Page 4 of 6 1 2 3 4 5 6
Re: Rule question [Re: PTP] #214620
06/24/10 05:18 PM
06/24/10 05:18 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
no you have it backwards... before the start.. you can only take them up to close hauled... after the start you can luff them to head to wind.
See above for proper course...
crac.sailregattas.com
Re: Rule question [Re: Mark Schneider] #214621
06/24/10 05:22 PM
06/24/10 05:22 PM
really? I know you have a lot more experience than me, but I thought I had that one down!
edit: just tried to look it up and didn't find anything specific about it and didn't see anything about prior to vs after the start
Re: Rule question [Re: PTP] #214624
06/24/10 05:43 PM
06/24/10 05:43 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
The relevant rule is 17:
ON THE SAME TACK; PROPER COURSE
If a boat clear astern becomes overlapped within two of her hull
lengths to leeward of a boat on the same tack, she shall not sail above
her proper course while they remain on the same tack and overlapped
within that distance, unless in doing so she promptly sails
astern of the other boat. This rule does not apply if the overlap
begins while the windward boat is required by rule 13 to keep clear.
So if you are racing and try to overtake from underneath (lee side) you cannot luff someone up. If you are being overtaken to windwards, then you can luff the windward boat up (provided you give them room to keep clear).
There is no 'proper course' before the start - so you can luff a boat head to wind. Once the gun goes off, your proper course is close hauled.
I'm not sure if Mark is not just yanking your chain.
Chris.
Chris.
Re: Rule question [Re: flumpmaster] #214626
06/24/10 05:45 PM
06/24/10 05:45 PM
Thanks Chris,
any difference between prior to and after start?
Re: Rule question [Re: PTP] #214627
06/24/10 05:49 PM
06/24/10 05:49 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Thanks Chris,
I just edited my reply to answer that. Pre start - luffing OK. Post start - not OK if overtaking from clear behind.
Re: Rule question [Re: flumpmaster] #214635
06/25/10 01:36 AM
06/25/10 01:36 AM
BUT remember the leeward boat will USUALLY define what proper course is. So if a high pointing boat is sailing up under you; it is THEIR proper course that defines what is Valid; thus if you are sailing a low pointing boat; be ready to tack away. Second; if you are windward boat and disagree with them on proper course; you still have to avoid them and take them too the room;
Finally remember that proper course is something that is REASONABLE and follws the definition of what proper course is (in summary the course you qould sail to get to the mark QUICKEST in the absence of other boats; this MIGHT include sailing to gusts!
Re: Rule question [Re: scooby_simon] #214675
06/25/10 09:39 AM
06/25/10 09:39 AM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Agreed. Hobie 16s would be wise to watch for A-Cats climbing up underneath them in mixed fleet racing for example.
Re: Rule question [Re: flumpmaster] #214688
06/25/10 12:25 PM
06/25/10 12:25 PM
Been there before....the "you don't want to be there" warning was followed by "why?" and after a quick pointing demonstration right after the gun goes off, the H16 says "holy crap, you weren't kidding!".
Re: Rule question [Re: Jake] #214763
06/28/10 07:47 AM
06/28/10 07:47 AM
brucat Offline
brucat  Offline
OK, so I spoke with a Senior Judge (who happens to be an International Umpire) this weekend about the original scenario. He confirmed my original position on this.
He said that regardless of (and in part, especially because of) the handling characteristics of the spin boat, that does NOT entitle them to claim they were unable to keep clear if they capsize. Such a boat should expect to be headed up to the moon, and if they decide to overtake to windward, should leave enough space so they can avoid capsizing when the leeward boat brings them up.
Re: Rule question [Re: brucat] #214767
06/28/10 08:03 AM
06/28/10 08:03 AM
Annapolis, MD
Annapolis, MD
Good news.... Common sense leads you to the proper answer (as well as a careful reading of the rules)
Boat's ahead of you have the right to protect their position. That's the game we play period. If you attempt a pass by going for their wind... you have to keep clear... Snuffing the chute (because you must to stay upright) is just part of the passing boat's move.
Mind you... the probability of this working is small.
So... figure out the timing of the dive move... or plan to set up high for a clear passing lane.
Re: Rule question [Re: Mark Schneider] #214776
06/28/10 08:30 AM
06/28/10 08:30 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
That begs for the question:
If a non-spin boat takes up a spin boat and the spin has to be dropped. If the head of the spin fouls the leeward boat when it blows off for the douse. Did the leeward boat give room for avoidance?
Isak Dinesen
E. B. White
Re: Rule question [Re: Team_Cat_Fever] #214788
06/28/10 09:46 AM
06/28/10 09:46 AM
brucat Offline
brucat  Offline
I think that question has been answered. You're focusing on the wrong part of the equation.
Re: Rule question [Re: brucat] #214803
06/28/10 12:34 PM
06/28/10 12:34 PM
Playing devils advocate here.
As burdend boat does not have to anticipate what a ROW boat will do; Thus; you cannot ASSUME the leeward boat WILL luff; you just have to react to it; thus I would STILL argue that room means room to drop the kite if needed.
Re: Rule question [Re: scooby_simon] #214810
06/28/10 02:04 PM
06/28/10 02:04 PM
brucat Offline
brucat  Offline
You're free to argue anything you'd like, but in this case, it appears that you would lose.
If you know your boat needs so much space to safely round up, you need to leave that much space if you pass someone to leeward (on their windward side). The rules are simply not intended to protect the passing boat.
Re: Rule question [Re: brucat] #214826
06/28/10 05:47 PM
06/28/10 05:47 PM
But the rules are there to avoid collissions; if the windward boat is FORCED to capsize on top of the leeward boat; the leeweard boat did not give them enough room to keep clear.....
Remember I am playing devils advocate...
Re: Rule question [Re: scooby_simon] #214828
06/28/10 05:49 PM
06/28/10 05:49 PM
Mike Fahle Offline
Mike Fahle  Offline
Hi Scooby,
I have several points to make that I hope will help you and others understand this basic Right Of Way (R-O-W) rule 11; When boats on the same tack are overlapped, a windward boat shall keep clear of a leeward boat. (that is the actual wording) So the burden is mandatory on the windward boat. That is limited in this case by rule 16 which requires the R-O-W boat to give the other boat room to keep clear. This has all been pointed out already but since room is a defined word it is also a rule. It is "The space a boat needs in the existing conditions while manoeuvring PROMPTLY in a seamanlike way. I emphasized the word "promptly" because that seals the deal against your devil's advocate position. You must not only respond to the luff but you must do it promptly (no excuses). You must be prepared to handle your boat promptly in a seamanlike way at all times. It is not seamanlike to capsize, shrimp the spinnaker, teabag while trapeezing, steer erratically with your foot on the tiller, etc. That may happen at times with any of us, but it is not an "out" with the rules. They explicitly state what is required and that IS something that you need to anticipate no matter what your course.
The first and main purpose for the RRS is to make racing safe. It is not safe to require a R-O-W sailor to know how every different boat on the race course may handle. It IS safe to require every sailor to know how his own boat may handle so it is up to that sailor to allow himself the room necessary in the existing conditions to maneuver safely and responsibly near R-O-W boats.
In rereading the earlier posts, it still strikes me that several racers thought that the windward boat in this scenario was O.K. to pass close to weather of the leeward boat. I hope everyone now understands that to be a high risk maneuver. Matt McDonald described the classic tactic for the faster boat to qickly pass through to leeward but it seems to have escaped attention. Most experienced racers WOULD anticipate a sloop rigged boat luffing an overtaking spinnaker rigged boat even though the rules do not require that as you correctly wrote. The rules also do not require the leeward boat from anticipating that the windward boat may not manoeuver promptly in a seamanlike fashion but, again, most experienced racers WOULD so that they can be ready for the consequences (read rule 14). I hope this helps.
Re: Rule question [Re: Mike Fahle] #214832
06/28/10 06:58 PM
06/28/10 06:58 PM
France
pepin Offline OP
pepin  Offline OP
France
I did this maneuver in low wind. In higher where a gust can force you to bear away without warning I would never have attempted to get that close.
The main reason I was too close is that we just both passed the mark and there was not enough distance between the mark and the passing point for me to separate on any side. My choices were to make a speedy run on top of him, or stop below him because there was no way I was going to build enough speed to pass through the wind shadow: have you seen the size of the P19 sails?
In retrospect I should have delayed my mark rounding, by going further away before jybing, building separation so I could go under him outside his wind shadow.
Re: Rule question [Re: Mike Fahle] #214833
06/28/10 07:27 PM
06/28/10 07:27 PM
Originally Posted by Mike Fahle
Hi Scooby,
... It is "The space a boat needs in the existing conditions while manoeuvring PROMPTLY in a seamanlike way. I emphasized the word "promptly" because that seals the deal against your devil's advocate position. You must not only respond to the luff but you must do it promptly (no excuses). You must be prepared to handle your boat promptly in a seamanlike way at all times. It is not seamanlike to capsize, shrimp the spinnaker, teabag while trapeezing, steer erratically with your foot on the tiller, etc. That may happen at times with any of us, but it is not an "out" with the rules. They explicitly state what is required and that IS something that you need to anticipate no matter what your course....
OK, but I would argue that to maneuver a spinnaker so you can sail to windward in a seamanlike way would be to drop said spinnaker...not flip the sucker.
I think this is a 50/50 proposition...maybe 60/40 in favor of the leeward non-spin boat. It's going to come down to the judge until we have an exemplified interpretation.
Re: Rule question [Re: Jake] #214840
06/28/10 08:50 PM
06/28/10 08:50 PM
League City, TX
flumpmaster Offline
flumpmaster  Offline
League City, TX
Hi Scooby,
I'm with Jake on this - unless someone can pull a relevant example out the casebook.
Re: Rule question [Re: Mike Fahle] #214855
06/29/10 01:32 AM
06/29/10 01:32 AM
Hi Scooby,
Most experienced racers WOULD anticipate a sloop rigged boat luffing an overtaking spinnaker rigged boat even though the rules do not require that as you correctly wrote. The rules also do not require the leeward boat from anticipating that the windward boat may not manoeuvre promptly in a seamanlike fashion but, again, most experienced racers WOULD so that they can be ready for the consequences (read rule 14). I hope this helps.
Where in the rules does it state a boat has to anticipate what another might do and PLAN for avoiding action?
You state yourself that the wording is “promptly”; not “anticipate”
IF I got into the position(and I would try not to, remember I am playing devils advocate), I would still be saying “to manoeuvre promptly, the first thing I will need to do is PROPTLY drop my Spi ONCE THE LUFF HAS STARTED”
0 registered members (), 307 guests, and 103 spiders.
Posts267,058
