Page 2 of 3 1 2 3
Re: speed puck [Re: CatSailingHu] #229305
03/03/11 05:29 PM
03/03/11 05:29 PM
RickWhite Offline
RickWhite  Offline
I DO hope you all know that I sell them on this website's store. Here is the link
https://store.catsailor.com/pc/viewPrd.asp?idproduct=32306&idcategory=0
Rick White
www.onlinemarinestore.com
Re: speed puck [Re: CatSailingHu] #229306
03/03/11 05:29 PM
03/03/11 05:29 PM
pgp Offline OP
pgp  Offline OP
Nice set up.
Pete Pollard
Blade 702
Re: speed puck [Re: CatSailingHu] #229308
03/03/11 05:53 PM
03/03/11 05:53 PM
3 weeks Newman WA 1 week Robe ...
Brian P Offline
Brian P  Offline
has anyone ever lost one from the mounting velcro?
do you use a recovery lanyard of some sort?
i intend to mount mine on the kite pole, but worried about a kite sheet or jib sheet wrapping around it aqnd sending it into the big blue.
Brian Partridge
STINGRAY 580 "Fantasia"
A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD
BUT YOU CAN ROLL IT IN GLITTER!!!!!
Re: speed puck [Re: Brian P] #229314
03/03/11 11:14 PM
03/03/11 11:14 PM
taipanfc Offline
taipanfc  Offline
Problems to note:
If you are completely turtle then water getting in these units is a big concern, as it means the unit is phucked then.
Also the prostart doesn't have a bit to tie a rope/lanyard onto as a safetly line, depends on the velcro to hold it. Expensive to lose. Also at the moth worlds guys were having issues with water getting in the battery section. Best to use some vaseline on the seal to ensure water doesn't creep in.
Re: speed puck [Re: taipanfc] #229316
03/04/11 05:55 AM
03/04/11 05:55 AM
Brian P Offline
Brian P  Offline
cheer bro
Brian Partridge
Re: speed puck [Re: Brian P] #229317
03/04/11 06:33 AM
03/04/11 06:33 AM
When I have some time I want to do a gps overlay on some gopro sailing footage, so you can actually know how fast you go when you do what.
I looked at the iphone as well for a sailing instrument and actually think its ideal, it has a gps, camera, data connection and a lot of other sensors like a gyro.
Maybe also thinking about putting this into some sort of dashboard with a video overlay.
If you have an iphone 3gs or 4 this free app registers everything the sensors do:
http://itunes.apple.com/us/app/xsensor/id345145166?mt=8
A speedometer like the speedpuck looks interesting but speed alone would not give enough information without having something to compare it with (like maybe your speed on this side of the course on the previous lap or something).
Re: speed puck [Re: Tony_F18] #229319
03/04/11 06:58 AM
03/04/11 06:58 AM
pgp Offline OP
pgp  Offline OP
My biggest concern is sailing the best course to weather, speed seems to me the major component.
Pete Pollard
Blade 702
Re: speed puck [Re: pgp] #229322
03/04/11 07:30 AM
03/04/11 07:30 AM
IMHO the best way to improve your upwind performance is to practice with another boat most similar to yours side by side and see who is quickest, make some changes if you are slower, and try again.
The gps will show your speed but you wont know if the number shown is "good" because of changing conditions like wind, current, waves etc.
It could be useful to download the data to a PC though, you can see your tacking angles and tack-to-tack speed.
Re: speed puck [Re: Tony_F18] #229323
03/04/11 07:57 AM
03/04/11 07:57 AM
pgp Offline OP
pgp  Offline OP
Practicing with another boat is impractical, there are none nearby.
And I'm unable to upload data from my last outing with my 301, which brings me back to the original question.
I'm trying to contact Garmin which is not nearly as easy as it should be imo.
Pete Pollard
Blade 702
Re: speed puck [Re: pgp] #229327
03/04/11 09:10 AM
03/04/11 09:10 AM
Chicago, Illinois USA
TEH Offline
TEH  Offline
My .02 is that if you want to study after the race, the Garmin is fine. If you want feedback during the race and to study after, then speedpuck is a good option. I haven't used anything else, but it's easy to see, gives you speed and shows the shifts.
Blade F16 USA 725
Re: speed puck [Re: TEH] #229328
03/04/11 09:14 AM
03/04/11 09:14 AM
pgp Offline OP
pgp  Offline OP
My biggest complaint with the Garmin is that it doesn't work and tech support is... tedious?
Pete Pollard
Blade 702
Re: speed puck [Re: pgp] #229331
03/04/11 10:03 AM
03/04/11 10:03 AM
Can you be more specific about your garmin problem?
Re: speed puck [Re: Tony_F18] #229332
03/04/11 10:12 AM
03/04/11 10:12 AM
pgp Offline OP
pgp  Offline OP
It won't upload to my pc. At first it simply showed that little "busy circle" saying it was uploading, but never finished. Now my pc is not detecting the device at all.
My first outing with it was fine. I uploaded problem free and was able to review the data and actually locate some problems with my sailing, but nothing since.
Pete Pollard
Blade 702
Re: speed puck [Re: Brian P] #229333
03/04/11 10:17 AM
03/04/11 10:17 AM
France
pepin Offline
pepin  Offline
France
Originally Posted by Brian P
has anyone ever lost one from the mounting velcro? do you use a recovery lanyard of some sort? [...]
There is velcro and velcro. The positive lock on that velcro is incredible and I've never had any device move once stuck in place. I use a lanyard on all the devices if there is a spot to attach one anyway, aka on all but the prostart.
The prostart has its own support that can be screwed in and the devices clips in it. It's fairly solid but a line can get wrapped around the release...
Re: speed puck [Re: pepin] #229334
03/04/11 10:47 AM
03/04/11 10:47 AM
pete, you may benefit more on your upwind practice with VMG rather than outright speed. I've heard people set imaginary waypoints on the GPS and sail upwind for a while noting their VMG when they change things (direction, settings, etc)
I'd bet someone's got something that will show TWD, Apparant, TWS, SOG, etc. that will fit on a dingy/beachcat...
Re: speed puck [Re: waterbug_wpb] #229337
03/04/11 10:58 AM
03/04/11 10:58 AM
pgp Offline OP
pgp  Offline OP
Right now I'd settle for something simple and reliable. frown
Pete Pollard
Blade 702
Re: speed puck [Re: pgp] #229339
03/04/11 11:57 AM
03/04/11 11:57 AM
Puk it - the simplicity of the puk is what makes it so useful. Use speed or heading on the display combined with the header/lift graphic; one quick glance is all it takes and trends are very evident. The download is gravy for the debrief. The fun is everyone displaying max speed at the end of the day and dropping it on the tramp to see who pissed biggest. I love my Puk.
Re: speed puck [Re: John Williams] #229340
03/04/11 12:01 PM
03/04/11 12:01 PM
pgp Offline OP
pgp  Offline OP
http://www.velocitek.com/forums/index.php?showtopic=404
For me, reliability is the key. I don't have much patience for balky equipment.
Pete Pollard
Blade 702
Re: speed puck [Re: pgp] #229341
03/04/11 12:10 PM
03/04/11 12:10 PM
I have two - they've both downloaded fine, although I only use one of them with any regularity. The vast majority of reviews on Velocitek devices is overwhelmingly positive.
Re: speed puck [Re: pepin] #229350
03/04/11 04:32 PM
03/04/11 04:32 PM
TEH Offline
TEH  Offline
The velcro is very tough on the speed puck, but I have found it has worn over the years and is not as strong now. I always tie the lanyard to the spin pole. I did have it come loose once in a crash and was glad I did.
Blade F16 USA 725
Page 2 of 3 1 2 3
0 registered members (), 218 guests, and 82 spiders.
Posts267,058
