| Re: Crew weight corrector weights?
[Re: Dlennard]
#214572 06/24/10 09:06 AM 06/24/10 09:06 AM |
Posts: 3,224 Roanoke Island ,N.C. | 1. The NACRA 20 Minimum Sailing Weight shall be 325lbs; however, for crews requiring more than 25lbs. plus 1/2 of the additional weight required need be carried.
I read that AS for the teams that have to carry more than 25lbs to make weight they have to carry minimum plus 1/2 of the difference. What a horrible disadvantage when you get to sail at or below minimum while the heavy guys are WAY over. Gimme a break.
[Re: Kris Hathaway]
#214574 06/24/10 09:37 AM 06/24/10 09:37 AM |
Posts: 887 Crofton, MD | Kris, even worse we were at 480#s with a torn spinny.
[Re: Team_Cat_Fever]
#214581 06/24/10 10:02 AM 06/24/10 10:02 AM |
Posts: 887 Crofton, MD | I'm getting some of the same interperitation here and I have to ask Really? Put yourself in my situation. You want 60#s additional weight, fixed, on the boat, with potentially all of it working against the masts floation while on its side. Really?
I have also done some short course racing with my son, so we were at the 285#s, without corrector weigths and the other teams with two humans on board just walked away from us since the wind was slightly stronger than what the two of us could hold down. At 10 years old he can trim the jib sometimes, he can trap out sometimes, he can call opposing boats, and he can always give me a rash of crap for making a decision that cost us a place or two. It not all Roses.
Looks like I should just take the single handed correction factor, good enough.
[Re: Chris9]
#214588 06/24/10 11:12 AM 06/24/10 11:12 AM |
Posts: 3,224 Roanoke Island ,N.C. | What did the factory/class say? I don't think the rules were written to make it a family boat ,they were written to keep light teams from taking advantage. The skill of the sailors aboard has no bearing on the handicap. I'd say talk to your fellow club members and come up with an equitable solution, it's not like your traveling and racing lots of different folks with your son.
[Re: Chris9]
#214590 06/24/10 11:37 AM 06/24/10 11:37 AM |
Posts: 3,224 Roanoke Island ,N.C. | Right on. Maybe I can actually "Check in properly" this year, but I doubt it. Think they'd be pissed if I mooned them at check-in?
[Re: Chris9]
#214632 06/24/10 11:33 PM 06/24/10 11:33 PM |
Posts: 1,459 Annapolis,MD | Kris, even worse we were at 480#s with a torn spinny. And yet you still beat me at 400#s and a non-torn spinny... Here's my suggestion for how to affix the weight - go to West Marine and buy an anchor of the approximate weight needed. Get a line, tie one end to the anchor, the other to the crossbeam near the dolphin striker, then the toss the anchor into the water. It doesn't need to touch bottom. | | | Re: Crew weight corrector weights?
[Re: Chris9]
#214699 06/25/10 08:53 PM 06/25/10 08:53 PM |
Posts: 1,459 Annapolis,MD | Past two Tuesday nights been saling with board up 6 inches, sometimes downwind forget to pull them higher.
Thanks for the suggestion. Were you trying it out for me? I was. It worked well. | | |
1,174
guests, and 41
