Hi All
Good posts ,
Raced the H-21 for a year and traveled around the country with it for events ,-
The telescoping beams were not a problem at all ,--though you needed to be carefull around sand as it would cause binding .-We generally set up in parking lots or grass areas.
The added wings to the extended beam were great also ,though you had to be sure to tie them in ,
the spin block was mounted on the wing end and could be pulled out by the force which would result in a wing flying around at the end on a spin sheet line ,-
The physics problem of the 21 was its huge overall weight,
the comptip mast was very heavy also , to lift and take down .
quick story -
On one mast take down in Newport ,I had gotten a large gash on my hand during Sat races that required stitches ,
we raced Sun ,-me with a duct taped right hand in high winds and a huge chop from enormous amounts of boat traffic from spectators and the jazz festival going on .
With the mast that heavy and tall and one hand good was a bad combination , half way down the base popped off its base and started down pivoting on my shoulder with me fighting it the whole way ,---For some reason the gr crew thought they could catch it before it hit ,--yelled let it go ,--but too late ,--they ended up with a fractured wrist . -Rough wek for al of us.
We had one on a trap wire on each side ,--but from then on we always attached a rope and winch .
Do really appreciate the light C F masts available to use now ,-hopefully costs will continue to come down for them .
Wanted to comment on the rules aspect and how that effects boat design also ,-for cats though ,not monos .
Will add a post there in re -.
