| Re: Autoratchets; Who is using what?
[Re: orphan]
#235240 07/26/11 02:44 PM 07/26/11 02:44 PM |
Posts: 3,906 Clermont, FL, USA | I have both but I've only used the Harken. The few times I've gone with Ronstan I've been disappointed. Yeah, I'm a Harken bigot.
Sorry Jeff, I know it's a pretty useless reply but you never call any more, was it something I said?
[Re: David Ingram]
#235250 07/26/11 05:32 PM 07/26/11 05:32 PM |
Posts: 129 Austin, TX | I use the Ronstan Orbits on my C2 and they work great. I used the Harkens on my N20 and they were fine too.
Bo Kersey Corsair 31-1D 276 | | | Re: Autoratchets; Who is using what?
[Re: davefarmer]
#235258 07/26/11 08:04 PM 07/26/11 08:04 PM |
Posts: 4,119 Northfield Mn | I'm huge fan of the Ronstan orbit blocks, for both the spinnaker and main sheets. The Ronstan main blocks I had were absolutely awesome even with a cheap line. I have a Harken 10:1 right now and don't know if I hate it because of the extra line or the tragic cleat adjustment.
[Re: David Ingram]
#235263 07/26/11 09:34 PM 07/26/11 09:34 PM |
Posts: 3,224 Roanoke Island ,N.C. | I have both but I've only used the Harken. The few times I've gone with Ronstan I've been disappointed. Yeah, I'm a Harken bigot.
Sorry Jeff, I know it's a pretty useless reply but you never call any more, was it something I said? Same here.I've never seen any reason to sway from Harken. From what I've heard the orbits have a more aggressive "hex" that hold well but will eat sheets. I wore the ratchet pawls out on many of the old Ronstan smart ratchets.
[Re: CatSailingHu]
#235285 07/27/11 10:05 AM 07/27/11 10:05 AM | MN3
| MN3
Unregistered | i had a 8:1 main blocks from harken. after a year i realized the ratchamatic feature wouldn't engage. Called them up.. they suggested a remedy that didn't help (soak in almost boiling water to free up any salts). they told me to ship them back, they would replace (without a receipt, and they didn't care how long i had them)...
BIG UPS for their customer service. | | | Re: Autoratchets; Who is using what?
[Re: orphan]
#235286 07/27/11 11:55 AM 07/27/11 11:55 AM |
Posts: 1,307 Asuncion, Paraguay | We are rigging the SC15 jib sheets with a Ronstan and a Harken, one in each side. I prefer the Ronstan due to better grip (line suffers more, though), efficient cleat, less weight and lower price. It is early to say anything about durability. If buying new ones I would use price as the first criteria. You should choose Ronstan if the crew´s hands are not strong (teen, woman, etc.)
Luiz
[Re: Luiz]
#235288 07/27/11 01:12 PM 07/27/11 01:12 PM |
Posts: 1,203 uk | Ronstan has one important and vital roll to play on many catamarans...
....the drain plugs!
Always Harken
[Re: TEAMVMG]
#235294 07/27/11 02:44 PM 07/27/11 02:44 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | Harken except for Distance Racing, I use Ronstan 62100 blocks for my outer spin sheet blocks. They grip better (although your sheet will look like beavers chewed it up after a week) and are freekin bullet proof. They are the all aluminum frame ones. Other than that I don't like using Ronstan because of durability issues. They seem to break easier. Plus the Harken logo looks way cooler.
Lee
[Re: TeamChums]
#235300 07/27/11 04:45 PM 07/27/11 04:45 PM |
Posts: 932 Solomon's Island, MD | I had a harken 8:1 mainsheet blow up during Tybee, Harken replaced the lower block assembly for free, no questions asked.
I also blew up some ronstan blocks trying to run a 2:1 system on the spinnaker, they weren't auto ratcheting or anything special but simply weren't built to the same toughness of a comparable Harken block (no Harkens in stock at WM).
I've used the harken setup on the N20's and its worked perfectly fine, seems fairly bulletproof. As a tip, its best to at least spray the auto ratchet blocks after sailing in salt water, better to soak them overnight in a bucket of soapy water
Scorpion F18
[Re: samc99us]
#235305 07/27/11 08:09 PM 07/27/11 08:09 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | I had a harken 8:1 mainsheet blow up during Tybee, Harken replaced the lower block assembly for free, no questions asked. I also blew up some ronstan blocks
Was anyone injured in the explosions?
Lee
[Re: TeamChums]
#235306 07/27/11 08:30 PM 07/27/11 08:30 PM |
Posts: 932 Solomon's Island, MD | Fortunately, or unfortunately depending on where you were sitting at the time, no one was hurt.. Blow up may be a bit exaggerated, the end caps that prevent the cleat from rotating failed over the course of 3 days-1 day of hard upwind sailing followed by 2 days of hard reaching. In the end the lower set of 3 blocks was no longer attached to the base and was riding at the top of the mainsail. Needless to say these problems made sheeting the main a b$tch and resulted in at least 3 capsizes.
I should mention that a replacement Ronstan lower block assembly was available to us, however the attachment point to the traveler was a whopping 3/16" stainless clevis pin, which I've bent on a Hobie 14 mainsheet system, never mind a 8:1 N20 mainsheet. In the end we used a friends Harken 10:1 system which worked flawlessly for the rest of the race.
Scorpion F18
[Re: samc99us]
#235325 07/28/11 09:26 AM 07/28/11 09:26 AM |
Posts: 172 Anacortes | I have the Ronstan Orbit auto ratchets on the spin sheets and they work pretty good, came with the boat. The grip is great. They are switchable between full ratchet, auto, and no ratchet, which seems great until you find they will switch themselves from one to the other, mostly from auto to full ratchet. So on jibes when you think the ratchet will disengage it doesn't, which really slows down the kite coming across, especially because they have so much grip.
On all the other boats I sail I use Harken autoratchets and they are dependable and work great. Just set the adjustment all the way out and you're at the perfect setting.
If i was replacing the spin blocks on my Tiger I'd go Harken.
Anacortes Rigging.com Rigging and Yacht Services
1,118
guests, and 41
