Page 1 of 5 1 2 3 4 5
Construction of Garage Mahal has begun! #216973
08/02/10 06:10 PM
08/02/10 06:10 PM
Jake Offline OP
Jake  Offline OP
Re: Construction of Garage Mahal has begun! [Re: Jake] #216976
08/02/10 07:13 PM
08/02/10 07:13 PM
I'd put some sort of roof over the stairs.
Re: Construction of Garage Mahal has begun! [Re: Karl_Brogger] #216977
08/02/10 07:40 PM
08/02/10 07:40 PM
andrewscott
andrewscott
you should cut a slot in the roof for mast up storage smile
looks great.
Re: Construction of Garage Mahal has begun! [Re: ] #216979
08/02/10 07:47 PM
08/02/10 07:47 PM
Nimrod Offline
Nimrod  Offline
Look great, we're thinking of something simular but not as big.
Good luck, you doing this yourself?
Re: Construction of Garage Mahal has begun! [Re: Nimrod] #216980
08/02/10 07:59 PM
08/02/10 07:59 PM
Jake Offline OP
Jake  Offline OP
I would really like to but there's no way I would have time to handle the construction and the height of the structure dictates scaffolding or lift equipment with multiple hands - I've hired a builder to put it in the dry (including finished exterior and concrete). I'll take over at that point with the wiring, plumbing, flooring, and HVAC...I will hopefully have enough left in the budget to contract the insulating and drywall...those are time consuming tasks (and tasks that I'm not a big fan of doing).
I was going to go 24x24 but a couple sailor/builder friends of mine gave the same piece of advice....they both said that "people complain about building it too small and they complain about it costing too much but nobody complains about building it too big."
Re: Construction of Garage Mahal has begun! [Re: Jake] #216985
08/02/10 08:15 PM
08/02/10 08:15 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
The extra space will be nice Jake. My garage is 24' deep and the 20 hulls did NOT want to fit in there with the other garage type crap.
Also, when you get one of those RC winged tri's going, I'll purchase one from you since most of my sailing is going to be on a gator pond across the street.
Re: Construction of Garage Mahal has begun! [Re: Jake] #216986
08/02/10 09:01 PM
08/02/10 09:01 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
You can't have too much power or outlets. Install compressor outlets into the walls. Consider built-in vacuum system.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Construction of Garage Mahal has begun! [Re: hobie1616] #216987
08/02/10 09:45 PM
08/02/10 09:45 PM
Not worth the hassle in my opinion. Money better spent on a good moveable shop vac. Fein, Alto-Wap, Festool, etc.
Re: Construction of Garage Mahal has begun! [Re: Karl_Brogger] #216990
08/02/10 10:18 PM
08/02/10 10:18 PM
Make sure your electric service is up to the anticipated load. It is surprisingly inexpensive to upgrade.
Re: Construction of Garage Mahal has begun! [Re: John Williams] #216993
08/02/10 10:46 PM
08/02/10 10:46 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
When I built my detached garage I added two buried conduits between the house and the new slab for the garage. One was for power, the other was for future (if needed) stuff. Well, the second one is now full with phone lines, cat5, coax, cctv wiring, low voltage wire for the garage door, etc. It came in real handy.
Philip
USA #1006
Re: Construction of Garage Mahal has begun! [Re: P.M.] #216995
08/02/10 11:17 PM
08/02/10 11:17 PM
Louisiana
millipede Offline
millipede  Offline
Louisiana
Never underestimate the power of dust collection. You can even run a hose to a table made of peg boards and use it for a down flow table for sanding. I hate having to drag my shop vac around. Check out Harbor Freight for a cheap but decent DC.
Wish I was on the water instead of in front of a computer.
Re: Construction of Garage Mahal has begun! [Re: John Williams] #217015
08/03/10 07:21 AM
08/03/10 07:21 AM
Jake Offline OP
Jake  Offline OP
Great advice on here, thanks! I did call the power company and asked them about putting a dedicated service on the new structure - they said that the County probably wouldn't allow it since it will be attached to the existing structure...which is debatable since my shop is attached only by a shared roof over unlivable carport / breezeway...but they're running the numbers on my existing service to see if it will support the additional heatpumps, RV plug, welder, etc.
Re: Construction of Garage Mahal has begun! [Re: Jake] #217020
08/03/10 07:53 AM
08/03/10 07:53 AM
how are they bracing the gable ends? I'm not sure where your house is, but remember windstorm mitigation...it will save a lot on your eventual insurance premium...
Might consider one of those mist fire sprinkler systems too... they don't spray as much water, but do the same job (minimizing collateral damage). Garage fires are the worst.. don't ask me how I know
Re: Construction of Garage Mahal has begun! [Re: Jake] #217021
08/03/10 07:53 AM
08/03/10 07:53 AM
Fixed it for ya: grin
the additional LED-beamers, plasma TV, walkin-fridge, subwoofers, xbox, grill, microwave, jacuzzi
Re: Construction of Garage Mahal has begun! [Re: Tony_F18] #217022
08/03/10 07:54 AM
08/03/10 07:54 AM
Now that's a MAN CAVE! smile
Only thing missing to make it truly manish is an old skool waterbed (the big bag kind)....
Re: Construction of Garage Mahal has begun! [Re: waterbug_wpb] #217023
08/03/10 08:03 AM
08/03/10 08:03 AM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Every garage should have a floor drain ......
"ARRRRRrrrrrrr ...." Tim (ToolTime) Taylor
Re: Construction of Garage Mahal has begun! [Re: HMurphey] #217026
08/03/10 08:21 AM
08/03/10 08:21 AM
Good point!
Unless you get super crazy with big loads, i.e. hot tub, BIG electric motor/s (>3h.p.), resistance loads (electric heat), a 60 amp. sub-panel will be large enough (guessing your load to be ~9kW max.) Add surge suppression to your low voltage cables (phone, video, etc.) where they enter the Garage (buried conduit from house?) Lightning seeks the smallest wires first.
Re: Construction of Garage Mahal has begun! [Re: _flatlander_] #217038
08/03/10 10:49 AM
08/03/10 10:49 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
That is too cool! I am so jealous.
Re: Construction of Garage Mahal has begun! [Re: HMurphey] #217042
08/03/10 11:20 AM
08/03/10 11:20 AM
hobie1616 Offline
hobie1616  Offline
Don't forget to put a NASCAR shop paint job on the floor.
Re: Construction of Garage Mahal has begun! [Re: _flatlander_] #217046
08/03/10 11:50 AM
08/03/10 11:50 AM
Jake Offline OP
Jake  Offline OP
Good point!
I was going to run a 100Amp line over from my existing 200Amp service. In addition to the two 1Ton heat pumps and RV that may run it's AC from time to time, I'll have one or two Dye Sub heat presses running that each require a dedicated 20 amp circuit. That's not to mention a pretty hefty 80gallon 175psi compressor.
0 registered members (), 712 guests, and 104 spiders.
Posts267,058
