Re: wings [Re: Kris Hathaway] #236724
08/23/11 09:34 AM
08/23/11 09:34 AM
Memphis, TN
M
mikeborden Offline
mikeborden  Offline
M
Memphis, TN
You don't need to worry about the cuffs if you don't use the handle when you go out! smile
Viper USA 132
1984 Hobie 18
Re: wings [Re: Smiths_Cat] #236731
08/23/11 10:58 AM
08/23/11 10:58 AM
Originally Posted by Smiths_Cat
It looks like a Harken micro block. Harken quotes a maximum safe working load of 100kg. I guess other manufacturers have similar loads. Add some shockloading to it and it will fail...
Its a 16mm Harken 404 block, SWL is 250-lbs, breaking load is 1200-lbs. I've been using the same set of trap lines for two seasons, what fails is where it connects to the sister clip and the stopper pinches it. That's where I used to luggage tag it on there and have since just started putting in a splice. There's a lot less exposed on the sister clip with just a eye splice there. So far its worked out I have to replace the return part about once a season.
The splices are not stitched or locked otherwise. If unloaded (e.g. if you grab the handle), they can open easily.
They are stitched, I just do it real sneaky like.
(edit)- To each there own on the adjustable setup. I don't care for them, that's why I use the dogbones so you still have a hi/low setting.
Re: wings [Re: Karl_Brogger] #236732
08/23/11 11:05 AM
08/23/11 11:05 AM
Chicago, Illinois USA
TEH Offline
TEH  Offline
I have Karl's rig and used it for two seasons now without incident. I do hope I have the 16mm blocks as I am over the 100KG limit.
I did have one line fray near the aluminum stopper because it gets dug into by the block and forms little saw-like grooves.
Karl, you'll need to show me the sneaky stitch as I went to spliced lines and they are not currently stiched.
Blade F16 USA 725
Re: wings [Re: mikeborden] #236735
08/23/11 11:14 AM
08/23/11 11:14 AM
Maryland
Kris Hathaway Offline
Maryland
Ha! How about when you come in? Going out, it is reflex especially in a race with wind where you are trapping right away after the tack. Last week, I was glad because I found myself hiked out but not hooked in while skippering. As crew, some will "trap out" and then clip in. I think there is footage from the Racine event illustrating that technique.
Kris Hathaway
Re: wings [Re: Kris Hathaway] #236763
08/24/11 08:05 AM
08/24/11 08:05 AM
Memphis, TN
M
mikeborden Offline
mikeborden  Offline
M
Memphis, TN
You got me there...I do have to use it when coming in. smile
Viper USA 132
1984 Hobie 18
Re: wings [Re: mikeborden] #236765
08/24/11 08:31 AM
08/24/11 08:31 AM
When you are coming in the stopper is tight to the block or thimble. I'm not sure I've gotten a glove caught going in. It's always when I'm doing thqt in/out crap in lighter, almost trapping conditions.
Re: wings [Re: Karl_Brogger] #236780
08/24/11 04:36 PM
08/24/11 04:36 PM
TEH Offline
TEH  Offline
For me the glove gets stuck in the up and down wind. You start to go in....pull on the handle, before you get all the way in, the wind builds you go out with hand still on the handle...glove gets caught.
Blade F16 USA 725
Re: wings [Re: pgp] #237765
09/17/11 05:40 AM
09/17/11 05:40 AM
pgp Offline OP
pgp  Offline OP
I was thinking something like this.
Pete Pollard
Blade 702
Re: wings [Re: pgp] #238141
09/22/11 10:37 AM
09/22/11 10:37 AM
Santa Fe, New Mexico, USA
WillLints Offline
WillLints  Offline
I’m interested Pete. Until I got into the larger air I felt like wings were “sissy” but now realize that I would be able to get some ballast out toward the windward when trapping would mean having my feet washed off the side of the boat, leading to a certain capsize.
Also, after a capsize, the boat wouldn’t be able to be blown away from me, if it had a trampoline on the wings.
In DanTnz’s link, (http://www.hobie-cat.net/download/catalogue/gb/wings.pdf) there was a third option which wasn’t pictured. 3. Classic Wings
Similar to the Hobie 18 Magnum wings with near armchair
comfort, sitting high and dry or trapezing near outer space !
Wings are bolted onto the crossbars and can be easily
removed or folded up and out of the way. Maximum beam
120cm (48"), weight of kit 26.2kg (57.64lbs).
I’m wondering if the “bolted on to cross bars” could be modified to work our boats?
Will_Lints
one-up, Blade 706, epoxy bottoms
Re: wings [Re: WillLints] #238151
09/22/11 12:15 PM
09/22/11 12:15 PM
pgp Offline OP
pgp  Offline OP
I suppose you could modify anything.
My thought was to have them slide into the cross bars.
I think of them as forming a sort of ****. I'm no longer willing to dangle my body off the boat unless there is someone designated to pick me up.
btw- what's with the epoxy bottoms?
Pete Pollard
Blade 702
Re: wings [Re: pgp] #238172
09/22/11 03:18 PM
09/22/11 03:18 PM
WillLints Offline
WillLints  Offline
Epoxy w/ S-glass bottoms came about because of the sailing conditions in New Mexico. The lake shores I mostly sail are a mix of mud and rocks, rocks of varying size and usually not too visible. There is a lake at the south end of the state which is mostly sandy but there are always the old campfire places which are generally a ring of rocks and because the lake levels are not stable the old fire pits become a nuisance. Also, coming ashore in 20 plus MPH wind single handed is a bit much for me at 150 lbs.
I don’t regret for a minute doing the modification because my hulls are so tough, easily tougher than H18s and in some instances tougher than H16s. I haven’t had to repair a single ding to the epoxy s-glass bottoms, all that happens is that the paint gets scraped off.
Individually, I think the hulls are a lot stouter, less twisting and bending.
Will_Lints
Re: wings [Re: WillLints] #238175
09/22/11 03:32 PM
09/22/11 03:32 PM
pgp Offline OP
pgp  Offline OP
I may try that.
Pepin taught me a neat trick. When coming to shore downwind, make a pass at the beach, when you're directly up wind of the place you want to land, come head to wind. Once the boat stops pull up the foils, ease the sheets and stand as far forward as possible to lift the transoms out of the water. You'll drift down to the spot you chose with perfect control and no drama.
Pete Pollard
Blade 702
Re: wings [Re: pgp] #238177
09/22/11 03:43 PM
09/22/11 03:43 PM
WillLints Offline
WillLints  Offline
I like the sounds of that, I’m going to give that a try.
Will_Lints
Re: wings [Re: pgp] #238186
09/22/11 04:26 PM
09/22/11 04:26 PM
Originally Posted by pgp
I may try that.
That's basically what I do, but I don't ease the sheets. When they are tight the boat will weather vane and resist's rotating. I get all the way to the bridle and ride it in.
Re: wings [Re: Karl_Brogger] #238187
09/22/11 04:34 PM
09/22/11 04:34 PM
WillLints Offline
WillLints  Offline
Karl, probably a dumb question, but does that mean you startle one of the hulls at the bridle?
Will_Lints
Re: wings [Re: WillLints] #238191
09/22/11 04:46 PM
09/22/11 04:46 PM
pgp Offline OP
pgp  Offline OP
Well, Karl is startling! I stand at he bridle and hold on to the forestay.
Pete Pollard
Blade 702
Re: wings [Re: pgp] #238195
09/22/11 05:33 PM
09/22/11 05:33 PM
WillLints Offline
WillLints  Offline
Oh cra*, even when i look up the words I get them wrong. I meant 'straddle'.
Will_Lints
Re: wings [Re: WillLints] #238198
09/22/11 06:07 PM
09/22/11 06:07 PM
I stand. If you're sitting with a leg on both sides you are in a bit of an awkward position if you need to do something urgently.
0 registered members (), 296 guests, and 8 spiders.
Posts267,059
