
M
-Patrick
Exactly. We have figured the boat out, for the most part, but we still aren't experts. lol. How long are you guys coming down for? Just to pick it up and go? We should try to sail.
F16 Viper - USA 211
Re: C2 [Re: rhodysail] #212435
06/02/10 09:33 AM
06/02/10 09:33 AM
M
M
If you tie the knot to the top of the ring, I believe it's more efficient. Once it's tied, move the not to the side (depending on which side of the hook the halyard is on up top) so it will hook in without the knot getting in the way. Face the knot away from the hook too.
F16 Viper - USA 211
Re: C2 [Re: Matthew Whitehead] #212436
06/02/10 09:35 AM
06/02/10 09:35 AM
M
M
Then to take it down, rotate the mast away from the side of the hook that the line was running up top.
F16 Viper - USA 211
0 registered members (), 3,562 guests, and 404 spiders.
