Page 2 of 5 1 2 3 4 5
Re: Steeplechase Tracking [Re: Seeker] #225248
12/11/10 12:24 PM
12/11/10 12:24 PM
what rating is the f20 using?
Re: Steeplechase Tracking [Re: Seeker] #225249
12/11/10 12:26 PM
12/11/10 12:26 PM
cyberspeed Offline OP
The wind was straight on the nose going up to the angelfish. Started to fill in when I left the bridge. Should make better progress on the outside.
Roberts is running, somehow the spot got turned off. Probably when I installed it. I tried to check them all before they left but Roberts was on the water before I could double check it.
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Steeplechase Tracking [Re: Seeker] #225250
12/11/10 12:26 PM
12/11/10 12:26 PM
Bob_Curry Offline
Bob_Curry  Offline
First thru the cut to the outside is CC, followed 6 minutes later by the M20 of Phillips and side-by-side them is the Roberts on the RC22. Nacra F20 has not gone into the cut yet. Winds outside are 10kts and building. More to come....
wink
Re: Steeplechase Tracking [Re: Bob_Curry] #225251
12/11/10 12:34 PM
12/11/10 12:34 PM
Bob_Curry Offline
Bob_Curry  Offline
The Nacra F20 just went thru; 19 minutes behind the front runner. The chase boat is going in now so we'll see what happens at the finish of todays leg!
wink
Re: Steeplechase Tracking [Re: PTP] #225253
12/11/10 12:47 PM
12/11/10 12:47 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Same as the M20, I believe.
Isak Dinesen
E. B. White
Re: Steeplechase Tracking [Re: Team_Cat_Fever] #225254
12/11/10 12:53 PM
12/11/10 12:53 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Light wind on the nose would definitely favor the M20. They really excel in that condition.
The F20 I would think would excel in Medium winds downwind sailing. Medium being 12-18 knts.
So this might be a rough race for the F20 unless the wind does come up on the outside and the foils can come to life.
Mike Hill
N20 #1005
Re: Steeplechase Tracking [Re: cyberspeed] #225255
12/11/10 12:55 PM
12/11/10 12:55 PM
Craig,
Can you put up a full entry list, and show which teams have spots and who they are.
Good job ,so far. This is the first time I've watched . Not as good as being there , but way better than waiting a week for results.
Isak Dinesen
E. B. White
Re: Steeplechase Tracking [Re: Mike Hill] #225256
12/11/10 12:58 PM
12/11/10 12:58 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Can someone put peoples names to the boat names on the tracking page. Only one I know is
Dingo Racing = Dave Ingram and crew?
Mike Hill
N20 #1005
Re: Steeplechase Tracking [Re: Mike Hill] #225257
12/11/10 12:59 PM
12/11/10 12:59 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Popping out of Angelfish before noon usually makes for a pretty good day. Now the chutes are up and they will be making pretty good time.
Wish I was there.
Mike Hill
N20 #1005
Re: Steeplechase Tracking [Re: Mike Hill] #225258
12/11/10 01:00 PM
12/11/10 01:00 PM
Team Redhead is Mark Smith and Joe Pocreva
looks like they are doing well, at least in terms of teams with Spots
Re: Steeplechase Tracking [Re: Mike Hill] #225259
12/11/10 01:02 PM
12/11/10 01:02 PM
CC carbon cruising is Bret Moss and John Casey
RM is Mike Krantz and David Lennard
TR is Mark Smith and Joe Pocreva
Isak Dinesen
E. B. White
Re: Steeplechase Tracking [Re: PTP] #225260
12/11/10 01:02 PM
12/11/10 01:02 PM
where do they stop today on the map?
Re: Steeplechase Tracking [Re: PTP] #225261
12/11/10 01:03 PM
12/11/10 01:03 PM
About 1/2 way between where the last 2 Rt. 1 markers are on the map, right before the turn under the Channel 5 bridge.
Check off "show split points" in the menu ,it says Steeple half. Craig has done a nice job on this.
Isak Dinesen
E. B. White
Re: Steeplechase Tracking [Re: PTP] #225262
12/11/10 01:35 PM
12/11/10 01:35 PM
pgp Offline
pgp  Offline
Pete Pollard
Blade 702
Re: Steeplechase Tracking [Re: Team_Cat_Fever] #225263
12/11/10 01:42 PM
12/11/10 01:42 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
Beautiful job by Mr. Cyberspeed.
I am sitting on my porch, wind indicator says 1 knt out of the north. Brutal.....
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Steeplechase Tracking [Re: Team_Cat_Fever] #225264
12/11/10 01:47 PM
12/11/10 01:47 PM
Hi Guys,
Sorry had some ground crew duties to do for Roberts. I did not get a full entry list. The one on registration should be correct:
http://www.catsailor.com/registration/list-entries.php?regatta=104
I had to twist some arms this morning to get some on so I was not able to get all the info from the individual teams. I will try to get it all straighted out when I get to the half way mark.
craig van eaton
Supercat 20
TEAM CYBERSPEED
Endurance Series
www.SailSeries.com
Re: Steeplechase Tracking [Re: cyberspeed] #225265
12/11/10 01:57 PM
12/11/10 01:57 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Craig, That link is the Tradewinds Registration page.
Mike Hill
N20 #1005
Re: Steeplechase Tracking [Re: Mike Hill] #225266
12/11/10 02:01 PM
12/11/10 02:01 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Looking like a dead downwind run on the outside. That would make for a long day. Hope the wind turns a little for them.
Mike Hill
N20 #1005
Re: Steeplechase Tracking [Re: Mike Hill] #225268
12/11/10 02:20 PM
12/11/10 02:20 PM
arbo06 Offline
arbo06  Offline
What happened to Carbon Crusing's spot?
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Steeplechase Tracking [Re: arbo06] #225269
12/11/10 02:26 PM
12/11/10 02:26 PM
Nothing.
Make sure you have them checked off in the menu box.
Isak Dinesen
E. B. White
