| Mold making from a plug #232001 05/05/11 05:55 PM 05/05/11 05:55 PM |
Posts: 291 | So I am looking to repair the trailing edge on a couple of daggerboards that I bought used. The trailing edge is in really poor shape. I was thinking of making a mold of the trailing edge from a new daggerboard to aid in the repair process. If you were going to do it this way would you make a fiberglass mold or would you make one by laying the new board into some type of plaster. On one board I will probably have to lay some glass for stregth. On the other I think I can just rebuild the edge with thickened epoxy like I have done on some Hobie 18 boards many times. Previously I had clamped a straigted edge on the trailing edge, packed it with thickened epoxy and then sanded to shape. While don't think the mold will save any time, in fact it will probably negate any extra sanding with the time it takes to make the mold, I thought it my be fun to try something different and pick up a skill I can use later. Seeing as new boards are now 850.00 a peice, I probably should make a mold of the entire board and start a production line.
| | | Re: Mold making from a plug
[Re: Dan_Delave]
#232008 05/06/11 02:04 AM 05/06/11 02:04 AM |
Posts: 1,203 uk | I can't offer much on mold-making but.. To repair a damaged trailing edge, make flat strips of fibreglass or carbon lay-up about 1-2mm thick and about 25mm wide and as long as the repair that you need, cut a slot down the trailing edge with a Dremel disc and insert the strip with some epoxy as glue. This will give a nice hard edge that can be filled to and faired
[Re: TEAMVMG]
#232022 05/06/11 09:35 AM 05/06/11 09:35 AM |
Posts: 291 | Thanks Paul. Thats an idea that I had not previously thought of. I just may give that a go.
[Re: carlbohannon]
#232087 05/08/11 04:54 PM 05/08/11 04:54 PM |
Joined: Feb 2009 Posts: 678 Palm Beach County TheManShed
Posts: 678 Palm Beach County | Both ideas are good. One thought your finished product is only as good as your plug / mold so it looks like you will have to repair at least one board. Paul has a very good idea on how to fix the trailing edge; it is good to have some type of fiber material in the repair and a good anchor to your part being repaired.
Mike Shappell www.themanshed.comTMS-20 Builder G-Cat 5.7 - Current Boat NACRA 5.2 - early 70's | | |
445
guests, and 42
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
