| Re: Formula 14 development
[Re: Rolf_Nilsen]
#214796 06/28/10 11:10 AM 06/28/10 11:10 AM |
Joined: Apr 2002 Posts: 695 Ft. Pierce, Fl. USA Seeker
Posts: 695 Ft. Pierce, Fl. USA | To take advantage of the most recent design trends I did a total revamp of my F14 design. Including: 1) Broadening the hull from 9-1/2" to 14" wide 2) Completely changed the section shape 3) Add slightly more rocker profile Almost finished with rebuilding the jig...here is the Starboard side Jig roughly completed… Uploaded with ImageShack.us | | | Re: Formula 14 development
[Re: Seeker]
#214968 06/30/10 02:44 AM 06/30/10 02:44 AM |
Posts: 1,382 Essex, UK | I like the look of that! Are you planning on building in wood or foam/glass?
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Formula 14 development
[Re: Jalani]
#222797 10/27/10 01:33 PM 10/27/10 01:33 PM |
Posts: 695 Ft. Pierce, Fl. USA | Thanks John for the complement...this build is going to have to go in spurts, as time permits. Tackled the tight chine radius this morning...worked well considering the compound curve the strips were required to make. Worked on the sheer this evening...so all the basic foam for one half of one hull has been glued in place....the epoxy/glass bubbles were too wet on the new work to trim the foam tight to the jig. Uploaded with ImageShack.us
[Re: Seeker]
#224112 11/14/10 02:07 PM 11/14/10 02:07 PM | Scarecrow
| Scarecrow
Unregistered | Seeker, you might want to make yourself known here, there are a whole lot of people looking to buy your boat.
[Re: Seeker]
#224285 11/16/10 02:19 PM 11/16/10 02:19 PM | Scarecrow
| Scarecrow
Unregistered | Seeker, do you have much to spare in your weight budget? Given most of it can be built from scraps in your build a wing could turn out quite cheap. Particularly if you're happy not to twist the first section. | | | Re: Formula 14 development
[Re: Seeker]
#224401 11/19/10 02:36 AM 11/19/10 02:36 AM |
Posts: 1,382 Essex, UK | It'll be one hell of a result if you build a lightweight 14 footer with a rigid wing! You'll certainly generate a lot of interest!!
[Re: Jalani]
#224473 11/20/10 06:59 PM 11/20/10 06:59 PM |
Posts: 190 | Seeker, I thought that there was a max. girth for the mast of an F14?
lesburn1.blogspot.com
A-Cat USA 49 18Sq 49
297
guests, and 70
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
