| pitchpole #239383 10/26/11 03:40 PM 10/26/11 03:40 PM |
Posts: 8 ISRAEL | we had a spectecular pitchpole with our Nacra F20C last friday, runing with the spi in ~17knots wind and ~0.8m waves. The helm was sitting near the back beam and the crew was out on the trapeze with the chiken line, behind the helm, but it was not enough to avoid losing control and capsizing. What are the reasons for pitchpolling and what are the best ways to avoid it?
Segev Eyal Nacra F20C Sdot Yam ISRAEL
| | | Re: pitchpole
[Re: segev]
#239386 10/26/11 04:09 PM 10/26/11 04:09 PM |
Posts: 1,203 uk | how far down were each of the boards? how hard was the main sheeted? how far out was the traveler?
| | | Re: pitchpole
[Re: TEAMVMG]
#239387 10/26/11 04:13 PM 10/26/11 04:13 PM |
Posts: 8 ISRAEL | boards about 40cm up. main fully sheeted in with traveller centered.
| | | Re: pitchpole
[Re: segev]
#239407 10/27/11 06:58 AM 10/27/11 06:58 AM |
Posts: 12,310 South Carolina | we had a spectecular pitchpole with our Nacra F20C last friday, runing with the spi in ~17knots wind and ~0.8m waves. The helm was sitting near the back beam and the crew was out on the trapeze with the chiken line, behind the helm, but it was not enough to avoid losing control and capsizing. What are the reasons for pitchpolling and what are the best ways to avoid it? It's going to be hard to comment on that because very few of us have experience with that boat and the curved boards. I think maybe it's possible that you had your weight too far back. Did the bows happen to leap up away from the water before it plunged back in?
Jake Kohl | | | Re: pitchpole
#239411 10/27/11 08:08 AM 10/27/11 08:08 AM |
Posts: 5,590 Naples, FL | Did the bows happen to leap up away from the water before it plunged back in? I was going to ask the same question...
| | | Re: pitchpole
[Re: pitchpoledave]
#239420 10/27/11 01:03 PM 10/27/11 01:03 PM |
Posts: 8 ISRAEL | total crew weight about 165kg. there was no bouncing of the bows. they just dived in.
| | | Re: pitchpole
[Re: segev]
#239471 10/28/11 12:21 PM 10/28/11 12:21 PM |
Posts: 932 Solomon's Island, MD | Random BAMF gust? I've seen boats go from upright to pitchpole instantly , nothing you can do in certain situations. Otherwise, did the crew dump the shoot or was he/she holding onto the sheet for dear life, aggravating the situation? Also, did the helm drive down if the rudders weren't cavitated?
Scorpion F18
| | | Re: pitchpole
[Re: samc99us]
#239505 10/30/11 09:59 AM 10/30/11 09:59 AM |
Posts: 8 ISRAEL | random gust? perhaps. The crew was not able to let the sheet off - it happened too fast. The helm drove down, the rudders did not seem to be cavitated.
| | | Re: pitchpole
[Re: catman]
#239737 11/04/11 04:57 AM 11/04/11 04:57 AM |
Posts: 8 ISRAEL | our mast was raked as in the NACRA guide for the F20C. at this position we have neutral helm. we consider taking it backwards, although there is not too much to take since the side stays are almost fully shortened.
| | | Re: pitchpole
[Re: segev]
#239767 11/05/11 01:58 PM 11/05/11 01:58 PM |
Posts: 1,307 Asuncion, Paraguay | boards about 40cm up. main fully sheeted in with traveller centered. Do you use elastics to keep the boards in place? How do you rig them (pulling in what direction)? If you rig the elastics so they pull the top of the boards forward, you are reducing their angle of attack for vertical lift, making the boat more capsize prone. Try rigging the elastics so they pull the top of the boards back, which increases that angle of attack and, consequently, the vertical component of lift. The more you need vertical lift from the boards, the more you want the top of the board pulled back. Enlarge (sand) the cases in the fore and aft direction if you feel that more vertical lift is necessary.
Luiz
267
guests, and 179
