| Re: G.Zeus, y'all!
[Re: MalteM]
#223937 11/11/10 09:29 PM 11/11/10 09:29 PM |
Posts: 13 | The previous owner of my boat had a carbon set of rear beam risers made in Gulfbreeze FL for $550 at Recreational Composites back in 2006. Very nice, lite, stiff & strong. If I knew how to post a picture I would. PM me if you wish
Ed Baldwin Central OH Bimare 18HT #4
| | | Re: G.Zeus, y'all!
[Re: davefarmer]
#223982 11/12/10 02:09 PM 11/12/10 02:09 PM |
Posts: 12,310 South Carolina | Here's a pic of an aluminum riser from Joe's boat.
dave ahhhh...I see now. I was wondering what in the heck you guys were doing to make those round beams fit together.
Jake Kohl | | | Re: G.Zeus, y'all!
[Re: davefarmer]
#224015 11/12/10 08:17 PM 11/12/10 08:17 PM |
Posts: 2,921 Michigan | Here's a pic of an aluminum riser from Joe's boat.
dave those are the ones Joe and I made. We made some originally with an old beam from a nacra but it wasn't stiff enough. These are actually overkill and could be lesser thickness. Much less expensive than the carbon ones. Once you cut holes in them to lighten them some then they don't weigh a whole bunch more than the carbon ones. | | | Re: G.Zeus, y'all!
[Re: bvining]
#224020 11/12/10 08:54 PM 11/12/10 08:54 PM |
Posts: 13 | "Carbon and aluminum dont play well together"
Hey, explain this a little more if you don't mind and what would you put between the two surfaces? Thanks!
| | | Re: Where have all the 18HTs gone?
[Re: bvining]
#228442 02/09/11 01:33 PM 02/09/11 01:33 PM |
Posts: 8 indy | sorry for the delay, yes bought it, picked up old trailer from H 16, modified it once back home with load spreading at contact points, broke main halyard in Outer Banks on first raising of main, had some questions re mast rake as boat seemed to not be set up correctly re stay lengths, received video from Bimare after month of emailing, but it does not address stay lengths, also the pin attached to front aspect carbon mast base seems to suggest raising mast from forward using this as pivot point, but this seeems horribly risky and unstable vs raising mast from aft with both sidestays connected and ready to stabilize mast once vertical, just waiting for forestays to be attached, any one have correct lenghts fore side and forestays, are adjuster plates typically used on sides, and are high tensile lines used for final adjustments on forestays ? have owned Solcat 18 TheMightyHobie18, H20 and having line vs wire for standing rigging seems fragile for a rig this size | | | Re: Where have all the 18HTs gone?
[Re: wayler]
#228452 02/09/11 08:15 PM 02/09/11 08:15 PM |
Posts: 12,310 South Carolina | Raising from the front is actually easier since you should have two split forestays. Most a-cats step their mast this way. Connect the forestays with a lot of slack in them and make sure the boat is pointed into the wind. Step the mast and let the mast lean raked way back...the two forestays will help keep it stable...though it is wise to have someone steading the mast at the base while someone pins the shrouds for a little insurance.
Jake Kohl | | | Re: Where have all the 18HTs gone?
#228499 02/11/11 04:53 PM 02/11/11 04:53 PM |
Posts: 1,307 Asuncion, Paraguay | Raising from the front is actually easier since you should have two split forestays. Does it make sense to rig the boom (halyard and mainsheet) and use it as a gin pole? The mainsheet would keep the mast steady until the shrouds are connected.
Luiz
[Re: wayler]
#228511 02/12/11 08:33 AM 02/12/11 08:33 AM |
Joined: Jul 2005 Posts: 267 Ocean Springs, MS Capt_Cardiac
Posts: 267 Ocean Springs, MS | are adjuster plates typically used on sides, and are high tensile lines used for final adjustments on forestays ? have owned Solcat 18 TheMightyHobie18, H20 and having line vs wire for standing rigging seems fragile for a rig this size I rigged all the standing rigging on my HT with amsteel line. you don't have to worry about it being fragile. it has a higher strength than steel wire does. eventually i took it all off though because i found i had to constantly adjust it and it 'felt' spongy. the rigging didn't feel stiff. maybe it was all in my head but i still like the SS lines. now, i use amsteel to adjust the forestays. no problem there. its all that boat ever uses. i replace it every 2-3 yrs because rigging should be replaced that often but i'm sure it would last longer. the side stays are conventional with plates for adjustment. what a great boat! cc
Capt Cardiac Ocean Springs Yacht Club Sailor Nacra20 - Flight of Ideas #5 | | | Re: Where have all the 18HTs gone?
[Re: Capt_Cardiac]
#228732 02/17/11 10:41 AM 02/17/11 10:41 AM |
Posts: 13 | Anyone have pictures or a diagram of how the internal downhaul is set up on their HT? When I purchased my boat she was set up with a external downhaul system but it looks like it was originally set up with a internal system.
I have always found raising the mast from bow to stern easiest. I also use standard SS rigging with SS plates for adjustment.
-Chris F18HT USA 1 Rochester NY
Bimare Jav2 18HT
[Re: roccats]
#228780 02/18/11 08:37 AM 02/18/11 08:37 AM |
Posts: 267 Ocean Springs, MS | I don't have any diagrams and i'm too simple to be able to explain it here. I think it would be a challenge to set it up again if it were disassembled. You can do it, its just challenging. The internal cross bar has to be taken down and done in such a way that it can be retrieved. I think it takes some fishing tape work. good luck.
[Re: Capt_Cardiac]
#228825 02/18/11 07:59 PM 02/18/11 07:59 PM |
Posts: 2,921 Michigan | I removed it years ago and you tape a line to the bolt when you pull it out so that you can then pull the blocks down. The blade has an internal downhaul that runs the same way. Maybe someone can get you a diagram of that. Put something on the F16 forum and I guarantee someone has a diagram already made up. any advice captain cardiac has comes from what I taught him ![smile smile](/forum/images/graemlins/default/smile.gif) Not too long ago, he would rather do anything than work on a boat
[Re: PTP]
#228834 02/19/11 08:39 AM 02/19/11 08:39 AM |
Posts: 267 Ocean Springs, MS | that's cruel. perhaps true but cruel.
359
guests, and 87
Mod | | Forums26 Topics22,405 Posts267,057 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
